    MQTT datapoint parsing help.
    6 Posts 3 Posters 3.2k Views 3 Watching
    • R Offline
      rob987
      I need some pointers on getting MQTT data into mango.
      I have configured the MQTT Broker OK, and am receiving data,
      but I cannot work out how to parse it.
      INFO  2021-01-11T17:13:09,026 (com.serotonin.m2m2.rt.RuntimeManagerImpl.stopDataSourceShutdown:447) - Data source 'MQTT_NAS' stopped
      INFO  2021-01-11T17:13:11,949 (com.serotonin.m2m2.rt.RuntimeManagerImpl.initializeDataSourceStartup:408) - Data source MQTT_NAS took 2ms to start
      WARN  2021-01-11T17:16:46,079 (com.infiniteautomation.m2m2.mqtt.client.MqttClientDataSourceRT.messageArrived:355) - Unknown topic "tele/tasmota_E14FF4/STATE" payload: "{"Time":"2021-01-11T17:16:45","Uptime":"2T23:52:24","UptimeSec":258744,"Heap":26,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":3,"Wifi":{"AP":1,"SSId":"NixNet","BSSId":"E4:8D:8C:3F:D7:A1","Channel":1,"RSSI":80,"Signal":-60,"LinkCount":1,"Downtime":"0T00:00:03"}}"
      ERROR 2021-01-11T17:16:46,121 (com.infiniteautomation.m2m2.mqtt.client.MqttClientDataSourceRT.messageArrived:375) - Error during read topic: "tele/tasmota_E14FF4/SENSOR" datapoint: "MQTT_NAS - Mealies_Temperature" payload: "{"Time":"2021-01-11T17:16:45","DS18B20":{"Id":"01192718DE3D","Temperature":25.6},"TempUnit":"C"}" exception: "Text '2021-01-11T17:16:45' could not be parsed at index 0"
      I have a json timestamp pattern of "yyyy'-'MM'-'dd'T'HH':'mm':'ss"
      Also, the temperature value is NaN :-(
      R 1 Reply Last reply Reply Quote 0
      • R Offline
        rob987 @rob987
        I have been trying different patters, and have a new error which is confusing me.
        The Date could not be parsed, then the message ends with
        :ISO resolved to 2021-01-12T16:46:47 of type java.time.format.Parsed"
        ERROR 2021-01-12T16:46:47,246 (com.infiniteautomation.m2m2.mqtt.client.MqttClientDataSourceRT.messageArrived:375) - Error during read topic: "tele/tasmota_E14FF4/SENSOR" datapoint: "MQTT_NAS - Mealies_Temperature" payload: "{"Time":"2021-01-12T16:46:47","DS18B20":{"Id":"01192718DE3D","Temperature":26.6},"TempUnit":"C"}" exception: "Text '2021-01-12T16:46:47' could not be parsed: Unable to obtain Instant from TemporalAccessor: {},ISO resolved to 2021-01-12T16:46:47 of type java.time.format.Parsed"
        • CraigWebC Offline
          CraigWeb
          I think it might be due to the ' chars in your pattern try this one and see if it works:
          yyyy-MM-dd'T'HH:mm:ss.SSS
          • R Offline
            rob987
            Tried the date format yyyy-MM-dd'T'HH:mm:ss.SSS and the error changed to
            Error during read topic: "tele/tasmota_E14FF4/SENSOR" datapoint: "MQTT_NAS - Mealies_Temperature" payload: "{"Time":"2021-01-13T13:26:48","DS18B20":{"Id":"01192718DE3D","Temperature":28.1},"TempUnit":"C"}" exception: "Text '2021-01-13T13:26:48' could not be parsed at index 19"
            I have the Sensor temperature, and WiFi signal strength working now. ( Just using JSON, and not JSON + Timestamp, as I cannot find a parsing string that works )
            Mango is subscribed to two topics, STATE and SENSOR.
            The steps I took were
            1. Connect to MQTT Broker and get a copy of the raw data ( Also checks connection from Mango PC )
            robert@mango:~$ mosquitto_sub  -h 192.168.220.208 -p 1883 -u robert -P XXXXX -t tele/#
            Client mosqsub/22329-mango received PUBLISH (d0, q0, r0, m0, 'tele/tasmota_E14FF4/STATE', ... (274 bytes))
            tele/tasmota_E14FF4/STATE {"Time":"2021-01-13T10:46:48","Uptime":"4T17:22:27","UptimeSec":408147,"Heap":25,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":3,"Wifi":{"AP":1,"SSId":"NixNet","BSSId":"E4:8D:8C:3F:D7:A1","Channel":1,"RSSI":92,"Signal":-54,"LinkCount":1,"Downtime":"0T00:00:03"}}
            Client mosqsub/22329-mango received PUBLISH (d0, q0, r0, m0, 'tele/tasmota_E14FF4/SENSOR', ... (96 bytes))
            tele/tasmota_E14FF4/SENSOR {"Time":"2021-01-13T10:46:48","DS18B20":{"Id":"01192718DE3D","Temperature":26.6},"TempUnit":"C"}
            Check the Subscribed Data at https://jsonformatter.org/json-parser You can paste the received data string in, and get a readable JSON document.
            object{9}
            	Time : 2021-01-13T10:46:48
            	Uptime : 4T17:22:27
            	UptimeSec : 408147
            	Heap : 25
            	SleepMode : Dynamic
            	Sleep : 50
            	LoadAvg : 19
            	MqttCount : 3
            	Wifi {8}
            		AP : 1
            		SSId : NixNet
            		BSSId : E4:8D:8C:3F:D7:A1
            		Channel : 1
            		RSSI : 92
            		Signal : -54
            		LinkCount : 1
            		Downtime : 0T00:00:03
            And
            object {3}
                DS18B20 {2}
                    Temperature : 26.6
                TempUnit : C
            Here are the working MQTT Datapoint setups
            And Temperature
            And The correct values shown on the datasource page
            If anyone has some ideas on how to parse the Time (JSON + Timestamp) let me know
            T 2 Replies Last reply Reply Quote 1
            • T Offline
              tungthanh500 @rob987
              @rob987 This is the most detail instruction regarding MQTT for new user. I highly recommend using his instruction. New user should check ma.log to check if data source is correct setup to read data from MQTT broker before working on data point.
              • T Offline
                @rob987 Hi, have you find solution for you JSON timestamp?
