    New installation strange errors
    24 Posts 4 Posters 22.2k Views 4 Watching
    • danD Offline
      dan
      Hi Guys, have installed a fresh installation of Mango on an Ubuntu box, and I'm getting some strange errors in the Java console...
      DevTools failed to load SourceMap: Could not load content for http://10.40.0.200:8080/resources/dijit/form/Form.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
      DevTools failed to load SourceMap: Could not load content for http://10.40.0.200:8080/resources/dijit/_base.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
      DevTools failed to load SourceMap: Could not load content for http://10.40.0.200:8080/resources/dijit/WidgetSet.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
      DevTools failed to load SourceMap: Could not load content for http://10.40.0.200:8080/resources/dijit/_base/focus.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
      DevTools failed to load SourceMap: Could not load content for http://10.40.0.200:8080/resources/dijit/selection.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
      DevTools failed to load SourceMap: Could not load content for http://10.40.0.200:8080/resources/dijit/_base/place.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
      DevTools failed to load SourceMap: Could not load content for http://10.40.0.200:8080/resources/dijit/_base/popup.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
      DevTools failed to load SourceMap: Could not load content for http://10.40.0.200:8080/resources/dijit/_base/scroll.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
      DevTools failed to load SourceMap: Could not load content for http://10.40.0.200:8080/resources/dijit/_base/sniff.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
      DevTools failed to load SourceMap: Could not load content for http://10.40.0.200:8080/resources/dijit/_base/typematic.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
      DevTools failed to load SourceMap: Could not load content for http://10.40.0.200:8080/resources/dijit/typematic.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
      DevTools failed to load SourceMap: Could not load content for http://10.40.0.200:8080/resources/dijit/TooltipDialog.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
      DevTools failed to load SourceMap: Could not load content for http://10.40.0.200:8080/resources/dijit/_base/wai.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
      DevTools failed to load SourceMap: Could not load content for http://10.40.0.200:8080/resources/dijit/_base/window.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
      DevTools failed to load SourceMap: Could not load content for http://10.40.0.200:8080/resources/dojo/fx/Toggler.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
      DevTools failed to load SourceMap: Could not load content for http://10.40.0.200:8080/resources/dijit/form/DropDownButton.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
      DevTools failed to load SourceMap: Could not load content for http://10.40.0.200:8080/resources/dijit/form/ComboButton.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
      Would this be related to Java version? Or something missing from the installation? Or maybe permissions?
      ~$ java --version
      openjdk 14.0.2 2020-07-14
      OpenJDK Runtime Environment (build 14.0.2+12-Ubuntu-120.04)
      OpenJDK 64-Bit Server VM (build 14.0.2+12-Ubuntu-120.04, mixed mode, sharing)
      Cheers
      Dan
      • cwangvC Offline
        cwangv @dan
        @dan
        have you tried installing it using the mango script? I assume the Java is the one that Mango wants. I find it much easier using the script.
        • danD Offline
          dan
          I think I used the script on this one, sorry can't recall.
          It seems to be a path issue, it's like it can't find the resources folder?
          • cwangvC Offline
            cwangv @dan
            @dan
            My suggestion will be to follow the instructions down to the 'T' with the same user name as mentioned on their website. I am not that experienced with linux that is how I have done it.
            • danD Offline
              dan
              Yep all good, I think I did that.
              • cwangvC Offline
                cwangv
                here is my jdk. I wonder why your is newer version but with older date
                openjdk version "11.0.9.1" 2020-11-04
                OpenJDK Runtime Environment (build 11.0.9.1+1-post-Debian-1deb10u2)
                OpenJDK 64-Bit Server VM (build 11.0.9.1+1-post-Debian-1deb10u2, mixed mode, sharing)
                • danD Offline
                  dan
                  Interesting, might be the date it was installed maybe.
                  I might try another version.
                    I use version 14, I advise doing a manual install also.
                    • danD Offline
                      dan
                      Hey Matt, I am back running latest openjdk 14.0.2 2020-07-14.
                      I went back to my notes from the install and it looks like I installed manually, I'll try reinstalling I think.
                      Cheers
                        Before you do, echo $JAVA_HOME and the like
                        • danD Offline
                          dan
                          root@water:/opt# echo $JAVA_HOME
                          /usr/bin
                          root@water:/opt# /usr/bin/java --version
                          root@water:/opt# echo $MA_HOME
                          /opt/mango
                          root@water:/opt#
                            Yep, looks like mango error. Definitely try a reinstall. May pay to check filesystem permissions on your mango directory also..
                            Good Luck Dan
                            • danD Offline
                              dan
                              Yeh tried that ;)
                              Weird.
                              /opt/mango is all owned by mango:mango
                                You did a sudo chown mango:mango /opt/mango -R ?
                                Since that issue looks like a read error to me..
                                Best ensure files are all chmod 644 as well.. with the exception of the scripts in the bin folder..
                                Sorry thats all that comes to mind at this time
                                • danD Offline
                                  dan
                                  Yeh pretty much...
                                  chown -R mango:mango /opt/mango
                                  Obviously does the same thing :P
                                    Yep, sorry running on fumes tonight, thats the best I have got.
                                    • danD Offline
                                      dan
                                      Haha all good mate, thanks for that. I'll see what else I can pick up outta the logs.
                                      Cheers
                                      • CraigWebC Offline
                                        CraigWeb
                                        @dan said in New installation strange errors:
                                        What version of mango is this?
                                        Can you have a look in your /opt/mango/web/resources folder if all the permissions are good there and if the directory has any content?
                                        • danD Offline
                                          dan
                                          Hi Craig, it's version 3.7.7 straight off the store.
                                          dijit directory has 428 files
                                          root@water:/opt/mango/web/resources/dijit# ls -la
                                          total 428
                                          drwxr-xr-x 12 mango mango  4096 Jan 27 17:02 .
                                          drwxr-xr-x 30 mango mango  4096 Jan 27 17:02 ..
                                          -rw-r--r--  1 mango mango  1554 Jan 27 17:02 BackgroundIframe.js
                                          -rw-r--r--  1 mango mango  4230 Jan 27 17:02 Calendar.js
                                          -rw-r--r--  1 mango mango  9146 Jan 27 17:02 CalendarLite.js
                                          -rw-r--r--  1 mango mango  1581 Jan 27 17:02 CheckedMenuItem.js
                                          All files are owned by mango
                                          'mango' seems to be running mango process...
                                          root@water:/opt/mango/web/resources/dijit# ps -aux |grep mango
                                          mango       6354  1.5  4.3 8058288 700864 ?      Sl   Apr16  13:44 java -server -Dma.home=/opt/mango com.serotonin.m2m2.Main
                                          I've never had this issue before on a clean install, it's very odd.
                                          • danD Offline
                                            dan
                                            I think I've found the issue.
                                            I went to the new GUI and it suggested there were updates to be installed, and it listed a heap of the standard modules, So I selected them for install and after restarting it all looked normal again.
                                            Very strange.
