    mango changes MVAR units to MVA
    6 Posts 4 Posters 2.4k Views 4 Watching
      craig
      I am trying to use units MVAR and MVARh but mango keeps changing them to MV*A and MVAh.
      Can MVAR and MVARh be added to the list of units?
        Hi Craig
        you can add a suffix to your points if the unit you need is not in the list.
          Hi Craigs,
          This thread has some information about another option, to modify the UnitUtil class to have them as units or labels: https://forum.infiniteautomation.com/topic/3202/converting-units
            @craig, In the Mango code we have implemented Aliases for VAR and VA which correspond to Volts x Amps. Since VAR is a measure of a 'type' of Power my understanding is that it is still basically Volts x Amps. If you want to convert your point's values to another Unit they need to be based on derived units that are supported by our library so VAR = V*A. If you don't need to convert this value to another type of unit for display then as @CraigWeb says, just use a suffix.
              @terrypacker While VAR is effectively Volt X Amps. It should always be displayed as VAR. As that is its unit. Reactive power is different to active power and needs to be measured when doing power factor correction. All 3 phase systems have both active and reactive power and both need to be measured and displayed. It probably is worth looking into adding it as a unit.
                @CraigWeb I agree and actually right after I made my previous post took a deeper look into what is going on with the internals of our Units library. I think something isn't working quite right with our Unit Aliases so I opened this issue:
                https://github.com/infiniteautomation/ma-core-public/issues/1331
