    Mango's Out of Memory Problem
    19 Posts 3 Posters 10.4k Views 3 Watching
    • N Offline
      Nikospps
      Hello,
      i have installed Mango into two clients. Suddenly, while two machines run for a long time without any problem, i issued the same problem "out of memory", as two attachments shows:
      The problem showed up in different days.
      Any explanation about this?
      PS:Above attachments are screenshots from two different clients,which the same problem occured.
      Thanks in advance,
      Nikos.
        Hi Nikos,
        What version are these Mangoes? You may need to update. There was a notable memory leak fixed in 3.4 (comes up in this thread: https://forum.infiniteautomation.com/topic/3443/event-handler-setting-meta-point-failing) where a task queue could begin to fill but never empty. There was also a small websocket memory leak fixed in 3.3.4
          @Nikospps we will need a lot more information in order to give you any meaningful help.
          • Mango version?
          • Have you updated all your modules?
          • What version/build number of Java are you running?
          • Number of data points
          • What data sources you have enabled
          • How long where the instances of mango running for?
          • Log files
          • Do you have any event handlers or scripts running?
          • Do you have any reports running? How many data points in each?
          • How many simultaneous users are using these instances of Mango?
          Please see
          https://help.infiniteautomation.com/reporting-bugs/
          • N Offline
            Nikospps
            Hello @phildunlap @Jared-Wiltshire and thanks for the immediate replies.
            I have purchased two licenses: one commercial (1000 datat points) with core at 3.3.4 and the second one commercial-lite (500 data points) with core at 3.3.3. All the modules are outdated.
            Java number that i am running is 1.8.0_161 and 1.8.0_162 for each one.
            I have enabled about 50% of data points in each machine, with a variety of event handlers, a small number of scripts running and no reports.
            These instances are used by two (2) users: administrator and another one.
            I have to upgrade in latest version (3.4.1) as @phildunlap mentioned right?
            If i use UI to make the upgrades, will i have any problem with my data and GUID's?
            Thanks in advance,
            Nikos.
              Yes you can update through the UI without having license issues and whatnot. If you're worried about your data or configuration, leave the "backup before updating" checkbox ticked and wait for it to create a backup (provided backups are enabled in your system settings!). If updating through the modules page caused license issues (aside the 2 --> 3 major upgrade, and perhaps future major versions, which is clearly stated on the modules page during the upgrade process) we would be overwhelmed with the same requests all the time.
              • N Offline
                Nikospps
                Hello @phildunlap ,
                i issued a big problem,after the effort of upgrading in to latest version:
                As a result i can't start (and open) the UI api.
                Why, all this issue?
                • N Offline
                  Nikospps
                  And also this, as i try to run upgrade.sh:
                    :-/ When I say the UI, I mean the webserver, not the command line. I guess you didn't chmod +x all the scripts when you did your installation? I suspect your invoking the upgrade.sh script directly didn't hurt anything, since it didn't know where Mango was installed, but we've never instructed anyone to do that.
                    You may still have the updated m2m2-core-3.4.1.zip in your Mango/ directory. If you attempted to start Mango again it would perform the upgrade.
                    Otherwise,
                    You should resolve this by downloading the enterprise bundle here: https://store.infiniteautomation.com/core
                    1. Place the downloaded file in your Mango/ directory with the name m2m2-core-3.4.1.zip ,
                    2. chmod +x Mango/bin/*.sh
                    3. You may need to chown -R yourOsUser:yourOsGroup Mango/ if you copy the files over with a different permission that the user that launches Mango doesn't have.
                    4. cd Mango/bin; ./ma.sh start
                    The start scripts will check for upgrades in the Mango/ directory.
                    N 1 Reply Last reply Reply Quote 0
                    • N Offline
                      Nikospps @phildunlap
                      Hello @phildunlap . When we said UI, i did use webserver and not command line. After the invoking, i made efforts to correct, using this. But NO, i didn't use terminal.
                      This problem was caused, during upgrade process. It was really bad, as i couldn't see, the place, where scada was created using Mango.
                      I will follow your steps and will inform you.
                      Thanks in adnvance,
                      Nikos.
                      • N Offline
                        Nikospps
                        Finally solved!
                        I made the same "upgrade process and in second one licensed Mango Software and caused me the same problem.
                        After this, i followed your steps and correct the problem on each of them.
                        I have upgrated-to 3.4.1-versions for each of these versions, for which i purchased the license.
                        Hope, that i will will not meet the same "Out Of Memory" problem again.
                        I will inform you, if yes.
                        Thanks for the support.
                        • N Offline
                          Nikospps
                          Goodmorning @phildunlap , @Jared-Wiltshire.
                          Unfortunately the problem still remains:
                          despite the fact i upgraded to 3.4.1 as we said:
                          As a result, i have connection problems with the scada, where i use Mango, and need to restart it every few days.
                          It's an important issue for me and my company, so i would like to find a solution together.
                          Waiting for your ideas.
                          Nikos.
                            From the information you've provided there are way too many unknowns. For instance, the extent that you've provided anything from your logs is images of your console with the lower part of a stack trace and some threads having errors.
                            Jared put many questions to you, and you should answer them.
                            Is it possible your events, user events, and audit tables would benefit from a purge? How large is your H2 database?
                            • N Offline
                              Nikospps
                              I will reply to Jared's questions one by one immediately.
                              I also quote this issue, that sometimes happens to my watchlists:
                              Normal Monitoring:
                              Strange Monitoring:
                                Don't forget to answer the questions I posed to you in the last post, while you're at it. I wouldn't be surprised if purging your events table helps.
                                • N Offline
                                  Nikospps
                                  @Jared-Wiltshire
                                  1. Mango Version for each of two purchased modules (Commercial and Commercial Lite):
                                    3.4.1
                                  2. Yes, i have updated all the modules.
                                  3. Currently run JDK 1.8.0_162
                                  4. 540/1000 Data points at Commercial Version and 80/500 at Commercial Lite Version.
                                  5. Modbus I/P Data Sources are enabled on both two versions.
                                  6. They are running about 4 months.
                                  7. Send me please a link, in order to send two files for each of two versions.
                                  8. Yes i do have. For example, an alarm, for a switch connector, when equals to zero (is 'OFF')
                                  9. No, i don't have any report handler.
                                  10. Currently two users: administrator and another one user with limited privileges.
                                  @phildunlap if i "purge all events" on system settings, i will lose only data of these events during these months or all the configuration settings, which enabled, to run these?
                                  Nikos.
                                    'Purging all events' will only delete everything in the events and userEvents tables in the database. It does not delete event handlers or configuration settings, only previous times that events occurred and information about acknowledgements or comments on those events.
                                    • N Offline
                                      Nikospps
                                      I had the same issues today morning. So, i "purged all events" and have to watch its progress (or not).
                                      • N Offline
                                        Nikospps
                                        Hello again,
                                        after 7 days of progress monitoring and delete of events, today i noticed again the same issue:
                                        I had answer to all questions. So maybe any bug?
                                          If there were, it would be a nightmare to investigate it through console screenshots.
                                          You can email your logs and your latest Mango/backup/core-database-H2-...zip file to support@infiniteautomation.com and I'll give it a look.
