    Data Source gone after upgrade to 3.6
    19 Posts 4 Posters 6.3k Views 4 Watching
    • thutchisT Offline
      thutchis
      I had a serial data source that disappeared after upgrading to 3.6. This data source had one data point that still shows up and I can't delete it. The data point still has data in the database up until the upgrade. I thought about backing up and manually deleting the data source in the .json file, but importing the .json file won't overwrite what's in memory I figure. Help.
      Craft Malt from the Ground Up
        Hi Thutchis
        Can you confirm that the serial data source was upgraded to 3.6. Go to your modules page and scroll down to the serial data source widget.
          As Craig says, please check the serial data source module is being loaded. You will also see a log message in your ma.log file indicating if it was / wasn't loaded.
          • thutchisT Offline
            thutchis
            Modules page shows:
            serial
            Serial Data Source
            Version: 3.6.0
            License: done unrestricted
            Signature: verified_user
            Signed: by store
            Vendor: Infinite Automation Systems Inc.
            I can send the ma.log if you tell me where to send it. There are some error entries. But I can't understand what all it says.
              Sure, please send it to support@infiiteautomation.com or paste the relevant errors here in this thread, so that all may benefit. You can have a line of three back ticks (key to the left of the 1 key, ` ) to format it nicely.
              this.isLegible() //true
              thutchisT 2 Replies Last reply Reply Quote 0
              • thutchisT Offline
                thutchis @phildunlap
                @phildunlap
                I finally got some time to work on this issue. When I try to delete the "orphaned" datapoint I get the following error in the UI.
                Error deleting data point: Internal Server Error — com.serotonin.ShouldNeverHappenException: java.lang.IllegalArgumentException: Invalid enum value
                What the data source and datapoint function is to receive a serial message from a moisture balance in the lab and email me the result. It worked great for over a year until I upgraded to 3.6.0 and that is when the Data Source disappeared.
                I have tried to recreate both the Data Source and Data Point under different names, using the same regex expression to parse the serial message. So far I don't get anything logged in the data point results.
                I do get the serial message logged in the /opt/mango/log/serialIO-x.log so I know the Mango server is getting the messages.
                Any suggestions on how to trouble-shoot this would be appreciated.
                • thutchisT Offline
                  @phildunlap I am also sending the ma.log to support@infiiteautomation.com.
                  Tom
                    The error in the log you provided suggests that it was saved with a databits value perhaps not 5, 6, 7, or 8 and that the enum that is now used for that property doesn't contain the value you were using. Do you know its databits setting?
                    If you know its XID (which you could look up by exporting the point or on the SQL console page), you could try setting its databits via JSON import with...
                       "dataSources":[
                             "xid":"DS_XID",
                             "dataBits":"DATA_BITS_8"
                    But, I'm curious to know what it had been set at, since perhaps the enum of allowed data bits settings needs other settings.
                    thutchisT 1 Reply Last reply Reply Quote 0
                    • thutchisT Offline
                      @phildunlap I am not familar with the databits parameter. How would I determine that?
                        It should be in any old JSON exports that include that data source.
                        • thutchisT Offline
                          @phildunlap OK, I get it now. Databits is the serial parameter of the data source. The data source is the problem because it disappeared when I upgraded to Mango 3.6, leaving the data point "orphaned". Do I need to recreate the original data source with the same XID from an old backup?
                            Did importing the JSON I provided (with the data source xid set to the xid of the missing data source) not solve it?
                            I would look up the XID if you don't know it either via the SQL console page in Mango with select xid, name from dataSources; or in an old JSON backup. Then you could try setting its data bits via the JSON import.
                            To maintain the data in the data point if there is data worth maintaining, recreating the data source will create a couple more steps. Let's try to fix it. Another maybe easier way to fix it would be to create a new serial data source with the right settings, then go to the SQL console page (you may need to enable it under edit menu, and have the sql console module installed) and,
                            select id, name from dataSources;
                            -- find the id of the old and new serial data sources
                            update dataSources set data=(select data from dataSources where id=[new id here]) where id=[old id here];
                            And then you should be able to see it on the data sources page, and delete the new serial data source.
                            • thutchisT Offline
                              @phildunlap said in Data Source gone after upgrade to 3.6:
                              This is the error message get when I submit the SQL Query:
                              update dataSources set data=(select data from dataSources where id=[DS_bf3ed68c-3ced-491a-af92-d228a4ce345c]) where id=[DS_80cdd749-28ad-4612-93d4-cac1ea998a1c];
                              ShouldNeverHappenException: org.h2.jdbc.JdbcSQLSyntaxErrorException: Syntax error in SQL statement "UPDATE DATASOURCES SET DATA=(SELECT DATA FROM DATASOURCES WHERE ID=[[*]DS_BF3ED68C-3CED-491A-AF92-D228A4CE345C]) WHERE ID=[DS_80CDD749-28AD-4612-93D4-CAC1EA998A1C]; "; expected "ALL, ANY, SOME"; SQL statement: update dataSources set data=(select data from dataSources where id=[DS_bf3ed68c-3ced-491a-af92-d228a4ce345c]) where id=[DS_80cdd749-28ad-4612-93d4-cac1ea998a1c]; [42001-199]
                              Apparently the SQL syntax is wrong. I am not enough of an SQL expert to find it.
                              • thutchisT Offline
                                @phildunlap If I put your SQL statement into the "SQL" update window I get the following error:
                                BadSqlGrammarException: StatementCallback; bad SQL grammar [update dataSources set data=(select data from dataSources where id=[DS_bf3ed68c-3ced-491a-af92-d228a4ce345c]) where id=[DS_80cdd749-28ad-4612-93d4-cac1ea998a1c];]; nested exception is org.h2.jdbc.JdbcSQLSyntaxErrorException: Syntax error in SQL statement "UPDATE DATASOURCES SET DATA=(SELECT DATA FROM DATASOURCES WHERE ID=[[*]DS_BF3ED68C-3CED-491A-AF92-D228A4CE345C]) WHERE ID=[DS_80CDD749-28AD-4612-93D4-CAC1EA998A1C]; "; expected "ALL, ANY, SOME"; SQL statement: update dataSources set data=(select data from dataSources where id=[DS_bf3ed68c-3ced-491a-af92-d228a4ce345c]) where id=[DS_80cdd749-28ad-4612-93d4-cac1ea998a1c]; [42001-199]
                                Press Escape to dismiss. Press Control-"o" to
                                  I was intending you to replace the whole square bracket portion with the ID (the number), so
                                  -- example of with some random IDs,
                                  update dataSources set data=(select data from dataSources where id=2) where id=1;
                                  Come to think of it, I'm not sure where I started using square brackets that way - certainly not coding. I think maybe it was composition, like the [one] example[s] didn't illustrate the right syntax but I'm not sure.
                                  • thutchisT Offline
                                    @phildunlap I wondered if that was your intention so I tried leaving out he square brackets, still get errors for some reason.
                                    BadSqlGrammarException: StatementCallback; bad SQL grammar [update dataSources set data=(select data from dataSources where id=DS_bf3ed68c-3ced-491a-af92-d228a4ce345c) where id=DS_80cdd749-28ad-4612-93d4-cac1ea998a1c;]; nested exception is org.h2.jdbc.JdbcSQLSyntaxErrorException: Syntax error in SQL statement "UPDATE DATASOURCES SET DATA=(SELECT DATA FROM DATASOURCES WHERE ID=DS_BF3ED68C-3CED[*]-491A-AF92-D228A4CE345C) WHERE ID=DS_80CDD749-28AD-4612-93D4-CAC1EA998A1C; "; expected "[, ::, *, /, %, +, -, ||, ~, !~, NOT, LIKE, ILIKE, REGEXP, IS, IN, BETWEEN, AND, OR, GROUP, HAVING, WINDOW, QUALIFY, UNION, EXCEPT, MINUS, INTERSECT, ORDER, OFFSET, FETCH, LIMIT, SAMPLE_SIZE, FOR, [, ::, *, /, %, +, -, ||, ~, !~, NOT, LIKE, ILIKE, REGEXP, IS, IN, BETWEEN, AND, OR, ,, )"; SQL statement: update dataSources set data=(select data from dataSources where id=DS_bf3ed68c-3ced-491a-af92-d228a4ce345c) where id=DS_80cdd749-28ad-4612-93d4-cac1ea998a1c; [42001-199]
                                      That is an XID. Note above the update statement I do another select, but only for the ID and name columns, to find the ID.
                                      XID columns are strings, and could work too, but they need to be inside single quotes to behave as strings.
                                      • thutchisT Offline
                                        thutchis
                                        Sorry, I mixed up "id" and "xid". That worked and I can now see the "disappeared" original serial data source on the data sources page.
                                        This seems to have fixed all the issues I had after upgrading to 3.6.x. No more errors in ma.log, The datapoint is now logging the serial data properly and the event handler is sending me the results again via email.
                                        Thanks so much for your patience, I am not a java or javascript programmer so I really struggle with this.
                                          Glad we got it figured out!
