    Mango RestApi Login V3.3.1
    mangoapirest apilogin
    6 Posts 3 Posters 2.5k Views 3 Watching
      matwolff
      Hello,
      when attempting to POST the login request as outlined here, https://help.infiniteautomation.com/mango-rest-api-authentication/
      I am receiving the 200OK response but I am not receiving the token or set-cookie headers in the response. We are currently on Mango V3.3.1 . I can post more info if needed was just curious if this was a known issue or if anyone had run into something similar. I am using PHP with cURL.
        Hi matwolff, welcome to the forum!
        I wonder, are you sending all the headers in the example? Are you getting a JSON response like you were successful?
        I was able to curl a login and save the response headers to a /home/mango/cookie-headers file with
        curl -X POST http://localhost:80/rest/v2/login --header "Accept:application/json" --header "Content-Type:application/json;charse=UTF-8" --header "X-XSRF-TOKEN:74cf354a-e871-48b6-a1c2-bebb93d00120" --header "Cookie:XSRF-TOKEN=74cf354a-e871-48b6-a1c2-bebb93d00120" --data '{"username":"admin","password":"admin"}' -D /home/mango/cookie-headers
          @matwolff I reviewed the help article and it looks correct to me. I did however add a section on using token authentication which has been available since v3.3.0, this may interest you.
            matwolff @phildunlap
            @phildunlap ,
            Thank you for this, I was able to resolve the issue after seeing your seeing your example I was sending Set-Cookie: instead of Cookie.
            Thanks again!
              matwolff @Jared Wiltshire
              @jared-wiltshire ,
              thanks for this as well. This would be an awesome option but would need something longer than a 3 month expiry as we wouldn't be able to trust our end users to update this regularly. Also, I just tried to create a token to check it out and received an error with no token generated.
              Cannot deserialize value of type java.util.Date from String "2018-06-04T21:55:32.087Z": not a valid representation (error: Failed to parse Date value '2018-06-04T21:55:32.087Z': Unparseable date: "2018-06-04T21:55:32.087Z")
                Jared Wiltshire @matwolff
                @matwolff said in Mango RestApi Login V3.3.1:
                You should be able to select a period longer than 3 months. You can also manually set the expiration date to anything you want. Just click the date input.
                I think you must have rest.customDateInputFormat set to something in your ${MA_HOME}/overrides/properties/env.properties file. Delete that line and also rest.customDateOutputFormat. They now have defaults for parsing/formatting dates as ISO 8601.
