    Point value crossed out in red
    16 Posts 3 Posters 8.3k Views 3 Watching
      mihairosu
      Mango Core version 4.4.3
      Mango API module version 4.4
      Mango UI module version 4.4
      Your platform and version Windows 10
      Your browser and version Chrome Version 109.0.5414.120 (Official Build) (64-bit)
      I'm beginning to build a new dashboard and I can't seem to get a point value to display. It shows as follows:
      These data points are coming in via Persistent Sync from a mangoGT running Mango OS v3. and far as I can tell, it is receiving data, but I could be wrong.
      I am just getting used to v4 and it's a bit of a learning curve. I normally would use the watchlists to see if data is coming in, but none of the watchlist data has any values in the Value column (I submitted a ticket for this separately) so maybe it's related.
      However when I check data point details, I can see data and the persistent publisher is showing that it is sending data, as far as I can see.
      • CraigWebC Offline
        CraigWeb
        @mihairosu There are 2 reasons for those diagonal lines, either the point is disabled or you are losing connection to the Mango API which is what I suspect Since the watchlists are not working either. Can you open your browser console and see if there are any console errors and also look if there are any network requests that are failing?
        Are you browsing from the same windows PC that you are hosting on?
          mihairosu @CraigWeb
          @CraigWeb
          Okay I figured out the "problem". Thanks for the guidance. I am accessing the GUI through HAProxy. If I use the direct IP address, there is no issue.
          I would like to use HTTPS/SSL, ideally through HAProxy (running on pfsense) since I'm using that for most everything else.
          Is there a way to get it to work through some sort of advanced settings?
          Else, I will just have to resort to certbot.
            mihairosu @mihairosu
            @mihairosu
            I did find these instructions, but they're for Apache. I'm not sure how to do the same thing in pfSense's HAProxy configs.
            • CraigWebC Offline
              CraigWeb @mihairosu
              @mihairosu I am not familiar with that proxy and I have seen many people struggle with similar firewalls. You will need to reach out to their support and ask how the proxy can be configured to allow WebSocket upgrades. All points value and event updates use WebSockets, most proxies do not allow this by default and it needs to be explicitly allowed.
              Here are the instructions to get SSL enabled but I can see this is going to be quite a struggle with that firewall, I can assist on the mango side but won't be able to help much with that Proxy.
              https://docs-v3.mango-os.com/ssl
                mihairosu @CraigWeb
                @CraigWeb
                Got it, thanks Craig.
                In this case, there's no issues on the Mango side, so I'll see what I can figure out and how to proceed.
                  MattFox @mihairosu
                  @mihairosu I'd argue that since you need a web server to host an ssl cert, use pfsense and port forward to the mango box instead. Use nginx as it offers better support for reverse proxy headers and websockets. Much simpler and allows you to have nginx automate the ssl certs to keep everything up to date.
                    mihairosu @MattFox
                    @MattFox
                    Do you have an nginx configuration you can share?
                    The documentation shows an example for apache, but not nginx.
                    • CraigWebC Offline
                      CraigWeb
                      @mihairosu nginx is by far the most popular however we have internally settled on using Caddy https://caddyserver.com/
                      which does everything @MattFox described, auto SSL renewal from LetsEncrypt ect. The only reason I mention this is that I would be able to support you on caddy.
                        MattFox @mihairosu
                        @mihairosu sure, give me a moment
                          MattFox @MattFox
                          @mihairosu https://forum.mango-os.com/topic/5616/use-nginx-with-mango-as-an-ssl-reverse-proxy
                            mihairosu @MattFox
                            @MattFox
                            Then you for the instructions, but I ran into a problem.
                            simply running certbot --nginx assumed it can do a challenge over port 80, i.e. mango os ip is publicly exposed, which ours is not, and that will fail.
                            We need do a dns challenge (cloudflare), which would look like this:
                            certonly --nginx --dns-cloudflare --dns-cloudflare-credentials /loc/to/cloudflare-api-token.ini -d mangoos.com
                            But running that will give a different error:
                            Too many flags setting configurators/installers/authenticators 'nginx' -> 'dns-cloudflare'
                            I haven't figured out to do either of these things:
                            1. Convert your HTTP nginx config to https
                            2. Figure out how to use the certbot --nginx with cloudflare dns challenge
                            When I figure it out I'll post here, but if you have any tips for either of those I would much appreciate it!
                            P.S. I do have the LetsEncrypt certificates on the system for step 1.
                              @mihairosu
                              After running certbot, it created the certificate and key in the /etc/letsencrypt/live/fqdn.com/ directory, I was able to get it to work with the following nginx configuration:
                              server {
                              listen 443 ssl;
                              server_name fqdn.com;
                              root /opt/mango/overrides/web/;
                              index index.html;
                              ssl_certificate /etc/letsencrypt/live/fqdn.com/fullchain.pem;
                              ssl_certificate_key /etc/letsencrypt/live/fqdn.com/privkey.pem;
                              include /etc/letsencrypt/options-ssl-nginx.conf;
                              location / {
                              proxy_pass http://127.0.0.1:8080/;
                              proxy_http_version 1.1;
                              # Inform Mango about the real host, port and protocol
                              proxy_set_header X-Forwarded-Host $host:$server_port;
                              proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
                              proxy_set_header X-Forwarded-Proto $scheme;
                              proxy_set_header Upgrade $http_upgrade;
                              proxy_set_header Connection "upgrade";
                              MattFoxM 1 Reply Last reply Reply Quote 1
                                MattFox @mihairosu
                                @mihairosu nicely done! If desired save the successful ssh call you made into a bash script followed by a sudo service nginx restart
                                You can then routinely call this once a month to keep your certs always up to date via cron.monthly or using crontab itself.
                                  mihairosu @MattFox
                                  @MattFox
                                  Based on the installation instructions for certbot on Ubuntu here, it looks like it should have automatically installed a renew job.
                                  I found it in systemctl list-timers
                                  Wed 2023-02-15 21:42:00 CST 1h 56min left n/a                         n/a          snap.certbot.renew.timer       snap.certbot.renew.service
                                  So I assume I should be good, but thanks for the heads up.
                                    MattFox @mihairosu
                                    @mihairosu good, it doesn't for the mango units so I'm glad everything is resolved.
