    78 Posts 3 Posters 96.9k Views 2 Watching
      Hi Jose,
      Data source settings;
      Row based query: unchecked, false
      (you'll have to handle the connection settings yourself using the in-Mango help, but it looks like this is already working for you)
      ID data point:
      data type numeric, column name "ID"
      info data point
      data type alphanumeric, column name "info"
      As for parsing what you're after out of the info field, I would do that in the script's "transformInfoToValue" function, and not try to do it in the SQL data source. Here's another possible version of that function:
      function transformInfoToValue( infoValue ) {
        //We'll use a regex group to get that part of the string
        var fnc = /FNC="([^"]*)"/.exec( infoValue );
        if( fnc === null )
           throw "FNC regex did not match text in info field";
        if( fnc[1]== "RESET" )
          return 3;
        else if( fnc[1]== "ACK" )
          return 2;
        else if( fnc[1] == "SILENCE" )
          return 4;
        else
          throw "Unknown value for xyz set: " + source.value;
        jmatos @phildunlap
        @phildunlap
        The scripts senses one error in line 17
        dataOut.set( transformInfoToValue( info.value ) );
        What could it be?
          This is a scripting data source that this script is in, yes? Only the scripting data source can call set()
          I would check...
          1. That we're not hitting the throw condition in the transformInfoToValue function. You could change it to return -1; in the else clause and instead do something like...
          var transformedValue = transformInfoToValue( info.value );
          if( transformedValue >= 0 )
              dataOut.set( transformedValue );
          1. That the variable name for dataOut is the same in the context and the script body. Same for info.
          2. That dataOut and info are settable.
          3. That dataOut and info are enabled.
            jmatos @phildunlap
            @phildunlap said in How to change the http sending value parameter:
            Hi jmatos,
            I'm not sure I completely understand, but it sounds like Point Links may work well for you. It sounds like you want to get values from lots of points and publish them all from the same point. Assuming this is for the publisher, a solution could be something like....
            1. Create a virtual point named 'Alarm Out' with an XID of 'almnr' of type alphanumeric
            2. Create a global script, having the body:
            function getPrefix() { /*So that you may change the prefix for all scripts later if required */
                return "4";
            1. Create a point link '1002 Alarm' from source 'CDI1 – LP_SENSOR_MANUAL_1002/1_1/4194279' to target 'Alarm Out', with the script body:
            return getPrefix() + "1002" + source.value;
            1. Create similar point links to 'Alarm Out' from all other points you will publish this way.
            Note that the 1002 is hardcoded into the script, since there will be 1 point link from each data point you're publishing here to our 'Alarm Out' point.
            If you have only a handful to set up, you can do it by hand. If you have hundreds, I can provide a script to generate the point links for you. A helpful regex for parsing out those DeviceID values could be:
            ^[^/]+_(\d+)/
            Hi Phildunlap,
            Following this solution I have tried to change the code of one of the point link to send two alarmOut upon a condition. No success... :-(
            Is something like this - wrong code - that I need on the specific point link:
            if(source.value == 6)
                return getPrefix() + "0101" + source.value;
            else
            The objective is to send two different alarm out when the source.value meets the condition. In any other cases only sends one alarm out.
            It's possible?
            Thank you
            Jose
              Hi Jose,
              If you need to do something like that you'll want to use the scripting data source as i described in the paragraph starting with "Alternatively (and perhaps more straightforwardly)" as you could simply call 'dataOut.set( )' twice
              Alternatively, you could have a second point link which only returns a value in that special case that you need to set two values.
                jmatos @phildunlap
                Hi jmatos,
                    return "4";
                ^[^/]+_(\d+)/
                Hi phildunlap,
                Now that we have buy at IAS the Mango solution we gonna step into the full configuration.
                As you say in the last paragraph above, you can provide us a script to generate all the points.
                How could this be done?
                Thank you in advance,
                Jose
                  Hi Jose,
                  I'm sure I had a clearer picture in my mind of what I would need to write you when I said that. But, here's a python script to generate JSON you can import on the import/export page. You'll need to edit the paths in the script if you want to use it, and it'll intake a CSV file like:
                  DP_123456,1003
                  DP_654321,1004
                  and output JSON for point links you can import. You may also need to modify the target point XID or other things like that. Here's the python:
                  import json
                  from StringIO import StringIO
                  #use double slashes for windows, i.e. "C:\\path\\to\\new-point-links.csv"
                  csvPointXids = open("/path/to/new-point-links.csv")
                  #I will treat this as though it's a CSV with two columns, 0 is source point XID, 1 is the code for the point link body, like 1002
                  basePointLink = """{
                           "xid":"PL_17-3-1_gen_%(loopCounter)d",
                           "sourcePointId":"%(sourceXid)s",
                           "targetPointId":"almnr",
                           "event":"CHANGE",
                           "logLevel":"NONE",
                           "disabled":false,
                           "script":"return getPrefix() + '%(outputNumber)s' + source.value",
                           "scriptPermissions":{
                              "customPermissions":"",
                           "writeAnnotation":false
                  #uncomment this if you have a header line to consume
                  #csvPointXids.readline()
                  outputConfig = {"pointLinks":[]}
                  loopCounter = 1
                  for line in csvPointXids.readlines() :
                  	data = line.replace("\r","").replace("\n","").split(",")
                  	if len(data) < 2 :
                  		continue
                  	pointJson = basePointLink % {"loopCounter": loopCounter, "sourceXid": data[0], "outputNumber": data[1]}
                  	#print pointJson
                  	outputConfig["pointLinks"].append( json.load( StringIO( pointJson ) ) )
                  	loopCounter += 1
                  csvPointXids.close()
                  #You need to edit this output path as well. C:\\path\\to\\output.json
                  output = open("/path/to/output.json", "w+")
                  output.write( json.dumps( outputConfig, indent=4, sort_keys=False, separators=(",",":") ) )
                  output.close()
                    jmatos
                    Hi phildunlap,
                    :-( Sorry I can't figure out two things:
                    A) Where do I run this code?
                    • I have run it in my windows python (3.6) but the only out put is:
                        "pointLinks",[]
                    B) After I run it I have to import the json file to Mango...?!
                    This is mainly because I can't understand how the code of basePointLink will pass to json... the previous pointLinks is empty.
                    Thank you,
                    Jose
                      Hi Jose,
                      I would bet that means there are no lines in your CSV or there is not a comma in the line separating the two fields. You can add a statement like
                      print line
                      to the for line in csvPointXids.readlines() : block before the if len(data). to see it print at the command line. If there are no lines in your file you will see no output. I think if you have the file path wrong in the initial open() it will error.
                      It looks like I got the separators backwards (should be separators=(",",":"), so I edited that to fix. I did test that the script generates JSON (but I didn't import the json)
                        jmatos
                        It's working!
                        Thank you very much. :-)
                          jmatos
                          Hi phildunlap,
                          How do I stop "Failed to send email (.)" messages? Is there any way to disable the email service on settings? I don't need it.
                          thank you
                            Hi jmatos,
                            The event level is set in the "System event alarm levels" section of the system settings as "Email send failure"
                            You can change this to "Do not log" (event handlers of the "Email send failure" event will be notified, but nothing will be stored in the database) or "Ignore" (nothing will happen).
                            I would wonder why you're sending emails if they're failing and you do not want them? Did you create an email event handler, or have you set your user to receive event emails above a certain threshhold?
                              jmatos
                              I have a DataSource with several (hundreds) DataPoints that I have imported and I want to discard. Which is the better an quick way to do it?
                              Thanks in advance,
                              Jose
                                Hi Jose,
                                You can delete the data source if it's all the points on the data source.
                                You can use the JSON from your import and this script to generate SQL delete statements:
                                #!/bin/python
                                import json
                                importedPoints = open("/path/to/import.json")
                                imprt = json.load(importedPoints)
                                importedPoints.close()
                                outputFile = open("/path/to/output.sql", "w+")
                                for dp in imprt["dataPoints"] :
                                    outputFile.write("DELETE FROM dataPoints WHERE xid='"+dp["xid"]+"';\n");
                                outputFile.close();
                                Next step would be running the SQL statements in an sql console.
                                  jmatos
                                  Sorry I do not understand where I "choose" the points to be deleted.
                                  In my mind I have (certainly wrong) exported the DS into an csv file and then in Excel I run a function to remove the DataPoints that I do not want. I was hopping that Mango could inversely import this kind of file.
                                    There is no way to delete points through import/export functions. You can generate the SQL from a CSV really easily, though, just get the XID from a column in the CSV...
                                    #!/bin/python
                                    xidColumn = 3 #change this!
                                    points = open("/path/to/points.csv")
                                    for line in points.readlines() :
                                        outputFile.write("DELETE FROM dataPoints WHERE xid='"+data[xidColumn]+"';\n");
                                    outputFile.close();
                                      jmatos @phildunlap
                                      @phildunlap
                                      The project is now installed and working on the client. We are in the real test and pay attention to how it behaves.
                                      To try workaround the issue on C) (c) - In the Virtual DATASOURCE there is one "update period" that makes the systems send the last alarm in that period time. Is there some way to deactivate it?) I set the update period to 300000h (about 34 years). Do you see any inconvenience on that?
                                      Thank you very much
                                        Yeah that's fine. What'll happen is every time the data source is enabled or disabled it will poll once, and then it'll be negligible load on the system.
                                        In Mango 3 I added a feature to the virtual data source to disable its polling entirely.
                                          jmatos
                                          Hi Phildunlap,
                                          As you know the solution is already installed at client facilities.
                                          unfortunately I have cross with a "huge" problem that I can't figure out. :-(
                                          When there is more than two (2) - say six - simultaneous alarm I can't get them all out on the http publisher. The alarms are registered in historic but only two reach the destination. It seems that they are lost between the publisher and from this to network. I've used wireshark and I dont see they getting out.
                                          I've try to increase the cache size (is necessary to restart the all mango instance or a simple save is enough?)
                                          May you please help me on this one?
                                          Thanks in advance,
                                          Jose
                                            jmatos @jmatos
                                            @jmatos said in How to change the http sending value parameter:
                                            Hi Phildunlap,
                                            Thanks in advance,
                                            Jose
                                            Do you have any answer to me regarding this issue?
