    28 Posts 3 Posters 36.3k Views 3 Watching
    • V Offline
      v8dave
      I don't have that icon. Is this a module I need to install or a setting somewhere?
      • V Offline
        v8dave
        I found the module and installed it and the icon is now present. My scripts still don't seem the be running as there is no output from the print(data) statement.
          No, I was curious if that's where the error was occurring, not telling you that you needed to install it.
          Do you get the same error from a very simple script, perhaps just...
          return false;
          Are you sure your point is in the context as bbl1 (b - b - lower case L - numeral 1)?
          • V Offline
            v8dave
              print("bbl1:");
              print(bbl1);
              print("data:");
              print(data);
                 return false;
              var firstValue = data[0];
                  return true;
              return false;
              • V Offline
                v8dave
                  return false;
                  • V Offline
                    v8dave
                    Looking at the log file, it is still failing at this line.
                    ERROR 2016-07-29 07:39:00,004 (com.serotonin.m2m2.meta.JavaScriptPointLocatorRT.executeImpl:54) - sun.org.mozilla.javascript.EvaluatorException: Java class "java.util.ArrayList" has no public instance field or method named "0". (<Unknown Source>#9) in <Unknown Source> at line number 9 in <Unknown Source> at line number 9
                    I export and send you the file.
                      It works fine for me, so, I wonder if it's a Java version issue.
                      Judging from that error message, I would try using data.get(0) instead of data[0]
                      Can you run "java -version" on the command line and report the result?
                      • V Offline
                        v8dave
                        It's running on a Centos system and the "java -version" command gives me this error.
                        Error occurred during initialization of VM
                        Could not reserve enough space for object heap
                        Error: Could not create the Java Virtual Machine.
                        Error: A fatal exception has occurred. Program will exit.
                        I have Mango running as a service on this machine. Java is install and running otherwise Mango won't run.
                        • V Offline
                          v8dave
                          With .get(0) I get this error.
                          ERROR 2016-07-29 08:13:13,576 (com.serotonin.m2m2.meta.JavaScriptPointLocatorRT.executeImpl:54) - sun.org.mozilla.javascript.EcmaError: TypeError: Cannot find function get in object {minimumValue: 99.05402923333332, minimumTime: 1469804893540, maximumValue: 99.568, maximumTime: 1469805193538, average: 99.15065249671122, sum: 397.38296884523055, count: 4, delta: 0.5139707666666737, integral: 29745.195749013365, firstValue: 99.05402923333332, firstTime: 1469805036550, lastValue: 99.568, lastTime: 1469805193538, periodStartTime: 1469804893540, periodEndTime: 1469805193540}. (<Unknown Source>#9) in <Unknown Source> at line number 9 in <Unknown Source> at line number 9
                          javax.script.ScriptException: sun.org.mozilla.javascript.EcmaError: TypeError: Cannot find function get in object {minimumValue: 99.05402923333332, minimumTime: 1469804893540, maximumValue: 99.568, maximumTime: 1469805193538, average: 99.15065249671122, sum: 397.38296884523055, count: 4, delta: 0.5139707666666737, integral: 29745.195749013365, firstValue: 99.05402923333332, firstTime: 1469805036550, lastValue: 99.568, lastTime: 1469805193538, periodStartTime: 1469804893540, periodEndTime: 1469805193540}. (<Unknown Source>#9) in <Unknown Source> at line number 9 in <Unknown Source> at line number 9
                            Dave,
                            That last post shows that you are using the statistics method to get the data. I'll just ignore that and focus on the first problems you were having. You are expecting the method:
                            bbl1.pointValuesSince()
                            to return an Array, but it actually returns a Java style ArrayList. The difference is that ArrayLists have a method called size() instead of the member length and accessing the values is done via get(index).
                            So here is an updated version of your script to run using an array list instead of an array:
                            if( data.size() <= 1 ) //we have the same edge conditions for our range
                               return false;
                            var firstValue = data.get(0);
                            for( var k = 1; k < data.size(); k+=1 ) {
                              if( firstValue.value - data.get(k).value < changeThreshhold)
                                return true;
                            return false;
                            Hope this helps.
                              Thanks Terry!
                              Terry's code will work on Java 7 and 8. I guess I've mostly been interacting with Java 8... mine only works on Java 8's JavaScript engine. So, you can convert .length to .size() as per Terry's suggestion and use get() instead of square brackets []. I will try to be more conscious of this in the future when contributing example code snippets.
                              Sorry for the confusion!
                              • V Offline
                                v8dave
                                No worries Phil, without this interaction you would not have known this so in the end we both benefit from the exchange of data.
                                I am slowly learning Mango and it's pretty impressive what you can do with it. Your only downside of the whole system is the lack of really good documentation on things like the scripting etc. Other than this, with the support on the forum it makes up for this until such time as you have the documentation done.
                                Thanks Terry, That seems to work this time. There are no errors appearing in the log file now. I just need to wait for the sensor to change and then hopefully I can detect the change.
                                  Very true. The community definitely makes me take a closer look at many things, which I enjoy.
                                  Virtual points can be useful to check if your meta point is behaving as you expect.
                                  The blue help icon (?) in sections with scripts has a 'related item' called 'Mango JavaScript' that documents the functions a data point has. Examples are definitely spread around the forum as well. There's a whole section called 'Scripting general discussion'
