    Line Chart Balloons
    6 Posts 2 Posters 3.2k Views 2 Watching
    • BGB Offline
      BG
      Hello All,
      I am using the latest Mango modules and trying to remove the balloons from some line charts.
      In the examples page for the Advance Charts it states that:
      use balloon="true" to turn on timestamp and value tool tips on mouse hover.
      So I assumed that a false there would turn the balloons off. But as shown in the screen shot below that is not the case.
      I also removed the balloon comment entirely and still the balloons appear on the chart. Hey must be the default setting in the AM charts module. Which is OK because I use them on other charts.
      I found a post by another Mango user on how to remove the date portion of the balloon text via a style entry: https://forum.infiniteautomation.com/post/22275 and it does exactly as it says, but I really need to remove the entire balloon from this chart.
      I have tried to use different items in the options by taking lines from AmChart examples but I can't get any of those to work either.
      Can anyone tell me how to disable the balloons from the chart please?
      Thank you
      Brian
        According to http://docs.amcharts.com/3/javascriptcharts/AmGraph#showBalloon
        showBalloon needs to be false.
        It's a graph-options item for each graph in the attribute:
        graph-options="[ {showBalloon:false},{showBalloon:false}]"
        • BGB Offline
          BG
          Thank you very much MattFox.
          I saw the showBalloon settings in AmGraph but didn't know how to pull that into Mango.
          Now using your style set up from the earlier forum entry and now this line I am left with only the cursor line.
          I was hoping that removing the balloons would also remove the cursor but I see in AmGraph that the balloon set up depends on the chartCursor so it looks like I need to disable the chartCursor.
          Do I disable the chartCursor via another set of options?
          Cheers
          Brian
            MattFox @BG
            @bg said in Line Chart Balloons:
            Tinker, that's how I learn. Besides ctrl + z exists for a reason! :D
            Simple!
            options="{
            chartCursor:{enabled:false}}"
            In fact, this removes the balloon on the x axis so the styling isn't required.
            Have fun!
            Note this is the options attribute which affects other javascript classes the chart calls on, not the graph options itself.
            • BGB Offline
              BG
              Tinkering is my favourite method as well :) But sometimes I head off in the wrong direction.
              Thanks for all the help, I now know how to completely dismantle the chartCursor.
              Cheers
              Brian
                My pleasure, always here if needed
