    SeroUtils.jar management
    41 Posts 6 Posters 91.0k Views 1 Watching
    • F Offline
      Fred
      Removed post.
        racj
        Dear Matthew,
        I am currently using JAMOD on a CDC platform and would be interested in using Modbus4J, since this gives RTU slave capability.
        However, The seroUtils.jar is not JAVA 1.4 compatible, which is what I need for my CDC platform (which consequently fails when trying to link).
        Are you able to provide a version of the JAR file built using the JAVA compiler switches -source 1.4 and -target 1.4 ?
        If you are able to do this then I would look to generate a CDC compatible version of Modbus4J.
        Many thanks
        Richard
          Hi Richard,
          It is very likely possible to create a CDC-compatible version of seroUtils. Is this a personal project, or do you have a development budget?
            racj
            Dear Matthew,
            This is a research project - so only a very limited budget.
            How long do you think it would take you ?
            Would it be possible for me to look at what is needed for a CDC compatible compile ? I do realise from the previous discussions in this thread that you have concerns about open sourcing SeroUtils - can this be handled some other way than global open source ?
            Regards
            Richard
              Hi Richard,
              Did you already convert Modbus4J to 1.4? I recall that for the "-source 1.4" switch to work you'd need to refactor all the generics, annotations, and auto-boxing, and possibly other stuff too.
                racj
                Dear Matthew,
                I have only identified the sections that will need to be modified (as you correctly identified this is mostly generics etc), However I have not proceeded with implementing any changes, because having a usable system is dependant on having a CDC compatible version of SeroUtils.
                Do you have a feel for how much work it would be to generate the CDC compatible version of SeroUtils ?
                Regards
                Richard
                  I could provide you with the subset of seroUtils required by Modbus4J fairly easily. Do note though that Modbus4J is GPL software. Any changes you make need to become open source, which is a consideration if your project ever becomes commercial in the future. But Serotonin can provide a more LGPL-like license in this occurrence.
                    racj
                    Dear Matthew,
                    Open source is not a problem.
                    Would you provide the sub-set of SeroUtils as source for me to do the conversion or would you look to do it yourself ?
                    Regards
                    Richard
                      If you're converting the Modbus4J stuff, you might as well do this too. Attached.
                        racj
                        Dear Matthew,
                        Thank you for that. I will let you know how I get on.
                        Regards
                        Richard
                        • G Offline
                          gpulido
                          Dear Matthew,
                          I'm collaborating in a Open Source project to develop a personal home-automation framework, and we would like to use your Modbus4J library.
                          Unfortunatelly it depends of the seroUtils.jar and as our project is under the GPL license we would like to know if you can proportionate us the source code for the library.
                          Thank you in advance
                          Best regards
                          Gabriel
                            Hi Gabriel,
                            The source in the above should be all you need. Feel free to use it.
                            Regards,
                            • G Offline
                              gpulido
                              Hello Mathew,
                              Unfortunately the link is broken can you publish it again?
                              Thank you
                              Regards,
                              Gabriel
                                Ah, right. Lost in the move. Re-attached.
                                  apl
                                  @mlohbihler said:
                                  Can I take this, that I can reengineer the needed sorces for mango M2M (1.12.4) for further development?
                                  Or under which license is seroUtils.jar?
                                    Yes, you can do what you like with the sources within the constraints of the GPL license. The license for seroUtils is not defined, but it is intended to be used only as support for Mango. I would be inclined to grant its use as support for Mango derivatives under GPL as well.
                                      apl
                                      So, can I
                                      get the needed sources
                                      or
                                      decompile the needed classes it for ScadaBR?
                                      and
                                      put them in a different packages?
                                      OR have a double license GPL and closed source licenses for serotonin only? (this can include any code commited to the GPL version is also in the closed source as well)?
                                      Arne
                                        For seroUtils? No. The license would be one of usage with Mango.
                                          apl
                                          So for ScadaBR I will have to throw out all references to seroUtil in order to get a full Open Source?
                                            apl
                                            Im missing a way to JSON serialize an enum by annotation - can you provide the sources to implement this?
                                            Or should I take the approach from my last mail?
