    28 Posts 3 Posters 36.3k Views 3 Watching
    • V Offline
      v8dave
      Thanks Phil, once I figure out where the meta script is input I'll give this a go. I have the module loaded but can't see where to input this script. :)
      • V Offline
        v8dave
        OK. I found how to create a meta script. It's actually a data source. I'll give your code a try out. Thanks again.
          Data will be coming from it, won't it? :D
          A solution some people use for noisy data, to avoid what I was talking about, is to just use averages from time periods to compare instead of raw data, so,
          var period = 300000 //5*60*1000 Five minutes
          var now = new Date();
          var start = now.getTime() - period;
          var middle = now.getTime() - period/2;
          if( Math.abs( p.getStats(middle, now).average - p.getStats(start, middle).average ) > 5 ) //Threshhold
            return true;
          return false;
          Depending on your needs or thoughts on your data.
          • V Offline
            v8dave
            Just trying this now and when I input the script and then click save, I get this error at the bottom.
            invalid return
            at line -1
            I've selected a suitable data point and set its name to p for this test.
              Are you using the scripts as posted or as they arrived in an email notification?
              I am able to run all of these with a numeric point for p. That looks like a syntax error, which I think I would get regardless of the code path.
              • V Offline
                v8dave
                Hi Phil, I am using a numerical data point. Here is the screen capture. I modified the script as I only need to detect a falling trend.!!
                  it looks like you are using the scripting data source, instead of a meta data source and putting these scripting in a meta data point.
                  Scripts are intended for a multiple-output control loop. Scripting data source scripts don't contain return statements, they set a point's value with p.set(value, time) or just p.set(value) for the current time.
                  This kind of thing, where we're producing a single answer from perhaps multiple inputs, should be a meta point.
                  • V Offline
                    v8dave
                    Ah yes, so I was. Just trying it now but there is an error about a null value on line 4 which seems strange because it would not get to this line unless there was data.
                       return false;
                    var firstValue = data[0];
                        return true;
                    return false;
                      That is odd....
                      I would put print(data) at line 2 to investigate.
                      • V Offline
                        v8dave
                        I've added that but where do I see the output from this?
                          It would be below the script window, if it ran, where you saw the error. If it didn't, I wonder if you have a global script declared? The global scripts page is this icon: 0_1469746987325_script-globe.png
                          • V Offline
                            v8dave
                            I don't have that icon. Is this a module I need to install or a setting somewhere?
                            • V Offline
                              v8dave
                              I found the module and installed it and the icon is now present. My scripts still don't seem the be running as there is no output from the print(data) statement.
                                No, I was curious if that's where the error was occurring, not telling you that you needed to install it.
                                Do you get the same error from a very simple script, perhaps just...
                                return false;
                                Are you sure your point is in the context as bbl1 (b - b - lower case L - numeral 1)?
                                • V Offline
                                  v8dave
                                    print("bbl1:");
                                    print(bbl1);
                                    print("data:");
                                    print(data);
                                       return false;
                                        return true;
                                    return false;
                                    • V Offline
                                      v8dave
                                        return false;
                                        • V Offline
                                          v8dave
                                          Looking at the log file, it is still failing at this line.
                                          ERROR 2016-07-29 07:39:00,004 (com.serotonin.m2m2.meta.JavaScriptPointLocatorRT.executeImpl:54) - sun.org.mozilla.javascript.EvaluatorException: Java class "java.util.ArrayList" has no public instance field or method named "0". (<Unknown Source>#9) in <Unknown Source> at line number 9 in <Unknown Source> at line number 9
                                          I export and send you the file.
                                            It works fine for me, so, I wonder if it's a Java version issue.
                                            Judging from that error message, I would try using data.get(0) instead of data[0]
                                            Can you run "java -version" on the command line and report the result?
