    Mango Service not working on Windows 10
    17 Posts 4 Posters 9.5k Views 4 Watching
      What is in your C:\Mango\yajsw\log\wrapper file when you start the service ?
      • K Offline
        KLN
        I just freshly installed service and below are the log file ( C:\Mango\yajsw\log\wrapper)
        INFO|wrapper|Service com.serotonin.m2m2.Main|19-04-17 15:36:17|ahessian jmx service bound to port 15002
        INFO|wrapper|Service com.serotonin.m2m2.Main|19-04-17 15:36:17|working dir C:\Mango\bin
        INFO|wrapper|Service com.serotonin.m2m2.Main|19-04-17 15:36:17|started process with pid 9028
        INFO|wrapper|Service com.serotonin.m2m2.Main|19-04-17 15:36:18|restart process due to default exit code rule
        INFO|wrapper|Service com.serotonin.m2m2.Main|19-04-17 15:36:18|restart internal RUNNING
        INFO|wrapper|Service com.serotonin.m2m2.Main|19-04-17 15:36:18|stopping process with pid/timeout 9028 45000
        INFO|wrapper|Service com.serotonin.m2m2.Main|19-04-17 15:36:18|process exit code: 4
        INFO|wrapper|Service com.serotonin.m2m2.Main|19-04-17 15:36:23|working dir C:\Mango\bin
        INFO|wrapper|Service com.serotonin.m2m2.Main|19-04-17 15:36:23|started process with pid 8384
        INFO|wrapper|Service com.serotonin.m2m2.Main|19-04-17 15:36:24|restart process due to default exit code rule
        INFO|wrapper|Service com.serotonin.m2m2.Main|19-04-17 15:36:24|restart internal RUNNING
        INFO|wrapper|Service com.serotonin.m2m2.Main|19-04-17 15:36:24|stopping process with pid/timeout 8384 45000
        INFO|wrapper|Service com.serotonin.m2m2.Main|19-04-17 15:36:24|process exit code: 4
        INFO|wrapper|Service com.serotonin.m2m2.Main|19-04-17 15:36:29|working dir C:\Mango\bin
        INFO|wrapper|Service com.serotonin.m2m2.Main|19-04-17 15:36:29|started process with pid 10676
        INFO|wrapper|Service com.serotonin.m2m2.Main|19-04-17 15:36:30|restart process due to default exit code rule
        INFO|wrapper|Service com.serotonin.m2m2.Main|19-04-17 15:36:30|restart internal RUNNING
        INFO|wrapper|Service com.serotonin.m2m2.Main|19-04-17 15:36:30|stopping process with pid/timeout 10676 45000
        INFO|wrapper|Service com.serotonin.m2m2.Main|19-04-17 15:36:30|process exit code: 4
        INFO|wrapper|Service com.serotonin.m2m2.Main|19-04-17 15:36:35|working dir C:\Mango\bin
        INFO|wrapper|Service com.serotonin.m2m2.Main|19-04-17 15:36:35|started process with pid 504
        INFO|wrapper|Service com.serotonin.m2m2.Main|19-04-17 15:36:36|restart process due to default exit code rule
        INFO|wrapper|Service com.serotonin.m2m2.Main|19-04-17 15:36:36|restart internal RUNNING
        INFO|wrapper|Service com.serotonin.m2m2.Main|19-04-17 15:36:36|stopping process with pid/timeout 504 45000
        INFO|wrapper|Service com.serotonin.m2m2.Main|19-04-17 15:36:36|process exit code: 4
        INFO|wrapper|Service com.serotonin.m2m2.Main|19-04-17 15:36:41|working dir C:\Mango\bin
        INFO|wrapper|Service com.serotonin.m2m2.Main|19-04-17 15:36:41|started process with pid 4200
        INFO|wrapper|Service com.serotonin.m2m2.Main|19-04-17 15:36:42|restart process due to default exit code rule
        INFO|wrapper|Service com.serotonin.m2m2.Main|19-04-17 15:36:42|restart internal RUNNING
        INFO|wrapper|Service com.serotonin.m2m2.Main|19-04-17 15:36:42|stopping process with pid/timeout 4200 45000
        INFO|wrapper|Service com.serotonin.m2m2.Main|19-04-17 15:36:42|process exit code: 4
        INFO|wrapper|Service com.serotonin.m2m2.Main|19-04-17 15:36:47|working dir C:\Mango\bin
        INFO|wrapper|Service com.serotonin.m2m2.Main|19-04-17 15:36:47|started process with pid 2528
        INFO|wrapper|Service com.serotonin.m2m2.Main|19-04-17 15:36:48|too many restarts
        INFO|wrapper|Service com.serotonin.m2m2.Main|19-04-17 15:36:48|process not in state RUNNING -> Delaying stop
        INFO|wrapper|Service com.serotonin.m2m2.Main|19-04-17 15:36:48|calling onStop
        INFO|wrapper|Service com.serotonin.m2m2.Main|19-04-17 15:36:48|Win service stop - timeout: 30000
        INFO|wrapper|Service com.serotonin.m2m2.Main|19-04-17 15:36:48|Win service wrapper.control -> stopping application
        INFO|wrapper|Service com.serotonin.m2m2.Main|19-04-17 15:36:48|Win service stop - after shutdown
        INFO|wrapper|Service com.serotonin.m2m2.Main|19-04-17 15:36:48|Win service stop - before notify
        INFO|wrapper|Service com.serotonin.m2m2.Main|19-04-17 15:36:48|Win service terminated
          Why did you show me the JAVA_HOME variable when I asked about the Path variable? If you run java -version in a command prompt, what do you get?
          You can see in the wrapper.conf that
          wrapper.java.command = java
          so it's not going through the Mango startup scripts as would normally be done, it's invoking java directly.
          • K Offline
            KLN
            My variable name:JAVA_HOME
            Now I changed back to
            wrapper.java.command = %JAVA_HOME%/bin/java
            While Starting Service Now I am getting error as
            Error2: The system cannot find the file specified
              One problem with that is that you've apparently defined JAVA_HOME in the User variables instead of the system variables.
              I don't know what you mean, "changed back to" as the zip you'd have gotten from our instructions on the setup had,
              So please check the Path variable for the system user. I am not sure if you could use JAVA_HOME as you have tried, but you would certainly have to define it as a variable for the system user to do so.
                JAST
                I am having the same problem. I've been following this thread as well as a post from three years ago: https://forum.infiniteautomation.com/topic/2270/windows-service-setup/7
                We've set our JAVA_Home variable and edited the PATH variable as well:
                Where would we find our wrapper.config file?
                Is there currently a patch for this or in the works? We are getting this issue with every Windows 10 device we try to load Mango 3 to.
                Thank you.
                  Hi gquiroz,
                  If you downloaded the yajsw from the link on this page: https://help.infiniteautomation.com/installing-services
                  the wrapper.conf would be mostly set up for Mango, and would be in yajsw/conf/
                  You may find the suggestion in this thread useful as an alternative to doing a yajsw service, since it has its own issues like not restarting when restarted via the modules page or during an upgrade: https://forum.infiniteautomation.com/topic/4168/mango-not-starting-back-up-after-restart-within-mango/5
                    JAST
                    Thanks!
                    I was able to get the service up and running with a system power cycle.
                      JAST
                      @phildunlap said in Mango Service not working on Windows 10:
                      We are experiencing this issue again. As KLN describes, the service does successfully install and we can see that it is running. But when trying to run mango on the browser, it cannot connect to local host. From your recommendation on https://forum.infiniteautomation.com/topic/4168/mango-not-starting-back-up-after-restart-within-mango/4 where would the event handler to create the Mango/RESTART file go?
                        On the system startup event.
