Trend line max point value limit
Will I need to have the same points on different update rates to avoid this issue with trend lines? So have a slower update rate point for the trends and then the same point on a quicker update rate for the displayed value?
Or are there other ways around it in the watch list configuration?
Right now, these points are reading from a device with 10 second update rate and I cannot see past 1 week.
image url) -
The problem may not be clear from the picture. It has a points values limited to 5001 values, please reduce time range or adjust the rollup interval. message at the bottom and the data flat lines.
Hi sbaik,
You can use rollups in the datebar to avoid that. You can also increase that limit in the UI settings: https://forum.infiniteautomation.com/topic/2983/increase-the-5001-limit-on-values-in-the-new-dashboards-ui
@phildunlap said in Trend line max point value limit:
I just set it to 10x and it worked. any repercussions on limit that high?
If you set it too high you'll be more likely to crash a browser.
