    SeroUtils.jar management
    41 Posts 6 Posters 89.4k Views 1 Watching
      I could provide you with the subset of seroUtils required by Modbus4J fairly easily. Do note though that Modbus4J is GPL software. Any changes you make need to become open source, which is a consideration if your project ever becomes commercial in the future. But Serotonin can provide a more LGPL-like license in this occurrence.
      • R Offline
        racj
        Dear Matthew,
        Open source is not a problem.
        Would you provide the sub-set of SeroUtils as source for me to do the conversion or would you look to do it yourself ?
        Regards
        Richard
          If you're converting the Modbus4J stuff, you might as well do this too. Attached.
          Attachment: download link
          • R Offline
            racj
            Dear Matthew,
            Thank you for that. I will let you know how I get on.
            Regards
            Richard
            • G Offline
              gpulido
              Dear Matthew,
              I'm collaborating in a Open Source project to develop a personal home-automation framework, and we would like to use your Modbus4J library.
              Unfortunatelly it depends of the seroUtils.jar and as our project is under the GPL license we would like to know if you can proportionate us the source code for the library.
              Thank you in advance
              Best regards
              Gabriel
                Hi Gabriel,
                The source in the above should be all you need. Feel free to use it.
                Regards,
                • G Offline
                  gpulido
                  Hello Mathew,
                  Unfortunately the link is broken can you publish it again?
                  Thank you
                  Regards,
                  Gabriel
                    Ah, right. Lost in the move. Re-attached.
                    • A Offline
                      apl
                      @mlohbihler said:
                      Modbus4J is open source, as all of the sources for Modbus4J are provided. As i said, seroUtils.jar is not open source, not for any matter of secrecy, but only because there are parts of it that users will most certainly ask about that we are not prepared to support. It is, of course, Java technology, and as such resourceful users will - i'm certain - find ways to debug their code without Serotonin having to take on supporting yet another open source project. Again, if this does not suit your sense of entitlement, you have alternatives.
                      Can I take this, that I can reengineer the needed sorces for mango M2M (1.12.4) for further development?
                      Or under which license is seroUtils.jar?
                        Yes, you can do what you like with the sources within the constraints of the GPL license. The license for seroUtils is not defined, but it is intended to be used only as support for Mango. I would be inclined to grant its use as support for Mango derivatives under GPL as well.
                        1 Reply Last reply Reply Quote -1
                        • A Offline
                          apl
                          So, can I
                          get the needed sources
                          or
                          decompile the needed classes it for ScadaBR?
                          and
                          put them in a different packages?
                          OR have a double license GPL and closed source licenses for serotonin only? (this can include any code commited to the GPL version is also in the closed source as well)?
                          Arne
                            For seroUtils? No. The license would be one of usage with Mango.
                            • A Offline
                              apl
                              So for ScadaBR I will have to throw out all references to seroUtil in order to get a full Open Source?
                              • A Offline
                                apl
                                Im missing a way to JSON serialize an enum by annotation - can you provide the sources to implement this?
                                Or should I take the approach from my last mail?
                                  They might do that i suppose, but rewriting all of that supporting code would be a large effort. The good news is that we just started the process of releasing seroUtils as open source. The first project is here: http://code.google.com/p/serotonin-json.
                                  Please note that this is not the version of JSON that is used in Mango, but a more advanced and streamlined version. (The API is similar in many ways, but different enough in others.)
                                  The release of other parts of seroUtils is forthcoming.
                                  Regarding serializing enums, you don't annotate them. The id of the enum is serialized as a string.
                                  • A Offline
                                    apl
                                    I am delighted :P
                                    Here a "bug" for you. Please have a look at pointListChangeLock in DataSourceRT and PollingDataSourceRT.
                                    1. the lock filed is not final.
                                    2. Its a commonly known static Object Boolean.TRUE
                                    3. the same lock will be used for writing the "cache" and working with the list, which made the lock useless in the first place.
                                      this is fixed in ScadaBR
                                    Arne.
                                    P.S. if you interested in further bugs, if I come along, please let me know.
                                      Hi Arne,
                                      Sorry, i'm not seeing what the bug is here. You point 2 is incorrect. The lock object is not Boolean.TRUE, it is a new Boolean object created for each data source instance. And contrary to point 3, the lock is only used to manage the point list, not writing to the cache (unless writing to the cache is part of a data sources usage of the point list).
                                      Maybe if you posted the "fix", it would help me understand.
                                      • A Offline
                                        apl
                                        in DataSourceRT.addDataPoint(...)
                                        pointListChangeLock is used to synchronize access to addedChangedPoints and removedPoints.
                                        in PollingDataSource.scheduleTimeout you synchronize also with pointListChangeLock...
                                        This makes the whole thing useless, you wont have separate access to add/Remove points.
                                        @2 You right, I was puzzled by the usage of Boolean ;-)
                                          Sorry, i still don't understand how this makes the whole thing pointless. You absolutely do have separate threads accessing scheduleTimeout and add/removeDataPoint. The former is a runtime function, the latter is a UI function. It still looks fine to me.
                                          • A Offline
                                            apl
                                            I thougth that the the whole thing is there, to add new DataPoints to RT if the RT is polling the dataPoints.
                                            with the lock only one Thread can access the add/Remove or pointList.
                                            I have a lock for the addList (the addList) one for remove and one for the pointList.
                                            so adding will lock only the addList ...
                                            If I copy over I must lock all.
                                            src is here (modified)
                                            https://scadabr.svn.sourceforge.net/svnroot/scadabr/trunk/scadabr/scadabr/src/main/java/com/serotonin/mango/rt/dataSource/DataSourceRT.java
