    Mango Installation Stuck at Starting Mango (Windows)
    25 Posts 6 Posters 34.2k Views 5 Watching
      Hi bux236,
      I would expect that to be a path problem. Either you haven't defined JAVA_HOME to point at your JDK root directory, jdk1.8.0_xxx/bin/ is not on your path, or you have installed a JRE instead of a JDK.
      • B Offline
        bux236
        Hello,
        Thank you for your reply, I have now set JDK in the JAVA_HOME.
        I now getting the following errors when trying to run upgrade.bat or mastart.bat
        C:\Program Files (x86)\mango automation\bin>upgrade.bat
        Running upgrade script...
        Using C:\Program Files (x86)\mango automation as MA_HOME
        C:\Program Files (x86)\mango automation\overrides\classes;C:\Program Files (x86)
        \mango automation\classes;C:\Program Files (x86)\mango automation\overrides\prop
        erties;C:\Program Files (x86)\mango automation\overrides\lib\*;C:\Program Files
        (x86)\mango automation\lib\*
        Using Java at C:\Program Files\Java\jdk1.8.0_65\bin\java
        Error: Could not find or load main class com.serotonin.m2m2.Main
        C:\Program Files (x86)\mango automation\bin>ma-start.bat
        C:\Program Files (x86)\mango automation\bin>```
        What am I doing wrong please!?
        Many Thanks,
        Chris
          That means there is no ma-priv-3.x.x.jar JAR file in the directories specified on the path output after "Using ... as MA_HOME"
          Running upgrade.bat is only sufficient to upgrade anything if you already have the new m2m2-core-3.x.x.zip in your Mango/ directory. Then you would have seen this message from ma-start.bat:
          Core upgrade found...
          So my guess is something has gone wrong with your upgrading, and you should place an m2m2-core-3.x.x.zip in your Mango/ directory and restart Mango.
          • B Offline
            bux236
            Hi Phildunlap,
            That did the trick!
            Thanks for you help
            Chris
              Glad to hear you got it resolved!
