    78 Posts 3 Posters 96.9k Views 2 Watching
      Hi Jose,
      I would bet that means there are no lines in your CSV or there is not a comma in the line separating the two fields. You can add a statement like
      print line
      to the for line in csvPointXids.readlines() : block before the if len(data). to see it print at the command line. If there are no lines in your file you will see no output. I think if you have the file path wrong in the initial open() it will error.
      It looks like I got the separators backwards (should be separators=(",",":"), so I edited that to fix. I did test that the script generates JSON (but I didn't import the json)
        jmatos
        It's working!
        Thank you very much. :-)
          jmatos
          Hi phildunlap,
          How do I stop "Failed to send email (.)" messages? Is there any way to disable the email service on settings? I don't need it.
          thank you
            Hi jmatos,
            The event level is set in the "System event alarm levels" section of the system settings as "Email send failure"
            You can change this to "Do not log" (event handlers of the "Email send failure" event will be notified, but nothing will be stored in the database) or "Ignore" (nothing will happen).
            I would wonder why you're sending emails if they're failing and you do not want them? Did you create an email event handler, or have you set your user to receive event emails above a certain threshhold?
              jmatos
              I have a DataSource with several (hundreds) DataPoints that I have imported and I want to discard. Which is the better an quick way to do it?
              Thanks in advance,
              Jose
                Hi Jose,
                You can delete the data source if it's all the points on the data source.
                You can use the JSON from your import and this script to generate SQL delete statements:
                #!/bin/python
                import json
                importedPoints = open("/path/to/import.json")
                imprt = json.load(importedPoints)
                importedPoints.close()
                outputFile = open("/path/to/output.sql", "w+")
                for dp in imprt["dataPoints"] :
                    outputFile.write("DELETE FROM dataPoints WHERE xid='"+dp["xid"]+"';\n");
                outputFile.close();
                Next step would be running the SQL statements in an sql console.
                  jmatos
                  Sorry I do not understand where I "choose" the points to be deleted.
                  In my mind I have (certainly wrong) exported the DS into an csv file and then in Excel I run a function to remove the DataPoints that I do not want. I was hopping that Mango could inversely import this kind of file.
                    There is no way to delete points through import/export functions. You can generate the SQL from a CSV really easily, though, just get the XID from a column in the CSV...
                    #!/bin/python
                    xidColumn = 3 #change this!
                    points = open("/path/to/points.csv")
                    for line in points.readlines() :
                        data = line.replace("\r","").replace("\n","").split(",")
                        outputFile.write("DELETE FROM dataPoints WHERE xid='"+data[xidColumn]+"';\n");
                    outputFile.close();
                      jmatos @phildunlap
                      @phildunlap
                      The project is now installed and working on the client. We are in the real test and pay attention to how it behaves.
                      To try workaround the issue on C) (c) - In the Virtual DATASOURCE there is one "update period" that makes the systems send the last alarm in that period time. Is there some way to deactivate it?) I set the update period to 300000h (about 34 years). Do you see any inconvenience on that?
                      Thank you very much
                        Yeah that's fine. What'll happen is every time the data source is enabled or disabled it will poll once, and then it'll be negligible load on the system.
                        In Mango 3 I added a feature to the virtual data source to disable its polling entirely.
                          jmatos
                          Hi Phildunlap,
                          As you know the solution is already installed at client facilities.
                          unfortunately I have cross with a "huge" problem that I can't figure out. :-(
                          When there is more than two (2) - say six - simultaneous alarm I can't get them all out on the http publisher. The alarms are registered in historic but only two reach the destination. It seems that they are lost between the publisher and from this to network. I've used wireshark and I dont see they getting out.
                          I've try to increase the cache size (is necessary to restart the all mango instance or a simple save is enough?)
                          May you please help me on this one?
                          Thanks in advance,
                          Jose
                            jmatos @jmatos
                            @jmatos said in How to change the http sending value parameter:
                            Hi Phildunlap,
                            Thanks in advance,
                            Jose
                            Do you have any answer to me regarding this issue?
                              Hi jmatos,
                              I would wonder,
                              1. What is the update event for the publisher?
                              2. What is the logging type for the Alarm out point?
                              3. Are you using the NoSQL database?
                              My expectation is that the logging type for the alarm point is discarding some seemingly-backdated data in the concurrent update situation, or possible that the data is occurring at the same millisecond, and the NoSQL database can't store more than one value at one timestamp.
                                jmatos
                                Hi phildunlap
                                1. All
                                2. When point value changes
                                3. I think so (How can I be sure?)
                                More info: When I go to menu [Data Point Details] history all the alarm out are registered OK.
                                Here on lab I try an simulated an alarm out send through the http publisher to the same destination software with a virtual source generating a random number every 1ooms and all them reach the destination.
                                Tomorrow I'll go to the client and try this virtual send.
                                updating after visit the client:
                                Test results with real BACnet objects on client:
                                At two times I had to restart Mango and five of five(!) alarms get to the destination! But just on the startup... :-( All the test afterwards only get the "old same" two.
                                So, the alarms are registered at entry level and reported in the Data Point Details. But only two reach the destination.
                                I think you maybe right concerning the same millisecond, but in this case something has to explain the five-of-five that reach the destination on startup.
                                Is there some delay we can insert to workaround the possible same timestamp?
                                Important: As I told you before, I'm not sure what DB is in use. How can I be sure and if not using NoSQL how do I change it? the problem can be in here... :-(
                                Thanks in advance,
                                Jose
                                  Hmm.
                                  Before working on a workaround for the same milliseconds, let's try to confirm that's actually occurring (but maybe this would be the workaround). One thing you could try is putting a couple manual offsets in the point links' times, like:
                                  TIMESTAMP = source.time+1; //one millisecond later than the source's TS
                                  //you could use +2 on another one, and so on
                                  It's possible on startup it registered a COV notification, got that point values (everything would have different timestamps), but for some reason reverted to polling those points. In which case, all new values would have the timestamp of the poll.
                                    jmatos
                                    Hi Phil,
                                    Where do I put it? Sorry but I can figure it out. Probably because I have 1800 point links... I'm lost here. :-(
                                    As instructed previously by you I put a Global script
                                    function getPrefix() { /*So that you may change the prefix for all scripts later if required */
                                        return "4";
                                    this is running on all point links. Is any way to add the time code here? Or am I confused? (its not the first time :D )
                                    thank you
                                      Wow 1800! Are they all to the same target point? At a certain number we may want to rethink the general tactic of wedging lots of points' alarms out one point. But, if it works, ok.
                                      Off hand I can't think of a way to do what I was describing in the global script, but here's a python script to mass modify your point links. You probably want to keep a JSON backup of them, in case you wish to revert.
                                      import json
                                      config = json.load( configFile )
                                      configFile.close()
                                      x = 0
                                      for pl in config["pointLinks"] :
                                        if pl["script"] != "" :
                                          pl["script"] = "TIMESTAMP=source.time+" + str(x) + ";\\n" + pl["script"]
                                          x += 1
                                      outputFile = open("/path/to/output.json", "w+")
                                      outputFile.write( json.dumps( {"pointLinks": config["pointLinks"]}, indent=4, sort_keys=False, separators=(",",": ") )
                                      outputFile.close()
                                        jmatos
                                        I'm hopping to test the first code in six or 8 link points. That I can do one by one... ;-)
                                        Thanks in advance for the second code.
                                        I'll feedback to you.
                                          jmatos @phildunlap
                                          @phildunlap said in How to change the http sending value parameter:
                                          import json
                                          configFile.close()
                                          x = 0
                                              x += 1
                                          outputFile.close()
                                          Sorry. I get an invalid syntax at outputFile.close()
                                            Whoops. Looks like there was a missing parenthesis. Fixed.
