    28 Posts 3 Posters 36.3k Views 3 Watching
    • V Offline
      v8dave
      Hi Phil, I am using a numerical data point. Here is the screen capture. I modified the script as I only need to detect a falling trend.!!
        it looks like you are using the scripting data source, instead of a meta data source and putting these scripting in a meta data point.
        Scripts are intended for a multiple-output control loop. Scripting data source scripts don't contain return statements, they set a point's value with p.set(value, time) or just p.set(value) for the current time.
        This kind of thing, where we're producing a single answer from perhaps multiple inputs, should be a meta point.
        • V Offline
          v8dave
          Ah yes, so I was. Just trying it now but there is an error about a null value on line 4 which seems strange because it would not get to this line unless there was data.
             return false;
          var firstValue = data[0];
              return true;
          return false;
            That is odd....
            I would put print(data) at line 2 to investigate.
            • V Offline
              v8dave
              I've added that but where do I see the output from this?
                It would be below the script window, if it ran, where you saw the error. If it didn't, I wonder if you have a global script declared? The global scripts page is this icon: 0_1469746987325_script-globe.png
                • V Offline
                  v8dave
                  I don't have that icon. Is this a module I need to install or a setting somewhere?
                  • V Offline
                    v8dave
                    I found the module and installed it and the icon is now present. My scripts still don't seem the be running as there is no output from the print(data) statement.
                      No, I was curious if that's where the error was occurring, not telling you that you needed to install it.
                      Do you get the same error from a very simple script, perhaps just...
                      return false;
                      Are you sure your point is in the context as bbl1 (b - b - lower case L - numeral 1)?
                      • V Offline
                        v8dave
                          print("bbl1:");
                          print(bbl1);
                          print("data:");
                          print(data);
                             return false;
                              return true;
                          return false;
                          • V Offline
                            v8dave
                              return false;
                              • V Offline
                                v8dave
                                Looking at the log file, it is still failing at this line.
                                ERROR 2016-07-29 07:39:00,004 (com.serotonin.m2m2.meta.JavaScriptPointLocatorRT.executeImpl:54) - sun.org.mozilla.javascript.EvaluatorException: Java class "java.util.ArrayList" has no public instance field or method named "0". (<Unknown Source>#9) in <Unknown Source> at line number 9 in <Unknown Source> at line number 9
                                I export and send you the file.
                                  It works fine for me, so, I wonder if it's a Java version issue.
                                  Judging from that error message, I would try using data.get(0) instead of data[0]
                                  Can you run "java -version" on the command line and report the result?
                                  • V Offline
                                    v8dave
                                    It's running on a Centos system and the "java -version" command gives me this error.
                                    Error occurred during initialization of VM
                                    Could not reserve enough space for object heap
                                    Error: Could not create the Java Virtual Machine.
                                    Error: A fatal exception has occurred. Program will exit.
                                    I have Mango running as a service on this machine. Java is install and running otherwise Mango won't run.
                                    • V Offline
                                      v8dave
                                      With .get(0) I get this error.
                                      ERROR 2016-07-29 08:13:13,576 (com.serotonin.m2m2.meta.JavaScriptPointLocatorRT.executeImpl:54) - sun.org.mozilla.javascript.EcmaError: TypeError: Cannot find function get in object {minimumValue: 99.05402923333332, minimumTime: 1469804893540, maximumValue: 99.568, maximumTime: 1469805193538, average: 99.15065249671122, sum: 397.38296884523055, count: 4, delta: 0.5139707666666737, integral: 29745.195749013365, firstValue: 99.05402923333332, firstTime: 1469805036550, lastValue: 99.568, lastTime: 1469805193538, periodStartTime: 1469804893540, periodEndTime: 1469805193540}. (<Unknown Source>#9) in <Unknown Source> at line number 9 in <Unknown Source> at line number 9
                                      javax.script.ScriptException: sun.org.mozilla.javascript.EcmaError: TypeError: Cannot find function get in object {minimumValue: 99.05402923333332, minimumTime: 1469804893540, maximumValue: 99.568, maximumTime: 1469805193538, average: 99.15065249671122, sum: 397.38296884523055, count: 4, delta: 0.5139707666666737, integral: 29745.195749013365, firstValue: 99.05402923333332, firstTime: 1469805036550, lastValue: 99.568, lastTime: 1469805193538, periodStartTime: 1469804893540, periodEndTime: 1469805193540}. (<Unknown Source>#9) in <Unknown Source> at line number 9 in <Unknown Source> at line number 9
                                        Dave,
                                        That last post shows that you are using the statistics method to get the data. I'll just ignore that and focus on the first problems you were having. You are expecting the method:
                                        bbl1.pointValuesSince()
                                        to return an Array, but it actually returns a Java style ArrayList. The difference is that ArrayLists have a method called size() instead of the member length and accessing the values is done via get(index).
                                        So here is an updated version of your script to run using an array list instead of an array:
                                        if( data.size() <= 1 ) //we have the same edge conditions for our range
                                           return false;
                                        var firstValue = data.get(0);
                                        for( var k = 1; k < data.size(); k+=1 ) {
                                          if( firstValue.value - data.get(k).value < changeThreshhold)
                                            return true;
                                        return false;
                                        Hope this helps.
                                          Thanks Terry!
                                          Terry's code will work on Java 7 and 8. I guess I've mostly been interacting with Java 8... mine only works on Java 8's JavaScript engine. So, you can convert .length to .size() as per Terry's suggestion and use get() instead of square brackets []. I will try to be more conscious of this in the future when contributing example code snippets.
                                          Sorry for the confusion!
                                          • V Offline
                                            v8dave
                                            No worries Phil, without this interaction you would not have known this so in the end we both benefit from the exchange of data.
                                            I am slowly learning Mango and it's pretty impressive what you can do with it. Your only downside of the whole system is the lack of really good documentation on things like the scripting etc. Other than this, with the support on the forum it makes up for this until such time as you have the documentation done.
                                            Thanks Terry, That seems to work this time. There are no errors appearing in the log file now. I just need to wait for the sensor to change and then hopefully I can detect the change.
