    Migrate from SQL to NoSQL
    9 Posts 3 Posters 1.5k Views 2 Watching
      psysak
      Just finally purchased a license for a full Mango instance and would like to migrate over to NoSQL. Are there any guides to do that?
        https://help.infiniteautomation.com/migrating-into-nosql/
          psysak
          Of course! Sorry about that, and thanks Joel
            psysak
            OK let me ask this. There are a couple of articles there, the one you referenced and this one
            https://help.infiniteautomation.com/database-conversions/
            So if I understand correctly, H2 is the "configuration" db and then the historical db is the one which is stored in mysql and the one I am attempting to migrate now?
            Also that little db icon doesn't exist anymore on the menu.
              psysak
              OK!! I don't have the module installed, that would do it!
                psysak
                Finally got it started but a fw seconds in this happened
                org.h2.jdbc.JdbcSQLException: IO Exception: "java.io.EOFException"; "/home/ubuntu/mango/databases/mah2.h2.db"; SQL statement: select pv.dataPointId, pv.dataType, pv.pointValue, pva.textPointValueShort, pva.textPointValueLong, pv.ts, pva.sourceMessage from pointValues pv left join pointValueAnnotations pva on pv.id = pva.pointValueId [90031-196]
                File corrupted while reading record: "page[136688] b-tree leaf table:78 entries:161". Possible solution: use the recovery tool; SQL statement: COMMIT [90030-196]
                And during startup I get this
                INFO  2018-02-06T09:54:10,202 (com.serotonin.m2m2.Lifecycle.initialize:218) - Initializing Spring Object Mapper
                INFO  2018-02-06T09:54:11,248 (com.serotonin.m2m2.Lifecycle.loadLic:523) - Checking license...
                INFO  2018-02-06T09:54:11,532 (com.serotonin.m2m2.db.H2Proxy.initializeImpl:42) - Initializing H2 connection manager
                FATAL 2018-02-06T09:54:14,143 (com.serotonin.m2m2.db.AbstractDatabaseProxy.initialize:160) - Unable to connect to database of type H2
                org.springframework.jdbc.CannotGetJdbcConnectionException: Could not get JDBC Connection; nested exception is org.h2.jdbc.JdbcSQLException: File corrupted while reading record: "index not found 74". Possible solution: use the recovery tool [90030-196]
                        at org.springframework.jdbc.datasource.DataSourceUtils.getConnection(DataSourceUtils.java:80) ~[spring-jdbc-4.3.13.RELEASE.jar:4.3.13.RELEASE]
                        at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:625) ~[spring-jdbc-4.3.13.RELEASE.jar:4.3.13.RELEASE]
                        at org.springframework.jdbc.core.JdbcTemplate.query(JdbcTemplate.java:690) ~[spring-jdbc-4.3.13.RELEASE.jar:4.3.13.RELEASE]
                        at org.springframework.jdbc.core.JdbcTemplate.query(JdbcTemplate.java:722) ~[spring-jdbc-4.3.13.RELEASE.jar:4.3.13.RELEASE]
                        at org.springframework.jdbc.core.JdbcTemplate.query(JdbcTemplate.java:732) ~[spring-jdbc-4.3.13.RELEASE.jar:4.3.13.RELEASE]
                        at com.serotonin.db.spring.ExtendedJdbcTemplate.queryForObject(ExtendedJdbcTemplate.java:39) ~[mango-3.3.0.jar:?]
                        at com.serotonin.db.spring.ExtendedJdbcTemplate.queryForObject(ExtendedJdbcTemplate.java:63) ~[mango-3.3.0.jar:?]
                        at com.serotonin.m2m2.db.H2Proxy.tableExists(H2Proxy.java:256) ~[mango-3.3.0.jar:?]
                        at com.serotonin.m2m2.db.AbstractDatabaseProxy.newDatabaseCheck(AbstractDatabaseProxy.java:178) ~[mango-3.3.0.jar:?]
                        at com.serotonin.m2m2.db.AbstractDatabaseProxy.initialize(AbstractDatabaseProxy.java:81) [mango-3.3.0.jar:?]
                        at com.serotonin.m2m2.Lifecycle.databaseInitialize(Lifecycle.java:667) [ma-priv-3.3.0.jar:?]
                        at com.serotonin.m2m2.Lifecycle.initialize(Lifecycle.java:289) [ma-priv-3.3.0.jar:?]
                        at com.serotonin.m2m2.Main.main(Main.java:127) [ma-priv-3.3.0.jar:?]
                Caused by: org.h2.jdbc.JdbcSQLException: File corrupted while reading record: "index not found 74". Possible solution: use the recovery tool [90030-196]
                        at org.h2.message.DbException.getJdbcSQLException(DbException.java:345) ~[h2-1.4.196.jar:1.4.196]
                        at org.h2.message.DbException.get(DbException.java:179) ~[h2-1.4.196.jar:1.4.196]
                        at org.h2.message.DbException.get(DbException.java:155) ~[h2-1.4.196.jar:1.4.196]
                        at org.h2.store.PageStore.getPage(PageStore.java:769) ~[h2-1.4.196.jar:1.4.196]
                        at org.h2.index.PageDataIndex.getPage(PageDataIndex.java:232) ~[h2-1.4.196.jar:1.4.196]
                        at org.h2.index.PageDataNode.getRowCount(PageDataNode.java:289) ~[h2-1.4.196.jar:1.4.196]
                        at org.h2.index.PageDataIndex.<init>(PageDataIndex.java:87) ~[h2-1.4.196.jar:1.4.196]
                        at org.h2.table.RegularTable.<init>(RegularTable.java:83) ~[h2-1.4.196.jar:1.4.196]
                        at org.h2.store.PageStore.addMeta(PageStore.java:1697) ~[h2-1.4.196.jar:1.4.196]
                        at org.h2.store.PageStore.readMetaData(PageStore.java:1628) ~[h2-1.4.196.jar:1.4.196]
                        at org.h2.store.PageStore.recover(PageStore.java:1406) ~[h2-1.4.196.jar:1.4.196]
                        at org.h2.store.PageStore.openExisting(PageStore.java:368) ~[h2-1.4.196.jar:1.4.196]
                        at org.h2.store.PageStore.open(PageStore.java:289) ~[h2-1.4.196.jar:1.4.196]
                        at org.h2.engine.Database.getPageStore(Database.java:2490) ~[h2-1.4.196.jar:1.4.196]
                        at org.h2.engine.Database.open(Database.java:697) ~[h2-1.4.196.jar:1.4.196]
                        at org.h2.engine.Database.openDatabase(Database.java:276) ~[h2-1.4.196.jar:1.4.196]
                        at org.h2.engine.Database.<init>(Database.java:270) ~[h2-1.4.196.jar:1.4.196]
                        at org.h2.engine.Engine.openSession(Engine.java:64) ~[h2-1.4.196.jar:1.4.196]
                        at org.h2.engine.Engine.openSession(Engine.java:176) ~[h2-1.4.196.jar:1.4.196]
                        at org.h2.engine.Engine.createSessionAndValidate(Engine.java:154) ~[h2-1.4.196.jar:1.4.196]
                        at org.h2.engine.Engine.createSession(Engine.java:137) ~[h2-1.4.196.jar:1.4.196]
                        at org.h2.engine.Engine.createSession(Engine.java:27) ~[h2-1.4.196.jar:1.4.196]
                        at org.h2.engine.SessionRemote.connectEmbeddedOrServer(SessionRemote.java:354) ~[h2-1.4.196.jar:1.4.196]
                        at org.h2.jdbc.JdbcConnection.<init>(JdbcConnection.java:116) ~[h2-1.4.196.jar:1.4.196]
                        at org.h2.jdbc.JdbcConnection.<init>(JdbcConnection.java:100) ~[h2-1.4.196.jar:1.4.196]
                        at org.h2.Driver.connect(Driver.java:69) ~[h2-1.4.196.jar:1.4.196]
                        at org.h2.jdbcx.JdbcDataSource.getJdbcConnection(JdbcDataSource.java:188) ~[h2-1.4.196.jar:1.4.196]
                        at org.h2.jdbcx.JdbcDataSource.getXAConnection(JdbcDataSource.java:351) ~[h2-1.4.196.jar:1.4.196]
                        at org.h2.jdbcx.JdbcDataSource.getPooledConnection(JdbcDataSource.java:383) ~[h2-1.4.196.jar:1.4.196]
                        at org.h2.jdbcx.JdbcConnectionPool.getConnectionNow(JdbcConnectionPool.java:226) ~[h2-1.4.196.jar:1.4.196]
                        at org.h2.jdbcx.JdbcConnectionPool.getConnection(JdbcConnectionPool.java:198) ~[h2-1.4.196.jar:1.4.196]
                        at org.springframework.jdbc.datasource.DataSourceUtils.doGetConnection(DataSourceUtils.java:111) ~[spring-jdbc-4.3.13.RELEASE.jar:4.3.13.RELEASE]
                        at org.springframework.jdbc.datasource.DataSourceUtils.getConnection(DataSourceUtils.java:77) ~[spring-jdbc-4.3.13.RELEASE.jar:4.3.13.RELEASE]
                        ... 12 more
                ERROR 2018-02-06T09:54:14,155 (com.serotonin.m2m2.Main.main:131) - Error during initialization
                        at com.serotonin.m2m2.db.AbstractDatabaseProxy.initialize(AbstractDatabaseProxy.java:81) ~[mango-3.3.0.jar:?]
                        at com.serotonin.m2m2.Lifecycle.databaseInitialize(Lifecycle.java:667) ~[ma-priv-3.3.0.jar:?]
                        at com.serotonin.m2m2.Lifecycle.initialize(Lifecycle.java:289) ~[ma-priv-3.3.0.jar:?]
                        ... 12 more
                INFO  2018-02-06T09:54:14,156 (com.serotonin.m2m2.Lifecycle.terminate:382) - Mango Lifecycle terminating...
                INFO  2018-02-06T09:54:14,168 (com.infiniteautomation.nosql.MangoNoSqlProxy.shutdown:115) - Terminating NoSQL Batch Write Manager.
                INFO  2018-02-06T09:54:14,181 (com.serotonin.m2m2.Lifecycle.terminate:491) - Mango Lifecycle terminated.
                Hooray! :)
                  psysak
                  I restored a backup from this morning and removed the NoSQL databases module, system is running for now.
                    Not sure what happened there. When we attempted the migration together, it worked without issue.
                      psysak
                      There is an old acronym, PEBKAC....
