    Mango Persistent TCP publisher constantly resets connection
    26 Posts 5 Posters 15.7k Views 4 Watching
      MaP
      I have upgraded the local mango to the latest persistent module but we still see the same connection reset behavior.
        MaP
        I enabled the Debug log for a while and received the following logs (only put about a third here):
        INFO 2016-10-27 15:00:50,050 (com.serotonin.m2m2.persistent.pub.PersistentSenderRT.initialize:228) - Initializing
        INFO 2016-10-27 15:00:50,101 (com.serotonin.m2m2.persistent.pub.PersistentSenderRT.initialize:242) - Initialized
        WARN 2016-10-27 15:00:51,127 (com.serotonin.m2m2.persistent.pub.PersistentSendThread.runImpl:182) - Connection reset
        java.net.SocketException: Connection reset
        at java.net.SocketInputStream.read(SocketInputStream.java:189)
        at java.net.SocketInputStream.read(SocketInputStream.java:121)
        at java.net.SocketInputStream.read(SocketInputStream.java:203)
        at com.serotonin.m2m2.persistent.common.Packet.readPacket(Packet.java:93)
        at com.serotonin.m2m2.persistent.pub.PersistentSendThread.getPointReceipt(PersistentSendThread.java:617)
        at com.serotonin.m2m2.persistent.pub.PersistentSendThread.openConnection(PersistentSendThread.java:599)
        at com.serotonin.m2m2.persistent.pub.PersistentSendThread.runImpl(PersistentSendThread.java:179)
        at com.serotonin.m2m2.rt.publish.SendThread.run(SendThread.java:56)
        WARN 2016-10-27 15:00:54,074 (com.serotonin.m2m2.persistent.pub.PersistentSendThread.runImpl:182) - Connection reset
        WARN 2016-10-27 15:00:57,354 (com.serotonin.m2m2.persistent.pub.PersistentSendThread.runImpl:182) - Connection reset
        WARN 2016-10-27 15:01:00,324 (com.serotonin.m2m2.persistent.pub.PersistentSendThread.runImpl:182) - Connection reset
        WARN 2016-10-27 15:01:03,604 (com.serotonin.m2m2.persistent.pub.PersistentSendThread.runImpl:182) - Connection reset
        WARN 2016-10-27 15:01:06,564 (com.serotonin.m2m2.persistent.pub.PersistentSendThread.runImpl:182) - Connection reset
        Any assistance would be appreciated.
          Is this to imply there was no debug output on the receiver's end? You can set the level even lower, at Trace. When I asked about the status button, I was wondering about from the Publisher's side as well.
          I would try to assess whether it was a configuration issue or a network issue. To do that I would export your Publisher's configuration, remove all the items in the "points" list, change the host to localhost and import it on your receiver's Mango. Create some virtual points, and see if you can publish them to the localhost receiver. If so, and both Mangos are running on the same versions of the module, you can be sure it's a network problem.
          Another thought is to remove the data points from the publisher, and see if the connection is stable.
            MaP
            I have some screenshots of the receiver side Trace Logs here:
            Constraint A foreign key constrant fails - DataSourceId References DataSources_Old
            Any ideas how to solve this?
            0_1477626888402_upload-450be2da-545a-47d8-ae31-a4216716418d
            0_1477626900084_upload-6ffb83db-fe75-41dd-8337-bfd20036dd14
              MaP
              This post is deleted!
                MaP
                Also encountering the below error while trying to construct a new publisher using only mango data source points like CPU temp.
                The published data points section just hangs with a loading image after seeing this error
                0_1477627920182_upload-49e1e9c1-9632-4377-8e3f-7aaf24e4253b
                  dataSources_old? You were playing around in your database schema! I assume you created a table dataSources_new like dataSources, then renamed dataSources to dataSources_old and moved dataSources_new to dataSources. Is there a reason you would try this?
                  If there isn't data that matters, I would fix it by exporting your configuration, going into the mysql command line, creating a database "mango2" and redirecting the connection string in your env.properties to this new database, and then importing your configuration again after Mango boots.
                  If there is data that matters, you can update the foreign key constraints to reference the right table (grumble grumble) by running some SQL:
                  ALTER TABLE dataPoints DROP FOREIGN KEY dataPointsFk1;
                  ALTER TABLE dataPoints ADD CONSTRAINT dataPointsFk1 FOREIGN KEY (dataSourceId) REFERENCES dataSources(id);
                    MaP
                    Hi Phil,
                    I just imported another sites data sources config into the mango and did a find replace to ensure unique XIDs. I was pretty sure this was a brand-new mango but I cant be sure that it hasnt been toyed with.
                    Is there a way to do a factory reset and clear all previous data/config from a mango?
                      MaP
                      Hi Phil,
                      I entered the SQL queries listed in your last post and received the following errors:
                      0_1477887143953_upload-96a5675c-75e6-4842-b086-afb6f1c0c9b5
                        MaP
                        0_1477893574186_upload-b2dd7f5b-b362-4810-bbd4-fb23d33e5c86
                          That's okay, the foreign key was the bigger problem. I'm going to remove the index recommendation from that post. But, it also looks like you're using the H2 web console now, but from your SQL error I think you're using MySQL? If so, running those commands in the H2 console won't help, you would have to run them in your MySQL database.
                          Using H2, you can cause a new Mango instance by renaming your Mango/databases directory while Mango is off. if using MySQL, you should create another database via CREATE DATABASE newMangoDatabaseName and then modify the connection string to point to this database. You would also need to rename the Mango/databases directory to set the old data aside, if you are using the NoSQL module.
                            MaP
                            0_1477982343865_upload-3db30b84-56f7-49c9-b436-daffa43837ce
                            Do you mean using the inbuilt SQL console on the Mango web interface to try the queries in the previous post?
                            0_1477982415138_upload-e76d2fba-dc92-4922-85a5-98e90ae41e3c
                              The error you posted relating to dataSources_old is a com.mysql.jdbc.exceptions.jdbc4.MySQLIntegrityConstraintViolationException so I'm pretty certain you were using MySQL. Is there a chance you overwrote your env.properties file?
                                MaP
                                I dont think so -
                                #    Copyright (C) 2014 Infinite Automation Systems Inc. All rights reserved.
                                #    @author Matthew Lohbihler
                                # TO OVERRIDE VALUES IN THIS FILE...
                                # Do not change the values in this file, because when you upgrade your core
                                # your changes will be overwritten. Instead, create a new file called
                                # <MA_HOME>/overrides/properties/env.properties and override properties
                                # there. The overrides directory will never be overwritten by an upgrade, so
                                # your customizations will be safe.
                                # The port at which Mango Automation will listen for browser connections
                                web.port=80
                                # The host interface to which Mango Automation will bind and listen for new connections
                                #  0.0.0.0 is the special interface that will force a bind to all available interfaces
                                web.host=0.0.0.0
                                # Should Mango Automation open (if possible) a browser window when it starts up?
                                web.openBrowserOnStartup=true
                                # Default database settings, NOTE that on windows this must be an absolute path
                                db.type=h2
                                db.url=jdbc:h2:${ma.home}/databases/mah2
                                db.location=${ma.home}/databases/mah2
                                db.port=8081
                                db.username=
                                db.password=
                                #For web console
                                db.web.start=false
                                db.web.port=8091
                                #db.type=derby
                                #db.url=${ma.home}/databases/madb
                                #db.username=
                                #db.password=
                                #General Database Settings
                                db.pool.maxActive=100
                                db.pool.maxIdle=10
                                db.update.log.dir=${ma.home}/logs/
                                # setting to show query times in the logs as INFO
                                db.useMetrics=false
                                # MySQL database settings. Your MySQL instance must already be running and configured before this can be used.
                                #db.type=mysql
                                #db.url=jdbc:mysql://localhost/<your mysql schema name>
                                #db.username=<your mysql username>
                                #db.password=<your mysql password>
                                # Database settings for conversion. If the db.* settings point to a new database instance, and the convert type setting
                                # is set, Mango Automation will attempt to convert from the convert.db.* settings to the db.* settings
                                # Note that database conversions should not be performed in the same step as an upgrade. First upgrade, then convert.
                                convert.db.type=
                                convert.db.url=${convert.db.url}
                                convert.db.username=${convert.db.username}
                                convert.db.password=${convert.db.password}
                                # The location of the Mango Automation store from which to get license files.
                                store.url=http://store.infiniteautomation.com
                                # SSL control
                                ssl.on=false
                                ssl.port=8443
                                ssl.keystore.location=/location/to/keystore/file.jks
                                ssl.keystore.password=freetextpassword
                                # System time zone. Leave blank to use default VM time zone.
                                timezone=
                                #Rest API Configuration
                                rest.enabled=true
                                #For using other than timestamp
                                rest.customDateOutputFormat=YYYY-MM-dd HH:mm:ss.SSS Z
                                rest.customDateInputFormat=YYYY-MM-dd HH:mm:ss.SSS Z
                                #For rest API Documentation at /swagger/index.html
                                swagger.enabled=false
                                swagger.mangoApiVersion=v1
                                #Distributor Settings
                                distributor=IA
                                #Jetty Thread Pool Tuning
                                web.threads.msIdleTimeout=10000
                                web.threads.minimum=10
                                web.threads.maximum=200
                                web.websocket.pingTimeoutMs=10000
                                #Jetty JSP Configuration
                                # See here for options: http://www.eclipse.org/jetty/documentation/9.2.10.v20150310/configuring-jsp.html
                                web.jsp.development=true
                                web.jsp.genStringsAsCharArray=true
                                web.jsp.trimSpaces=false
                                web.jsp.classdebuginfo=false
                                web.jsp.supressSmap=true
                                web.jsp.compilerClassName=org.apache.jasper.compiler.JDTCompiler
                                web.jsp.compiler=modern
                                web.jsp.fork=false
                                web.jsp.keepgenerated=true
                                #Regex used to match serial ports so they show up in the menu
                                serial.port.linux.regex=((ttymUSB)[0-9]{1,3}|rs(485)-[0-9])
                                serial.port.linux.path=/dev/
                                serial.port.windows.regex=
                                serial.port.windows.path=
                                serial.port.osx.path=/dev/
                                serial.port.osx.regex=(cu|tty)..*
                                  MaP
                                  The persistent TCP receiver is using MySQL while the local mango is using H2 i believe. Will this cause the issue?
                                    No, the TCP receiver will be using the database of the instance it is running on, and the database of the receiver and the publisher do not need to be the same. Have you been re-evaluating if your problem was solved? We have covered multiple paths to resolution, for each database.
                                    If your receiver is the one with the SQL error, and it is on MySQL, that is where i was advising to fix the foreign key problem.
                                      MaP
                                      I recently raised a support ticket for this - please disregard the Support Ticket - we applied this fix to the enterprise mango and the problem seems to have gone .
                                      We also applied this to the maintenance events table. I think during our upgrade from H2 -> MySQL this problem occurred.
                                      Thankyou for your help and suggestions for getting this problem fixed.
                                      0_1478659845558_upload-02d5adf1-a389-4a50-b27e-af25a2de1a95
