    JSON RETRIEVER: Error 400
    5 Posts 3 Posters 2.3k Views 3 Watching
    • Z Offline
      zaaphod
      I am having issues with JSON HTTP retriever and need a little help.
      I have set up the data source and data point. I get error 'Invalid Response 400' trying to configure the data source, I know it's down to configuration I am just not sure how it is set up, struggling to see it in the documentation. I know my API requests work out with Mango so I was looking for the advise on how I should set it up.
      When testing GET requests before i attempted to link it to Mango i had it set up like so.
      Endpoint: http://86.156.98.233:80/api/slot/0/io/di
      Headers:
      • Accept - vdn.dac.v1
      • Content-Type - application/json
      That will pull all my inputs of the device and can use the following to pick out each input for the specific signal.
      • 'http://86.156.98.233:80/api/slot/0/io/di/0/diStatus'
      Here is how I set it up.
      alt text
      I i get the error 400 when trying to connect, I beleive it is an issue to do with theh headers on the API get request. Where can i edit the headers? Any help would be much appreciated.
        It would likely be better if you used the mango javascript httpRequestBuilder to make your own GET query for your custom headers. Then use that to populate a meta data point or if needs be, use a scripting datasource and save all of your values to the points inside the scripted datasource.
        Refer to this help I gave Nurr not too long ago and use that to build your get query:
        https://forum.infiniteautomation.com/topic/4834/how-to-get-json-data-via-api/2
        • CraigWebC Offline
          CraigWeb
          I agree with MattFox, the JSON retriever is not very flexible and only works on very basic APIs.
          Are you using the Moxa ioLogik? If so you might want to look into using SNMP to communicate with it.
          • Z Offline
            zaaphod
            Thanks for the reply's.
            I had a go with the scripts but running into issues with the callback. I am getting 'TypeError: Cannot read property "length" from undefined at line: 16'.
            var foxesCBHandler = function(status, headers, content)
               var data = JSON.parse(content);
               data = data.result; //lets get the info we want.
                for (var pnt in CONTEXT_POINTS) //list of points in context
                    for(var i=0; i<data.length; i++) //loop through available values.
                        if(this[pnt].xid === data[ i ].deviceName) //items match
                            this[pnt].set(data[ i ].diStatus, Date.parse(data[ i ].readDate) ); //set value and time
                            break; //finished, next context pt!
            I'm rather new to javascript so not sure what the issue is there. The JSON i am requesting is:
            {"slot":0,"io":{"di":[
            {"diIndex":0,"diMode":0,"diStatus":0},
            {"diIndex":1,"diMode":0,"diStatus":0},
            {"diIndex":2,"diMode":0,"diStatus":0},
            {"diIndex":3,"diMode":0,"diStatus":0}
            I am just looking to pull the DiStatus.
            Matt, i am using the Moxa IoLogic. I can give that a look although have never used SNMP before. Have you set them up before with SNMP in the past? I'm not too sure of the configuration for it.
            Zaphod
              @zaaphod said in JSON RETRIEVER: Error 400:
              You're already 90% of the way there.
              I'd argue your code will be something like this since there is no "result" property in your incoming data.
                 data = data.io.di; //lets get the info we want.
              However, you still need to be able to have a means to link what diIndex is what point.
              If you have the points configured with a specific XID or naming convention, we can use that to map it all together.
