    Major Errors in Logs, but Everything Seems to Work
    6 Posts 2 Posters 1.9k Views 2 Watching
      mihairosu
      MangoES v2
      Mango Core 3.2.2+20171009170034 (just updated prior to these problems)
      I just updated to the latest Oracle 8 Java 151 (may or may not have anything to do with it)
      I am seeing 10,000+ errors of this kind as of this morning:
      Push: Broken pipe (Write failed) for a Mango Persistent TSP publisher.
      Also lots of these in lots sometimes every 10 min, sometimes every few min:
      WARN  2017-12-13T09:10:20,001 (com.serotonin.m2m2.util.timeout.TaskRejectionHandler.rejectedTask:75) - Rejected task: Polling Data Source: Commport0_boilers because Task Queue Full
      However, Live Data is arriving at the destination of the publisher just fine, because I can see data updates. Also see status:
      Point count: 153
      Update queue size: 0
      Connection: connected at port 57402
      Packet queue size: 0
      History sync status: completed 0 of 153 point(s), 97 requests sent, 0.0 points/s, total time: 8 minutes, 9 seconds and 679 milliseconds
      Packets sent during last 5 minutes: 5126
      Any idea what's going on?
        Yes, it is probably the same issue Aldo had here: https://forum.infiniteautomation.com/topic/3141/persistent-tcp-from-2-8-publisher-to-3-2-data-source-broken-pipe-write-failed
        And the same solution will likely work - save the data source again (no need to change anything on that page).
          mihairosu
          I tried to save it and am getting the error:
          Missing method or missing parameter converters
            Hmm. That may be your cache or your work folder.
            You could export the data source and change "pathPrefix":null to "pathPrefix":[] then import it.
              mihairosu
              I exported the Publisher, changed that value and now re-imported.
              I did another export and as you can see here, the value has stuck:
              ......etc......
              "logCount":1,
                     "logSize":1.0,
                     "maxPointValuesToSend":5000,
                     "parallelSyncTasks":100,
                     "pathPrefix":[
                     "port":9901,
              ......etc......
              I tried to Save, and I was getting the same error.
              Then I cleared my browser cache, and I could save without error, though I am still getting:
              10:44:26: Push to Main Historian: Broken pipe (Write failed)
                Hmm. It's possible that it's caused by another error. If you aren't seeing any, you could try launching Mango from the command line. It's possible the answer is escaping to stderr. If it isn't the pathPrefix being null, my next suspicion would be an invalid configuration on one of the points. But, I would have expected you to have gotten a log message from those things.
