    amCharts - maTankLevel center chart column in div
    4 Posts 2 Posters 2.1k Views 2 Watching
    • B Offline
      BobDay
      Hi - need a little help centering maTankLevel column in div...
      When using the ma-tank-level component, its width is greater than the actual chart data path. I've perused the amCharts documentation, and can't find a way to either center the data in the chart div, or to get the actual pixel width of the data element (column, in this case).
      I can hack it by placing the directive in a narrower div, but I can't dynamically size the containing div to the column size.
      html: (not relevant commented out; css below)
      <div id="09u098" class="table-block-top">
                  <table class="first-table">
                      <thead>
                          <tr class="tank-row">
                              <th class="tank-col caption">FILLING</th>
                              <th></th>
                              <th class="tank-col caption">READY</th>
                          </tr>
                      </thead> -->
                      <tbody>
                          <tr class="tank-block">
                              <td id="tank1" class="tank-box"><ma-tank-level id="tank1Tank" class="ma-tank" options="{angle: 12}"></ma-tank-level></td>
                              <td></td>
                              <td id="tank2" class="tank-box"><ma-tank-level id="tank2Tank" class="ma-tank" options="{angle: 12}"></ma-tank-level></td>
                          </tr>
                         /* <!-- <tr class="tank-row">
                              <td class="button">
                                 <ma-switch-img class="rotate-180" id="569459e8-da3b-48e6-b127-bb9081b1342e" style="position: relative; width: 44px; height: 44px;" default-src="/rest/v2/file-stores/default/icons/button-153683_640.png" src-false="/rest/v2/file-stores/default/icons/button-153683_640.png" src-true="/rest/v2/file-stores/default/icons/button-153683_640.png" point-xid="DP_t1_fill"></ma-switch-img>
                              </td>
                              <td class="text-lbl">FILL</td>
                              <td class="button">
                                  <ma-switch-img class="rotate-180" id="569459e8-da3b-48e6-b127-bb9081b1340a" style="position: relative; width: 44px; height: 44px;" default-src="/rest/v2/file-stores/default/icons/button-153683_640.png" src-false="/rest/v2/file-stores/default/icons/button-153683_640.png" src-true="/rest/v2/file-stores/default/icons/button-153683_640.png" point-xid="DP_t1_fill"></ma-switch-img>
                              </td>
                          </tr>
                              <td class="button">
                                  <ma-switch-img id="b5a74da4-554e-48e0-beb6-96f2bd6e4bc4" style="position: relative; height: 46px; width: 46px" toggle-on-click="true" default-src="/rest/v2/file-stores/default/icons/slim-green-led-on-th.png" point-xid="DP_t1_fill"></ma-switch-img>
                              </td>
                              <td class="text-lbl">SEL</td>
                              <td class="button">
                                  <ma-switch-img id="b5a74da4-554e-48e0-beb6-96f2bd6e4bc4" style="position: relative; height: 46px; width: 46px" toggle-on-click="true" default-src="/rest/v2/file-stores/default/icons/slim-green-led-on-th.png" point-xid="DP_t1_fill">1</ma-switch-img>
                              </td>
                          </tr>
                              <td class="text-val">Tank 1</td>
                              <td></td>
                              <td class="text-val">Tank 2</td>
                          </tr>
                      </tbody>
                  </table>
      </div> --> */
      relevant css:
      .tank-block {
         position: relative;
         /*left: 0px;
         top: 0px;*/
         padding: 20px;
         width: 400px;
         height: 300px;
      .tank-box {
        position: relative;
        display: inline-block;
        width: 175px;
        height: 250px;
        padding:0 0;
      .ma-tank {
         position: relative;
         height: 100%;
         width: 275px;
      .table-block-top {
          display: flex;
          justify-content: flex-start;
      table {
          max-width: 25%;
          /*display: inline-block;*/
          border: none;
          text-align: center;
          border-collapse: collapse;
          font-size: 1em;
          margin: 0 30px;
      table.first-table {
          padding-left:5px;
      table td, table th {
          border: none;
      table tbody td {
          text-align: center;
      .tank-row {
          height: 75px;
        @bullitbd I haven't dug too much into your code, but I think the crux of your issue is that you want the tank element to fit to the outside containing element?
        Here's a minimal code example that demonstrates how to do this -
        <div class="ma-designer-root" id="c00f126c-86e9-46a4-9282-a36865b9451a" style="width: 1366px; height: 768px; position: relative;">
            <div id="362df9d5-1eb8-4321-8a22-740ee3c3b903" style="position: absolute; width: 159px; height: 257px; left: 166px; top: 85px;">
                <ma-tank-level point-xid="voltage" max="5" style="width: calc(100% + 95px); height: 100%;"></ma-tank-level>
            </div>
        </div>
        Basically setting it to 100% height and width but making adding 95px to the width.
          Actually here's a second method which is a little more straightforward
              <div id="3facd1f4-cc6e-435f-a3f4-7641f450a1c8" style="position: absolute; width: 287px; height: 299px; left: 436px; top: 115px;">
                  <ma-tank-level point-xid="voltage" max="5" style="width: 100%; height: 100%;" options="{marginRight: -74}"></ma-tank-level>
              </div>
          </div>
          • B Offline
            BobDay
            @jared-wiltshire said in amCharts - maTankLevel center chart column in div:
            marginRight: -74
            Aha! Thank you Jared! I was barking up another tree... sorry for all the code - TMI
