    New installation strange errors
    24 Posts 4 Posters 23.2k Views 4 Watching
    • danD Offline
      dan
      root@water:/opt# echo $JAVA_HOME
      /usr/bin
      root@water:/opt# /usr/bin/java --version
      openjdk 14.0.2 2020-07-14
      OpenJDK Runtime Environment (build 14.0.2+12-Ubuntu-120.04)
      OpenJDK 64-Bit Server VM (build 14.0.2+12-Ubuntu-120.04, mixed mode, sharing)
      root@water:/opt# echo $MA_HOME
      /opt/mango
      root@water:/opt#
        Yep, looks like mango error. Definitely try a reinstall. May pay to check filesystem permissions on your mango directory also..
        Good Luck Dan
        • danD Offline
          dan
          Yeh tried that ;)
          Weird.
          /opt/mango is all owned by mango:mango
            You did a sudo chown mango:mango /opt/mango -R ?
            Since that issue looks like a read error to me..
            Best ensure files are all chmod 644 as well.. with the exception of the scripts in the bin folder..
            Sorry thats all that comes to mind at this time
            • danD Offline
              dan
              Yeh pretty much...
              chown -R mango:mango /opt/mango
              Obviously does the same thing :P
                Yep, sorry running on fumes tonight, thats the best I have got.
                • danD Offline
                  dan
                  Haha all good mate, thanks for that. I'll see what else I can pick up outta the logs.
                    @dan said in New installation strange errors:
                    /dijit/form/Form.js.map
                    What version of mango is this?
                    Can you have a look in your /opt/mango/web/resources folder if all the permissions are good there and if the directory has any content?
                    • danD Offline
                      dan
                      Hi Craig, it's version 3.7.7 straight off the store.
                      dijit directory has 428 files
                      root@water:/opt/mango/web/resources/dijit# ls -la
                      total 428
                      drwxr-xr-x 12 mango mango  4096 Jan 27 17:02 .
                      drwxr-xr-x 30 mango mango  4096 Jan 27 17:02 ..
                      -rw-r--r--  1 mango mango  1554 Jan 27 17:02 BackgroundIframe.js
                      -rw-r--r--  1 mango mango  4230 Jan 27 17:02 Calendar.js
                      -rw-r--r--  1 mango mango  9146 Jan 27 17:02 CalendarLite.js
                      -rw-r--r--  1 mango mango  1581 Jan 27 17:02 CheckedMenuItem.js
                      All files are owned by mango
                      'mango' seems to be running mango process...
                      root@water:/opt/mango/web/resources/dijit# ps -aux |grep mango
                      mango       6354  1.5  4.3 8058288 700864 ?      Sl   Apr16  13:44 java -server -Dma.home=/opt/mango com.serotonin.m2m2.Main
                      I've never had this issue before on a clean install, it's very odd.
                      • danD Offline
                        dan
                        I think I've found the issue.
                        I went to the new GUI and it suggested there were updates to be installed, and it listed a heap of the standard modules, So I selected them for install and after restarting it all looked normal again.
                        Very strange.
                        • danD Offline
                          dan
                          Something still not quite right...
                          Getting all these random error messages in the logs and the GUI isn't loading sometimes. This could possibly be due to the system being on the end of a satellite link, however I have another similar system on another satellite link and it isn't having the same issues.
                          I tried building the same view in the new UI but I can't seem to make it look as simple for the customer, the built-in tank level indicators are too large in the new UI.
                          This is all they want to see at their end..
                          I can't make much sense of the log entries.
                          ERROR 2021-04-19T06:52:37,817 (com.serotonin.m2m2.web.dwr.util.ExceptionDetectionFilter.doFilter:38) - DWR invocation exception
                          java.lang.NullPointerException: null
                                  at com.serotonin.m2m2.gviews.GraphicalViewDwr.getViewPointData(GraphicalViewDwr.java:118) ~[?:?]
                                  at com.serotonin.m2m2.gviews.GraphicalViewDwr.getViewPointData(GraphicalViewDwr.java:109) ~[?:?]
                                  at com.serotonin.m2m2.gviews.GraphicalViewLongPollDefinition.handleLongPoll(GraphicalViewLongPollDefinition.java:53) ~[?:?]
                                  at com.serotonin.m2m2.web.dwr.BaseDwr.doLongPoll(BaseDwr.java:641) ~[mango-3.7.7.jar:?]
                                  at com.serotonin.m2m2.web.dwr.BaseDwr.initializeLongPoll(BaseDwr.java:422) ~[mango-3.7.7.jar:?]
                                  at jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]
                                  at jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
                                  at jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:?]
                                  at java.lang.reflect.Method.invoke(Method.java:564) ~[?:?]
                                  at org.directwebremoting.impl.ExecuteAjaxFilter.doFilter(ExecuteAjaxFilter.java:34) ~[dwr-2.0.11.jar:?]
                                  at org.directwebremoting.impl.DefaultRemoter$1.doFilter(DefaultRemoter.java:428) ~[dwr-2.0.11.jar:?]
                                  at com.serotonin.m2m2.web.dwr.util.TranslationsFilter.doFilter(TranslationsFilter.java:37) ~[mango-3.7.7.jar:?]
                                  at com.serotonin.m2m2.web.dwr.util.ExceptionDetectionFilter.doFilter(ExceptionDetectionFilter.java:26) ~[mango-3.7.7.jar:?]
                                  at com.serotonin.m2m2.web.dwr.util.DwrPermissionFilter.doFilter(DwrPermissionFilter.java:46) ~[mango-3.7.7.jar:?]
                                  at org.directwebremoting.impl.DefaultRemoter.execute(DefaultRemoter.java:431) ~[dwr-2.0.11.jar:?]
                                  at org.directwebremoting.impl.DefaultRemoter.execute(DefaultRemoter.java:283) ~[dwr-2.0.11.jar:?]
                                  at org.directwebremoting.servlet.PlainCallHandler.handle(PlainCallHandler.java:52) ~[dwr-2.0.11.jar:?]
                                  at org.directwebremoting.servlet.UrlProcessor.handle(UrlProcessor.java:101) ~[dwr-2.0.11.jar:?]
                                  at org.directwebremoting.servlet.DwrServlet.doPost(DwrServlet.java:146) ~[dwr-2.0.11.jar:?]
                                  at javax.servlet.http.HttpServlet.service(HttpServlet.java:707) ~[javax.servlet-api-3.1.0.jar:3.1.0]
                                  at javax.servlet.http.HttpServlet.service(HttpServlet.java:790) ~[javax.servlet-api-3.1.0.jar:3.1.0]
                                  at org.eclipse.jetty.servlet.ServletHolder$NotAsyncServlet.service(ServletHolder.java:1391) ~[jetty-servlet-9.4.23.v20191118.jar:9.4.23.v20191118]
                                  at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:760) ~[jetty-servlet-9.4.23.v20191118.jar:9.4.23.v20191118]
                                  at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1617) ~[jetty-servlet-9.4.23.v20191118.jar:9.4.23.v20191118]
                                  at com.infiniteautomation.mango.webapp.filters.MangoCacheControlHeaderFilter.doFilter(MangoCacheControlHeaderFilter.java:155) ~[mango-3.7.7.jar:?]
                                  at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1604) ~[jetty-servlet-9.4.23.v20191118.jar:9.4.23.v20191118]
                                  at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:320) ~[spring-security-web-5.1.5.RELEASE.jar:5.1.5.RELEASE]
                                  at org.springframework.security.web.authentication.switchuser.SwitchUserFilter.doFilter(SwitchUserFilter.java:200) ~[spring-security-web-5.1.5.RELEASE.jar:5.1.5.RELEASE]
                                  at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:334) ~[spring-security-web-5.1.5.RELEASE.jar:5.1.5.RELEASE]
                                  at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:127) ~[spring-security-web-5.1.5.RELEASE.jar:5.1.5.RELEASE]
                                  at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:91) ~[spring-security-web-5.1.5.RELEASE.jar:5.1.5.RELEASE]
                                  at com.serotonin.m2m2.web.mvc.spring.security.RateLimitingFilter.doFilterInternal(RateLimitingFilter.java:53) ~[mango-3.7.7.jar:?]
                                  at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107) ~[spring-web-5.1.7.RELEASE.jar:5.1.7.RELEASE]
                                  at com.serotonin.m2m2.web.mvc.spring.security.PermissionExceptionFilter.doFilter(PermissionExceptionFilter.java:34) ~[mango-3.7.7.jar:?]
                                  at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:119) ~[spring-security-web-5.1.5.RELEASE.jar:5.1.5.RELEASE]
                                  at org.springframework.security.web.session.SessionManagementFilter.doFilter(SessionManagementFilter.java:137) ~[spring-security-web-5.1.5.RELEASE.jar:5.1.5.RELEASE]
                                  at org.springframework.security.web.authentication.AnonymousAuthenticationFilter.doFilter(AnonymousAuthenticationFilter.java:111) ~[spring-security-web-5.1.5.RELEASE.jar:5.1.5.RELEASE]
                                  at org.springframework.security.web.servletapi.SecurityContextHolderAwareRequestFilter.doFilter(SecurityContextHolderAwareRequestFilter.java:170) ~[spring-security-web-5.1.5.RELEASE.jar:5.1.5.RELEASE]
                                  at org.springframework.security.web.session.ConcurrentSessionFilter.doFilter(ConcurrentSessionFilter.java:155) ~[spring-security-web-5.1.5.RELEASE.jar:5.1.5.RELEASE]
                                  at org.springframework.security.web.authentication.AbstractAuthenticationProcessingFilter.doFilter(AbstractAuthenticationProcessingFilter.java:200) ~[spring-security-web-5.1.5.RELEASE.jar:5.1.5.RELEASE]
                                  at org.springframework.security.web.authentication.logout.LogoutFilter.doFilter(LogoutFilter.java:116) ~[spring-security-web-5.1.5.RELEASE.jar:5.1.5.RELEASE]
                                  at org.springframework.security.web.csrf.CsrfFilter.doFilterInternal(CsrfFilter.java:100) ~[spring-security-web-5.1.5.RELEASE.jar:5.1.5.RELEASE]
                                  at org.springframework.security.web.header.HeaderWriterFilter.doFilterInternal(HeaderWriterFilter.java:74) ~[spring-security-web-5.1.5.RELEASE.jar:5.1.5.RELEASE]
                                  at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:105) ~[spring-security-web-5.1.5.RELEASE.jar:5.1.5.RELEASE]
                                  at org.springframework.security.web.context.request.async.WebAsyncManagerIntegrationFilter.doFilterInternal(WebAsyncManagerIntegrationFilter.java:56) ~[spring-security-web-5.1.5.RELEASE.jar:5.1.5.RELEASE]
                                  at org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:215) ~[spring-security-web-5.1.5.RELEASE.jar:5.1.5.RELEASE]
                                  at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:178) ~[spring-security-web-5.1.5.RELEASE.jar:5.1.5.RELEASE]
                                  at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:357) ~[spring-web-5.1.7.RELEASE.jar:5.1.7.RELEASE]
                                  at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:270) ~[spring-web-5.1.7.RELEASE.jar:5.1.7.RELEASE]
                                  at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:545) ~[jetty-servlet-9.4.23.v20191118.jar:9.4.23.v20191118]
                                  at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143) ~[jetty-server-9.4.23.v20191118.jar:9.4.23.v20191118]
                                  at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:590) ~[jetty-security-9.4.23.v20191118.jar:9.4.23.v20191118]
                                  at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:127) ~[jetty-server-9.4.23.v20191118.jar:9.4.23.v20191118]
                                  at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:235) ~[jetty-server-9.4.23.v20191118.jar:9.4.23.v20191118]
                                  at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1607) ~[jetty-server-9.4.23.v20191118.jar:9.4.23.v20191118]
                                  at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:233) ~[jetty-server-9.4.23.v20191118.jar:9.4.23.v20191118]
                                  at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1297) ~[jetty-server-9.4.23.v20191118.jar:9.4.23.v20191118]
                                  at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:188) ~[jetty-server-9.4.23.v20191118.jar:9.4.23.v20191118]
                                  at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:485) ~[jetty-servlet-9.4.23.v20191118.jar:9.4.23.v20191118]
                                  at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1577) ~[jetty-server-9.4.23.v20191118.jar:9.4.23.v20191118]
                                  at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:186) ~[jetty-server-9.4.23.v20191118.jar:9.4.23.v20191118]
                                  at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1212) ~[jetty-server-9.4.23.v20191118.jar:9.4.23.v20191118]
                                  at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141) ~[jetty-server-9.4.23.v20191118.jar:9.4.23.v20191118]
                                  at org.eclipse.jetty.server.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:221) ~[jetty-server-9.4.23.v20191118.jar:9.4.23.v20191118]
                                  at org.eclipse.jetty.server.handler.gzip.GzipHandler.handle(GzipHandler.java:767) ~[jetty-server-9.4.23.v20191118.jar:9.4.23.v20191118]
                                  at org.eclipse.jetty.server.Server.handle(Server.java:500) ~[jetty-server-9.4.23.v20191118.jar:9.4.23.v20191118]
                                  at org.eclipse.jetty.server.HttpChannel.lambda$handle$1(HttpChannel.java:383) ~[jetty-server-9.4.23.v20191118.jar:9.4.23.v20191118]
                                  at org.eclipse.jetty.server.HttpChannel.dispatch(HttpChannel.java:547) ~[jetty-server-9.4.23.v20191118.jar:9.4.23.v20191118]
                                  at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:375) ~[jetty-server-9.4.23.v20191118.jar:9.4.23.v20191118]
                                  at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:270) ~[jetty-server-9.4.23.v20191118.jar:9.4.23.v20191118]
                                  at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311) ~[jetty-io-9.4.23.v20191118.jar:9.4.23.v20191118]
                                  at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:103) ~[jetty-io-9.4.23.v20191118.jar:9.4.23.v20191118]
                                  at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:117) ~[jetty-io-9.4.23.v20191118.jar:9.4.23.v20191118]
                                  at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:336) ~[jetty-util-9.4.23.v20191118.jar:9.4.23.v20191118]
                                  at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:313) ~[jetty-util-9.4.23.v20191118.jar:9.4.23.v20191118]
                                  at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:171) ~[jetty-util-9.4.23.v20191118.jar:9.4.23.v20191118]
                                  at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:129) ~[jetty-util-9.4.23.v20191118.jar:9.4.23.v20191118]
                                  at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:388) ~[jetty-util-9.4.23.v20191118.jar:9.4.23.v20191118]
                                  at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:806) ~[jetty-util-9.4.23.v20191118.jar:9.4.23.v20191118]
                                  at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:938) ~[jetty-util-9.4.23.v20191118.jar:9.4.23.v20191118]
                                  at java.lang.Thread.run(Thread.java:832) [?:?]
                            As stupid as it sounds. It really does feel like a partially corrupt install...
                            Use an enterprise level zip, remove the nosql module before install if you are not using it and see how you go. Something aint sticking Dan!
                            • danD Offline
                              dan
                              Yeh it's very strange.
                              I used this link to download the source and removed the install entirely then reinstalled.
                              https://store.infiniteautomation.com/account/downloads/fullCores/free-m2m2-core-3.7.7.zip
                                Lets assume the download was iffy and you start again.
                                Seems like a good idea... hate to be that guy, but given the situation, seems like your best shot..
