    Assigning Event Handler (Set Point) output to multiple targets
    4 Posts 2 Posters 1.6k Views 2 Watching
    • W Offline
      Wingnut2.0
      Re: Assigning event handlers
      Curious if its also possible to assign the output of an event handler set point to multiple target points via json?
        Hi Wingnut2.0,
        Sort of. It isn't possible using the return value, but you could add the points to context on the handler and do something like,
        for ( var varName in CONTEXT_POINTS ) {
          if("source" == varName)
            continue;
          this[varName].set(source.value);
        return UNCHANGED; //don't set a value to the "target" point here, we already did
        And you could change up the context points via JSON (not sure how the JSON portion tied in).
        • W Offline
          Wingnut2.0
          Thanks Phillip.
          In your response here https://forum.infiniteautomation.com/topic/3282/assigning-event-handlers you mentioned making the change in the JSON to have multiple points reference a single event handler.
          "eventTypes":[
                         "sourceType":"DATA_POINT",
                         "dataPointXID":"DP_1234",
                         "detectorXID":"ED_1234"
          I didnt know if the same approach might work by adding multiple target points in the JSON of the event handler
          "targetPointId":"DP_pointOne,
          "targetPointId":"DP_pointTwo,
            That enables one to handle multiple event types with the same event handler, not only point event detector event types. There is not a way through the UI to configure that sort of situation yet, but you can import it already and it'll work. It would be many-events-to-single-handler instead of single-handler-to-many-points.
            Looping over points and using the set() function is the only way to set multiple values from a set point handler. You can still construct the context (which should work automatically with the snippet I shared) through JSON via the "additionalContext" property of the set point handler.
