    Mango Service not working on Windows 10
    17 Posts 4 Posters 9.5k Views 4 Watching
    • K Offline
      KLN
      I couldn't able to see any updates on C:\Mango\logs\ma.log file recently, I too cleared log file and restarted the service No updates on ma.log
      I tried running services on command prompt below are updates. but services stopped again..
      C:\Mango\yajsw\bat>startservice.bat
      C:\Mango\yajsw\bat>cd C:\Mango\yajsw\bat\
      C:\Mango\yajsw\bat>call setenv.bat
      "java" -Xmx30m -Djna_tmpdir="C:\Mango\yajsw\bat/../tmp" -Djava.net.preferIPv4Stack=true -jar "C:\Mango\yajsw\bat/../wrapper.jar" -t "C:\Mango\yajsw\bat/../conf/wrapper.conf"
      YAJSW: yajsw-stable-11.11
      OS : Windows 10/10.0/x86
      JVM : Oracle Corporation/1.8.0_201/C:\Program Files (x86)\Java\jre1.8.0_201/32
      Apr 16, 2019 9:42:14 PM org.apache.commons.vfs2.VfsLog info
      INFO: Using "C:\Users\L&TTOD~1\AppData\Local\Temp\vfs_cache" as temporary files store.
      ************* STARTING Mango ***********************
      Service Mango started
      Press any key to continue . . .
        Hi KLN,
        You can check the Windows event viewer, it may have details. It sounds like maybe 'java' isn't on the Path environment variable for the system user? Can you confirm you've added the C:\Path\to\jdk\bin\ to the system Path variable?
        After that, I'd wonder if the paths in the wrapper.conf were correctly adjusted to where you installed Mango. I'll give the process a try tomorrow. It's been a long time since I did a Windows service installation so I'm not remembering all the subtleties This is a thread where someone ran into issues and figured them out: https://forum.infiniteautomation.com/topic/2270/windows-service-setup
        • K Offline
          KLN
          Hi phildunlap,
          Please find attached Environmental Setup screen shot.
          Mango path on my PC as below.
          C:\Mango
          My Wrapper.conf file details are below..
          # WARNING - Do not modify any of the properties when an application
          #  using this configuration file has been installed as a service or daemon.
          #  Please uninstall the service before modifying this file.  The
          #  service must then be reinstalled.
          # working directory
          ## Edit:
          wrapper.working.dir=C:\\Mango\\bin\\
          # tmp folder
          # yajsw creates temporary files named in_.. out_.. err_.. jna..
          # per default these are placed in jna.tmpdir.
          # jna.tmpdir is set in setenv batch file to <yajsw>/tmp
          wrapper.tmp.path = ${jna_tmpdir}
          # Application main class or native executable
          # One of the following properties MUST be defined
          # Java Application main class
          wrapper.java.app.mainclass=com.serotonin.m2m2.Main
          # Wrapper Logging Properties
          # Log Level for console output.  (See docs for log levels)
          wrapper.console.loglevel=INFO
          # Log file to use for wrapper output logging.
          wrapper.logfile=${wrapper_home}\/log\/wrapper.log
          # Maximum size that the log file will be allowed to grow to before
          #  the log is rolled. Size is specified in bytes.  The default value
          #  of 0, disables log rolling by size.  May abbreviate with the 'k' (kB) or
          #  'm' (mB) suffix.  For example: 10m = 10 megabytes.
          # If wrapper.logfile does not contain the string ROLLNUM it will be automatically added as suffix of the file name
          wrapper.logfile.maxsize=10m
          # Maximum number of rolled log files which will be allowed before old
          #  files are deleted.  The default value of 0 implies no limit.
          wrapper.logfile.maxfiles=10
          # Application Console Properties
          # Title to use when running as a console
          wrapper.console.title=com.serotonin.m2m2.Main
          # Wrapper Windows Service and Posix Daemon Properties
          # Name of the service
          wrapper.ntservice.name=Mango
          # Display name of the service
          wrapper.ntservice.displayname=Mango
          # Description of the service
          wrapper.ntservice.description=Mango Automation
          # Wrapper Posix Daemon Properties
          # The following grooy script should set it correctly for most distros
          wrapper.daemon.run_level_dir=${if (new File('\/etc\/rc0.d').exists()) return '\/etc\/rcX.d' else return '\/etc\/init.d\/rcX.d'}
          # Wrapper System Tray Properties
          # enable system tray
          wrapper.tray = true
          # TCP/IP port. If none is defined multicast discovery is used to find the port
          # Set the port in case multicast is not possible.
          wrapper.tray.port = 15002
          # Exit Code Properties
          # Restart on non zero exit code
          wrapper.on_exit.0=SHUTDOWN
          wrapper.on_exit.default=RESTART
          # Trigger actions on console output
          # On Exception show message in system tray
          wrapper.filter.trigger.0=Exception
          wrapper.filter.script.0=scripts\/trayMessage.gv
          wrapper.filter.script.0.args=Exception
          # genConfig: further Properties generated by genConfig
          placeHolderSoGenPropsComeHere=
          wrapper.java.command = java
          # Edit:
          wrapper.java.classpath.1 = C:\\Mango\\overrides\\classes
          wrapper.java.classpath.2 = C:\\Mango\\classes
          wrapper.java.classpath.3 = C:\\Mango\\overrides\\properties
          wrapper.java.classpath.4 = C:\\Mango\\overrides\\lib\\*.jar
          wrapper.java.classpath.5 = C:\\Mango\\lib\\*.jar
          wrapper.java.additional.1 = -server
          wrapper.java.additional.2 = -Dma.home=C:\\Mango
            What is in your C:\Mango\yajsw\log\wrapper file when you start the service ?
            • K Offline
              KLN
              I just freshly installed service and below are the log file ( C:\Mango\yajsw\log\wrapper)
              INFO|wrapper|Service com.serotonin.m2m2.Main|19-04-17 15:36:17|ahessian jmx service bound to port 15002
              INFO|wrapper|Service com.serotonin.m2m2.Main|19-04-17 15:36:17|working dir C:\Mango\bin
              INFO|wrapper|Service com.serotonin.m2m2.Main|19-04-17 15:36:17|started process with pid 9028
              INFO|wrapper|Service com.serotonin.m2m2.Main|19-04-17 15:36:18|restart process due to default exit code rule
              INFO|wrapper|Service com.serotonin.m2m2.Main|19-04-17 15:36:18|restart internal RUNNING
              INFO|wrapper|Service com.serotonin.m2m2.Main|19-04-17 15:36:18|stopping process with pid/timeout 9028 45000
              INFO|wrapper|Service com.serotonin.m2m2.Main|19-04-17 15:36:18|process exit code: 4
              INFO|wrapper|Service com.serotonin.m2m2.Main|19-04-17 15:36:23|working dir C:\Mango\bin
              INFO|wrapper|Service com.serotonin.m2m2.Main|19-04-17 15:36:23|started process with pid 8384
              INFO|wrapper|Service com.serotonin.m2m2.Main|19-04-17 15:36:24|restart process due to default exit code rule
              INFO|wrapper|Service com.serotonin.m2m2.Main|19-04-17 15:36:24|restart internal RUNNING
              INFO|wrapper|Service com.serotonin.m2m2.Main|19-04-17 15:36:24|stopping process with pid/timeout 8384 45000
              INFO|wrapper|Service com.serotonin.m2m2.Main|19-04-17 15:36:24|process exit code: 4
              INFO|wrapper|Service com.serotonin.m2m2.Main|19-04-17 15:36:29|working dir C:\Mango\bin
              INFO|wrapper|Service com.serotonin.m2m2.Main|19-04-17 15:36:29|started process with pid 10676
              INFO|wrapper|Service com.serotonin.m2m2.Main|19-04-17 15:36:30|restart process due to default exit code rule
              INFO|wrapper|Service com.serotonin.m2m2.Main|19-04-17 15:36:30|restart internal RUNNING
              INFO|wrapper|Service com.serotonin.m2m2.Main|19-04-17 15:36:30|stopping process with pid/timeout 10676 45000
              INFO|wrapper|Service com.serotonin.m2m2.Main|19-04-17 15:36:30|process exit code: 4
              INFO|wrapper|Service com.serotonin.m2m2.Main|19-04-17 15:36:35|working dir C:\Mango\bin
              INFO|wrapper|Service com.serotonin.m2m2.Main|19-04-17 15:36:35|started process with pid 504
              INFO|wrapper|Service com.serotonin.m2m2.Main|19-04-17 15:36:36|restart process due to default exit code rule
              INFO|wrapper|Service com.serotonin.m2m2.Main|19-04-17 15:36:36|restart internal RUNNING
              INFO|wrapper|Service com.serotonin.m2m2.Main|19-04-17 15:36:36|stopping process with pid/timeout 504 45000
              INFO|wrapper|Service com.serotonin.m2m2.Main|19-04-17 15:36:36|process exit code: 4
              INFO|wrapper|Service com.serotonin.m2m2.Main|19-04-17 15:36:41|working dir C:\Mango\bin
              INFO|wrapper|Service com.serotonin.m2m2.Main|19-04-17 15:36:41|started process with pid 4200
              INFO|wrapper|Service com.serotonin.m2m2.Main|19-04-17 15:36:42|restart process due to default exit code rule
              INFO|wrapper|Service com.serotonin.m2m2.Main|19-04-17 15:36:42|restart internal RUNNING
              INFO|wrapper|Service com.serotonin.m2m2.Main|19-04-17 15:36:42|stopping process with pid/timeout 4200 45000
              INFO|wrapper|Service com.serotonin.m2m2.Main|19-04-17 15:36:42|process exit code: 4
              INFO|wrapper|Service com.serotonin.m2m2.Main|19-04-17 15:36:47|working dir C:\Mango\bin
              INFO|wrapper|Service com.serotonin.m2m2.Main|19-04-17 15:36:47|started process with pid 2528
              INFO|wrapper|Service com.serotonin.m2m2.Main|19-04-17 15:36:48|too many restarts
              INFO|wrapper|Service com.serotonin.m2m2.Main|19-04-17 15:36:48|process not in state RUNNING -> Delaying stop
              INFO|wrapper|Service com.serotonin.m2m2.Main|19-04-17 15:36:48|calling onStop
              INFO|wrapper|Service com.serotonin.m2m2.Main|19-04-17 15:36:48|Win service stop - timeout: 30000
              INFO|wrapper|Service com.serotonin.m2m2.Main|19-04-17 15:36:48|Win service wrapper.control -> stopping application
              INFO|wrapper|Service com.serotonin.m2m2.Main|19-04-17 15:36:48|Win service stop - after shutdown
              INFO|wrapper|Service com.serotonin.m2m2.Main|19-04-17 15:36:48|Win service stop - before notify
              INFO|wrapper|Service com.serotonin.m2m2.Main|19-04-17 15:36:48|Win service terminated
                Why did you show me the JAVA_HOME variable when I asked about the Path variable? If you run java -version in a command prompt, what do you get?
                You can see in the wrapper.conf that
                so it's not going through the Mango startup scripts as would normally be done, it's invoking java directly.
                • K Offline
                  KLN
                  My variable name:JAVA_HOME
                  Now I changed back to
                  wrapper.java.command = %JAVA_HOME%/bin/java
                  While Starting Service Now I am getting error as
                  Error2: The system cannot find the file specified
                    One problem with that is that you've apparently defined JAVA_HOME in the User variables instead of the system variables.
                    I don't know what you mean, "changed back to" as the zip you'd have gotten from our instructions on the setup had,
                    So please check the Path variable for the system user. I am not sure if you could use JAVA_HOME as you have tried, but you would certainly have to define it as a variable for the system user to do so.
                      JAST
                      I am having the same problem. I've been following this thread as well as a post from three years ago: https://forum.infiniteautomation.com/topic/2270/windows-service-setup/7
                      We've set our JAVA_Home variable and edited the PATH variable as well:
                      Where would we find our wrapper.config file?
                      Is there currently a patch for this or in the works? We are getting this issue with every Windows 10 device we try to load Mango 3 to.
                      Thank you.
                        Hi gquiroz,
                        If you downloaded the yajsw from the link on this page: https://help.infiniteautomation.com/installing-services
                        the wrapper.conf would be mostly set up for Mango, and would be in yajsw/conf/
                        You may find the suggestion in this thread useful as an alternative to doing a yajsw service, since it has its own issues like not restarting when restarted via the modules page or during an upgrade: https://forum.infiniteautomation.com/topic/4168/mango-not-starting-back-up-after-restart-within-mango/5
                          JAST
                          Thanks!
                          I was able to get the service up and running with a system power cycle.
                            JAST
                            @phildunlap said in Mango Service not working on Windows 10:
                            We are experiencing this issue again. As KLN describes, the service does successfully install and we can see that it is running. But when trying to run mango on the browser, it cannot connect to local host. From your recommendation on https://forum.infiniteautomation.com/topic/4168/mango-not-starting-back-up-after-restart-within-mango/4 where would the event handler to create the Mango/RESTART file go?
                              On the system startup event.
