amCharts - maTankLevel center chart column in div
Hi - need a little help centering maTankLevel column in div...
When using the ma-tank-level component, its width is greater than the actual chart data path. I've perused the amCharts documentation, and can't find a way to either center the data in the chart div, or to get the actual pixel width of the data element (column, in this case).
I can hack it by placing the directive in a narrower div, but I can't dynamically size the containing div to the column size.
html: (not relevant commented out; css below)
<div id="09u098" class="table-block-top"> <table class="first-table"> <thead> <tr class="tank-row"> <th class="tank-col caption">FILLING</th> <th></th> <th class="tank-col caption">READY</th> </tr> </thead> --> <tbody> <tr class="tank-block"> <td id="tank1" class="tank-box"><ma-tank-level id="tank1Tank" class="ma-tank" options="{angle: 12}"></ma-tank-level></td> <td></td> <td id="tank2" class="tank-box"><ma-tank-level id="tank2Tank" class="ma-tank" options="{angle: 12}"></ma-tank-level></td> </tr> /* <!-- <tr class="tank-row"> <td class="button"> <ma-switch-img class="rotate-180" id="569459e8-da3b-48e6-b127-bb9081b1342e" style="position: relative; width: 44px; height: 44px;" default-src="/rest/v2/file-stores/default/icons/button-153683_640.png" src-false="/rest/v2/file-stores/default/icons/button-153683_640.png" src-true="/rest/v2/file-stores/default/icons/button-153683_640.png" point-xid="DP_t1_fill"></ma-switch-img> </td> <td class="text-lbl">FILL</td> <td class="button"> <ma-switch-img class="rotate-180" id="569459e8-da3b-48e6-b127-bb9081b1340a" style="position: relative; width: 44px; height: 44px;" default-src="/rest/v2/file-stores/default/icons/button-153683_640.png" src-false="/rest/v2/file-stores/default/icons/button-153683_640.png" src-true="/rest/v2/file-stores/default/icons/button-153683_640.png" point-xid="DP_t1_fill"></ma-switch-img> </td> </tr> <tr class="tank-row"> <td class="button"> <ma-switch-img id="b5a74da4-554e-48e0-beb6-96f2bd6e4bc4" style="position: relative; height: 46px; width: 46px" toggle-on-click="true" default-src="/rest/v2/file-stores/default/icons/slim-green-led-on-th.png" point-xid="DP_t1_fill"></ma-switch-img> </td> <td class="text-lbl">SEL</td> <td class="button"> <ma-switch-img id="b5a74da4-554e-48e0-beb6-96f2bd6e4bc4" style="position: relative; height: 46px; width: 46px" toggle-on-click="true" default-src="/rest/v2/file-stores/default/icons/slim-green-led-on-th.png" point-xid="DP_t1_fill">1</ma-switch-img> </td> </tr> <tr class="tank-row"> <td class="text-val">Tank 1</td> <td></td> <td class="text-val">Tank 2</td> </tr> </tbody> </table> ... </div> --> */relevant css:
.tank-block { position: relative; /*left: 0px; top: 0px;*/ padding: 20px; width: 400px; height: 300px; } .tank-box { position: relative; display: inline-block; width: 175px; height: 250px; padding:0 0; } .ma-tank { position: relative; height: 100%; width: 275px; } .table-block-top { display: flex; justify-content: flex-start; } table { max-width: 25%; /*display: inline-block;*/ border: none; text-align: center; border-collapse: collapse; font-size: 1em; margin: 0 30px; } table.first-table { padding-left:5px; } table td, table th { border: none; } table tbody td { text-align: center; } .tank-row { height: 75px; } -
@bullitbd I haven't dug too much into your code, but I think the crux of your issue is that you want the tank element to fit to the outside containing element?
Here's a minimal code example that demonstrates how to do this -
<div class="ma-designer-root" id="c00f126c-86e9-46a4-9282-a36865b9451a" style="width: 1366px; height: 768px; position: relative;"> <div id="362df9d5-1eb8-4321-8a22-740ee3c3b903" style="position: absolute; width: 159px; height: 257px; left: 166px; top: 85px;"> <ma-tank-level point-xid="voltage" max="5" style="width: calc(100% + 95px); height: 100%;"></ma-tank-level> </div> </div>Basically setting it to 100% height and width but making adding 95px to the width.
Actually here's a second method which is a little more straightforward
<div class="ma-designer-root" id="c00f126c-86e9-46a4-9282-a36865b9451a" style="width: 1366px; height: 768px; position: relative;"> <div id="3facd1f4-cc6e-435f-a3f4-7641f450a1c8" style="position: absolute; width: 287px; height: 299px; left: 436px; top: 115px;"> <ma-tank-level point-xid="voltage" max="5" style="width: 100%; height: 100%;" options="{marginRight: -74}"></ma-tank-level> </div> </div> -
@jared-wiltshire said in amCharts - maTankLevel center chart column in div:
marginRight: -74
Aha! Thank you Jared! I was barking up another tree... sorry for all the code - TMI
