Navigation
    • Search
    Migrate from SQL to NoSQL
    User help
    3
    9
    836
    • P
      psysak last edited by
      Just finally purchased a license for a full Mango instance and would like to migrate over to NoSQL. Are there any guides to do that?
      • JoelHaggar
        JoelHaggar last edited by
        https://help.infiniteautomation.com/migrating-into-nosql/
        • P
          Of course! Sorry about that, and thanks Joel
          • P
            psysak last edited by psysak
            OK let me ask this. There are a couple of articles there, the one you referenced and this one
            https://help.infiniteautomation.com/database-conversions/
            So if I understand correctly, H2 is the "configuration" db and then the historical db is the one which is stored in mysql and the one I am attempting to migrate now?
            Also that little db icon doesn't exist anymore on the menu.
            • P
              OK!! I don't have the module installed, that would do it!
              • P
                Finally got it started but a fw seconds in this happened
                org.h2.jdbc.JdbcSQLException: IO Exception: "java.io.EOFException"; "/home/ubuntu/mango/databases/mah2.h2.db"; SQL statement: select pv.dataPointId, pv.dataType, pv.pointValue, pva.textPointValueShort, pva.textPointValueLong, pv.ts, pva.sourceMessage from pointValues pv left join pointValueAnnotations pva on pv.id = pva.pointValueId [90031-196]
                File corrupted while reading record: "page[136688] b-tree leaf table:78 entries:161". Possible solution: use the recovery tool; SQL statement: COMMIT [90030-196]
                And during startup I get this
                INFO  2018-02-06T09:54:10,202 (com.serotonin.m2m2.Lifecycle.initialize:218) - Initializing Spring Object Mapper
                INFO  2018-02-06T09:54:11,248 (com.serotonin.m2m2.Lifecycle.loadLic:523) - Checking license...
                INFO  2018-02-06T09:54:11,532 (com.serotonin.m2m2.db.H2Proxy.initializeImpl:42) - Initializing H2 connection manager
                FATAL 2018-02-06T09:54:14,143 (com.serotonin.m2m2.db.AbstractDatabaseProxy.initialize:160) - Unable to connect to database of type H2
                org.springframework.jdbc.CannotGetJdbcConnectionException: Could not get JDBC Connection; nested exception is org.h2.jdbc.JdbcSQLException: File corrupted while reading record: "index not found 74". Possible solution: use the recovery tool [90030-196]
                        at org.springframework.jdbc.datasource.DataSourceUtils.getConnection(DataSourceUtils.java:80) ~[spring-jdbc-4.3.13.RELEASE.jar:4.3.13.RELEASE]
                        at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:625) ~[spring-jdbc-4.3.13.RELEASE.jar:4.3.13.RELEASE]
                        at org.springframework.jdbc.core.JdbcTemplate.query(JdbcTemplate.java:690) ~[spring-jdbc-4.3.13.RELEASE.jar:4.3.13.RELEASE]
                        at org.springframework.jdbc.core.JdbcTemplate.query(JdbcTemplate.java:722) ~[spring-jdbc-4.3.13.RELEASE.jar:4.3.13.RELEASE]
                        at org.springframework.jdbc.core.JdbcTemplate.query(JdbcTemplate.java:732) ~[spring-jdbc-4.3.13.RELEASE.jar:4.3.13.RELEASE]
                        at com.serotonin.db.spring.ExtendedJdbcTemplate.queryForObject(ExtendedJdbcTemplate.java:39) ~[mango-3.3.0.jar:?]
                        at com.serotonin.db.spring.ExtendedJdbcTemplate.queryForObject(ExtendedJdbcTemplate.java:63) ~[mango-3.3.0.jar:?]
                        at com.serotonin.m2m2.db.H2Proxy.tableExists(H2Proxy.java:256) ~[mango-3.3.0.jar:?]
                        at com.serotonin.m2m2.db.AbstractDatabaseProxy.newDatabaseCheck(AbstractDatabaseProxy.java:178) ~[mango-3.3.0.jar:?]
                        at com.serotonin.m2m2.db.AbstractDatabaseProxy.initialize(AbstractDatabaseProxy.java:81) [mango-3.3.0.jar:?]
                        at com.serotonin.m2m2.Lifecycle.databaseInitialize(Lifecycle.java:667) [ma-priv-3.3.0.jar:?]
                        at com.serotonin.m2m2.Lifecycle.initialize(Lifecycle.java:289) [ma-priv-3.3.0.jar:?]
                        at com.serotonin.m2m2.Main.main(Main.java:127) [ma-priv-3.3.0.jar:?]
                Caused by: org.h2.jdbc.JdbcSQLException: File corrupted while reading record: "index not found 74". Possible solution: use the recovery tool [90030-196]
                        at org.h2.message.DbException.getJdbcSQLException(DbException.java:345) ~[h2-1.4.196.jar:1.4.196]
                        at org.h2.message.DbException.get(DbException.java:179) ~[h2-1.4.196.jar:1.4.196]
                        at org.h2.message.DbException.get(DbException.java:155) ~[h2-1.4.196.jar:1.4.196]
                        at org.h2.store.PageStore.getPage(PageStore.java:769) ~[h2-1.4.196.jar:1.4.196]
                        at org.h2.index.PageDataIndex.getPage(PageDataIndex.java:232) ~[h2-1.4.196.jar:1.4.196]
                        at org.h2.index.PageDataNode.getRowCount(PageDataNode.java:289) ~[h2-1.4.196.jar:1.4.196]
                        at org.h2.index.PageDataIndex.<init>(PageDataIndex.java:87) ~[h2-1.4.196.jar:1.4.196]
                        at org.h2.table.RegularTable.<init>(RegularTable.java:83) ~[h2-1.4.196.jar:1.4.196]
                        at org.h2.store.PageStore.addMeta(PageStore.java:1697) ~[h2-1.4.196.jar:1.4.196]
                        at org.h2.store.PageStore.readMetaData(PageStore.java:1628) ~[h2-1.4.196.jar:1.4.196]
                        at org.h2.store.PageStore.recover(PageStore.java:1406) ~[h2-1.4.196.jar:1.4.196]
                        at org.h2.store.PageStore.openExisting(PageStore.java:368) ~[h2-1.4.196.jar:1.4.196]
                        at org.h2.store.PageStore.open(PageStore.java:289) ~[h2-1.4.196.jar:1.4.196]
                        at org.h2.engine.Database.getPageStore(Database.java:2490) ~[h2-1.4.196.jar:1.4.196]
                        at org.h2.engine.Database.open(Database.java:697) ~[h2-1.4.196.jar:1.4.196]
                        at org.h2.engine.Database.openDatabase(Database.java:276) ~[h2-1.4.196.jar:1.4.196]
                        at org.h2.engine.Database.<init>(Database.java:270) ~[h2-1.4.196.jar:1.4.196]
                        at org.h2.engine.Engine.openSession(Engine.java:64) ~[h2-1.4.196.jar:1.4.196]
                        at org.h2.engine.Engine.openSession(Engine.java:176) ~[h2-1.4.196.jar:1.4.196]
                        at org.h2.engine.Engine.createSessionAndValidate(Engine.java:154) ~[h2-1.4.196.jar:1.4.196]
                        at org.h2.engine.Engine.createSession(Engine.java:137) ~[h2-1.4.196.jar:1.4.196]
                        at org.h2.engine.Engine.createSession(Engine.java:27) ~[h2-1.4.196.jar:1.4.196]
                        at org.h2.engine.SessionRemote.connectEmbeddedOrServer(SessionRemote.java:354) ~[h2-1.4.196.jar:1.4.196]
                        at org.h2.jdbc.JdbcConnection.<init>(JdbcConnection.java:116) ~[h2-1.4.196.jar:1.4.196]
                        at org.h2.jdbc.JdbcConnection.<init>(JdbcConnection.java:100) ~[h2-1.4.196.jar:1.4.196]
                        at org.h2.Driver.connect(Driver.java:69) ~[h2-1.4.196.jar:1.4.196]
                        at org.h2.jdbcx.JdbcDataSource.getJdbcConnection(JdbcDataSource.java:188) ~[h2-1.4.196.jar:1.4.196]
                        at org.h2.jdbcx.JdbcDataSource.getXAConnection(JdbcDataSource.java:351) ~[h2-1.4.196.jar:1.4.196]
                        at org.h2.jdbcx.JdbcDataSource.getPooledConnection(JdbcDataSource.java:383) ~[h2-1.4.196.jar:1.4.196]
                        at org.h2.jdbcx.JdbcConnectionPool.getConnectionNow(JdbcConnectionPool.java:226) ~[h2-1.4.196.jar:1.4.196]
                        at org.h2.jdbcx.JdbcConnectionPool.getConnection(JdbcConnectionPool.java:198) ~[h2-1.4.196.jar:1.4.196]
                        at org.springframework.jdbc.datasource.DataSourceUtils.doGetConnection(DataSourceUtils.java:111) ~[spring-jdbc-4.3.13.RELEASE.jar:4.3.13.RELEASE]
                        at org.springframework.jdbc.datasource.DataSourceUtils.getConnection(DataSourceUtils.java:77) ~[spring-jdbc-4.3.13.RELEASE.jar:4.3.13.RELEASE]
                        ... 12 more
                ERROR 2018-02-06T09:54:14,155 (com.serotonin.m2m2.Main.main:131) - Error during initialization
                        at com.serotonin.m2m2.db.AbstractDatabaseProxy.initialize(AbstractDatabaseProxy.java:81) ~[mango-3.3.0.jar:?]
                        at com.serotonin.m2m2.Lifecycle.databaseInitialize(Lifecycle.java:667) ~[ma-priv-3.3.0.jar:?]
                        at com.serotonin.m2m2.Lifecycle.initialize(Lifecycle.java:289) ~[ma-priv-3.3.0.jar:?]
                        ... 12 more
                INFO  2018-02-06T09:54:14,156 (com.serotonin.m2m2.Lifecycle.terminate:382) - Mango Lifecycle terminating...
                INFO  2018-02-06T09:54:14,168 (com.infiniteautomation.nosql.MangoNoSqlProxy.shutdown:115) - Terminating NoSQL Batch Write Manager.
                INFO  2018-02-06T09:54:14,181 (com.serotonin.m2m2.Lifecycle.terminate:491) - Mango Lifecycle terminated.
                Hooray! :)
                • P
                  I restored a backup from this morning and removed the NoSQL databases module, system is running for now.
                  • phildunlap
                    phildunlap last edited by
                    Not sure what happened there. When we attempted the migration together, it worked without issue.
                    • P
                      There is an old acronym, PEBKAC....
