    Mango Installation Stuck at Starting Mango (Windows)
    25 Posts 6 Posters 34.9k Views 5 Watching
      Thanks for getting us that console output!
        stensma @phildunlap
        @phildunlap It looks like the same issue i have posted on my mini mac
        I got the java to hang.
        Please provide the same info and post a answer on the forum what happens
          Hi stensma,
          We'll be releasing the fix in 3.2.1 on Monday most likely. I will go ahead and email you the fix too, but you'll want to delete it next time you update.
          That sentence is an imperative! You can consult github if you like, but it's a bug. mmmmmt's thread dump is what happens.
            3.2.1 was released with this fix and a few other updates.
            • B Offline
              bux236
              I'm getting the following msg when Starting after performing an upgrade,
              "Core upgrade found...
              No Jar utility found to extract upgrade, Please manually unzip core upgrade and
              restart Mango..."
              How do I rectify this please?
                Hi bux236,
                I would expect that to be a path problem. Either you haven't defined JAVA_HOME to point at your JDK root directory, jdk1.8.0_xxx/bin/ is not on your path, or you have installed a JRE instead of a JDK.
                • B Offline
                  bux236
                  Thank you for your reply, I have now set JDK in the JAVA_HOME.
                  I now getting the following errors when trying to run upgrade.bat or mastart.bat
                  C:\Program Files (x86)\mango automation\bin>upgrade.bat
                  Running upgrade script...
                  Using C:\Program Files (x86)\mango automation as MA_HOME
                  C:\Program Files (x86)\mango automation\overrides\classes;C:\Program Files (x86)
                  \mango automation\classes;C:\Program Files (x86)\mango automation\overrides\prop
                  erties;C:\Program Files (x86)\mango automation\overrides\lib\*;C:\Program Files
                  (x86)\mango automation\lib\*
                  Using Java at C:\Program Files\Java\jdk1.8.0_65\bin\java
                  Error: Could not find or load main class com.serotonin.m2m2.Main
                  C:\Program Files (x86)\mango automation\bin>ma-start.bat
                  C:\Program Files (x86)\mango automation\bin>```
                  What am I doing wrong please!?
                  Many Thanks,
                  Chris
                    That means there is no ma-priv-3.x.x.jar JAR file in the directories specified on the path output after "Using ... as MA_HOME"
                    Running upgrade.bat is only sufficient to upgrade anything if you already have the new m2m2-core-3.x.x.zip in your Mango/ directory. Then you would have seen this message from ma-start.bat:
                    So my guess is something has gone wrong with your upgrading, and you should place an m2m2-core-3.x.x.zip in your Mango/ directory and restart Mango.
                    • B Offline
                      bux236
                      Hi Phildunlap,
                      That did the trick!
                      Thanks for you help
                      Chris
                        Glad to hear you got it resolved!
