<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Mango Installation Stuck at Starting Mango (Windows)]]></title><description><![CDATA[<p dir="auto"><img src="https://camo.nodebb.org/a2c64863f923213ec61186c69fec09c04cea0c85?url=https%3A%2F%2Fi.imgur.com%2FK4Ykh84.png" alt="0_1502939649890_screenshot.png" class=" img-fluid img-markdown" /><br />
It's just stuck there with no error message.</p>
<p dir="auto">Log below in case of the screenshot not showing.<br />
Using E:\TestProject\free-m2m2-core-3.2.0 as MA_HOME<br />
E:\TestProject\free-m2m2-core-3.2.0\overrides\classes;E:\TestProject\free-m2m2-c<br />
ore-3.2.0\classes;E:\TestProject\free-m2m2-core-3.2.0\overrides\properties;E:\Te<br />
stProject\free-m2m2-core-3.2.0\overrides\lib*;E:\TestProject\free-m2m2-core-3.2<br />
.0\lib*<br />
Using Java at java<br />
INFO  2017-08-17T11:10:00,481 (com.serotonin.m2m2.Main.main:90) - Starting Mango<br />
3.2.0+20170807191436 with Schema Version: 17</p>
]]></description><link>https://forum.mango-os.com/topic/2898/mango-installation-stuck-at-starting-mango-windows</link><generator>RSS for Node</generator><lastBuildDate>Wed, 19 Aug 2026 21:37:32 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/2898.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 17 Aug 2017 03:11:25 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Mango Installation Stuck at Starting Mango (Windows) on Mon, 30 Oct 2017 14:59:32 GMT]]></title><description><![CDATA[<p dir="auto">Glad to hear you got it resolved!</p>
]]></description><link>https://forum.mango-os.com/post/16008</link><guid isPermaLink="true">https://forum.mango-os.com/post/16008</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Mon, 30 Oct 2017 14:59:32 GMT</pubDate></item><item><title><![CDATA[Reply to Mango Installation Stuck at Starting Mango (Windows) on Mon, 30 Oct 2017 09:38:46 GMT]]></title><description><![CDATA[<p dir="auto">Hi Phildunlap,</p>
<p dir="auto">That did the trick!</p>
<p dir="auto">Thanks for you help<br />
Chris</p>
]]></description><link>https://forum.mango-os.com/post/16006</link><guid isPermaLink="true">https://forum.mango-os.com/post/16006</guid><dc:creator><![CDATA[bux236]]></dc:creator><pubDate>Mon, 30 Oct 2017 09:38:46 GMT</pubDate></item><item><title><![CDATA[Reply to Mango Installation Stuck at Starting Mango (Windows) on Sun, 29 Oct 2017 14:44:20 GMT]]></title><description><![CDATA[<p dir="auto">That means there is no ma-priv-3.x.x.jar JAR file in the directories specified on the path output after "Using ... as MA_HOME"</p>
<p dir="auto">Running upgrade.bat is only sufficient to upgrade anything if you already have the new m2m2-core-3.x.x.zip in your Mango/ directory. Then you would have seen this message from ma-start.bat:</p>
<p dir="auto"><code>Core upgrade found...</code></p>
<p dir="auto">So my guess is something has gone wrong with your upgrading, and you should place an m2m2-core-3.x.x.zip in your Mango/ directory and restart Mango.</p>
]]></description><link>https://forum.mango-os.com/post/15997</link><guid isPermaLink="true">https://forum.mango-os.com/post/15997</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Sun, 29 Oct 2017 14:44:20 GMT</pubDate></item><item><title><![CDATA[Reply to Mango Installation Stuck at Starting Mango (Windows) on Sun, 29 Oct 2017 11:27:17 GMT]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">Thank you for your reply, I have now set JDK in the JAVA_HOME.</p>
<p dir="auto">I now getting the following errors when trying to run upgrade.bat or mastart.bat</p>
<pre><code>C:\Program Files (x86)\mango automation\bin&gt;upgrade.bat
Running upgrade script...
Using C:\Program Files (x86)\mango automation as MA_HOME
C:\Program Files (x86)\mango automation\overrides\classes;C:\Program Files (x86)
\mango automation\classes;C:\Program Files (x86)\mango automation\overrides\prop
erties;C:\Program Files (x86)\mango automation\overrides\lib\*;C:\Program Files
(x86)\mango automation\lib\*
Using Java at C:\Program Files\Java\jdk1.8.0_65\bin\java
Error: Could not find or load main class com.serotonin.m2m2.Main
C:\Program Files (x86)\mango automation\bin&gt;ma-start.bat
C:\Program Files (x86)\mango automation\bin&gt;```
<p dir="auto">What am I doing wrong please!?</p>
<p dir="auto">Many Thanks,</p>
<p dir="auto">Chris</p>
]]></description><link>https://forum.mango-os.com/post/15996</link><guid isPermaLink="true">https://forum.mango-os.com/post/15996</guid><dc:creator><![CDATA[bux236]]></dc:creator><pubDate>Sun, 29 Oct 2017 11:27:17 GMT</pubDate></item><item><title><![CDATA[Reply to Mango Installation Stuck at Starting Mango (Windows) on Mon, 16 Oct 2017 15:04:49 GMT]]></title><description><![CDATA[<p dir="auto">Hi bux236,</p>
<p dir="auto">I would expect that to be a path problem. Either you haven't defined JAVA_HOME to point at your JDK root directory, jdk1.8.0_xxx/bin/ is not on your path, or you have installed a JRE instead of a JDK.</p>
]]></description><link>https://forum.mango-os.com/post/15828</link><guid isPermaLink="true">https://forum.mango-os.com/post/15828</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Mon, 16 Oct 2017 15:04:49 GMT</pubDate></item><item><title><![CDATA[Reply to Mango Installation Stuck at Starting Mango (Windows) on Mon, 16 Oct 2017 11:17:20 GMT]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">I'm getting the following msg when Starting after performing an upgrade,</p>
<p dir="auto">"Core upgrade found...<br />
No Jar utility found to extract upgrade, Please manually unzip core upgrade and<br />
restart Mango..."</p>
<p dir="auto">How do I rectify this please?</p>
<p dir="auto">Thanks</p>
]]></description><link>https://forum.mango-os.com/post/15826</link><guid isPermaLink="true">https://forum.mango-os.com/post/15826</guid><dc:creator><![CDATA[bux236]]></dc:creator><pubDate>Mon, 16 Oct 2017 11:17:20 GMT</pubDate></item><item><title><![CDATA[Reply to Mango Installation Stuck at Starting Mango (Windows) on Tue, 29 Aug 2017 15:25:04 GMT]]></title><description><![CDATA[<p dir="auto">3.2.1 was released with this fix and a few other updates.</p>
]]></description><link>https://forum.mango-os.com/post/15318</link><guid isPermaLink="true">https://forum.mango-os.com/post/15318</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Tue, 29 Aug 2017 15:25:04 GMT</pubDate></item><item><title><![CDATA[Reply to Mango Installation Stuck at Starting Mango (Windows) on Thu, 24 Aug 2017 15:17:14 GMT]]></title><description><![CDATA[<p dir="auto">Hi stensma,</p>
<p dir="auto">We'll be releasing the fix in 3.2.1 on Monday most likely. I will go ahead and email you the fix too, but you'll want to delete it next time you update.</p>
<p dir="auto">That sentence is an imperative! You can consult github if you like, but it's a bug. mmmmmt's thread dump is what happens.</p>
]]></description><link>https://forum.mango-os.com/post/15280</link><guid isPermaLink="true">https://forum.mango-os.com/post/15280</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Thu, 24 Aug 2017 15:17:14 GMT</pubDate></item><item><title><![CDATA[Reply to Mango Installation Stuck at Starting Mango (Windows) on Thu, 24 Aug 2017 14:04:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/phildunlap" aria-label="Profile: phildunlap">@<bdi>phildunlap</bdi></a> It looks like the same issue i have posted on my mini mac<br />
I got the java to hang.<br />
Please provide the same info and post a answer on the forum what happens</p>
]]></description><link>https://forum.mango-os.com/post/15279</link><guid isPermaLink="true">https://forum.mango-os.com/post/15279</guid><dc:creator><![CDATA[stensma]]></dc:creator><pubDate>Thu, 24 Aug 2017 14:04:03 GMT</pubDate></item><item><title><![CDATA[Reply to Mango Installation Stuck at Starting Mango (Windows) on Wed, 23 Aug 2017 15:18:53 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for getting us that console output!</p>
]]></description><link>https://forum.mango-os.com/post/15268</link><guid isPermaLink="true">https://forum.mango-os.com/post/15268</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Wed, 23 Aug 2017 15:18:53 GMT</pubDate></item><item><title><![CDATA[Reply to Mango Installation Stuck at Starting Mango (Windows) on Wed, 23 Aug 2017 01:24:22 GMT]]></title><description><![CDATA[<p dir="auto">Issue fixed, thanks.</p>
]]></description><link>https://forum.mango-os.com/post/15266</link><guid isPermaLink="true">https://forum.mango-os.com/post/15266</guid><dc:creator><![CDATA[mmmmmt]]></dc:creator><pubDate>Wed, 23 Aug 2017 01:24:22 GMT</pubDate></item><item><title><![CDATA[Reply to Mango Installation Stuck at Starting Mango (Windows) on Tue, 22 Aug 2017 16:52:37 GMT]]></title><description><![CDATA[<p dir="auto">Hi mmmmt and susana,</p>
<p dir="auto">I have sent you both an email with a possible solution. Please try it and let me know if it solves the issue!</p>
]]></description><link>https://forum.mango-os.com/post/15262</link><guid isPermaLink="true">https://forum.mango-os.com/post/15262</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Tue, 22 Aug 2017 16:52:37 GMT</pubDate></item><item><title><![CDATA[Reply to Mango Installation Stuck at Starting Mango (Windows) on Tue, 22 Aug 2017 11:03:34 GMT]]></title><description><![CDATA[<p dir="auto">Hi, I have the same problem with the new version 3.2.0. when  I try to boot the ma-start in windows and in Linux, it does not work. I did other way too, in the modules folder, I  download  the zip modules with every dependency module and restart too but it does not work either. Now, I have installed the version 3.0 and I want to upgrade because I need to use the SVG object like  "ma-svg"  because of the version 3.0 does not exist. I have Java 8 installed and the version 3.0 is working, then I don't know if the specification have changed or it is a bug in the new version.<br />
Could you tell me what is wrong and how to resolve it?</p>
<p dir="auto">Thank you in advance.</p>
]]></description><link>https://forum.mango-os.com/post/15259</link><guid isPermaLink="true">https://forum.mango-os.com/post/15259</guid><dc:creator><![CDATA[susana]]></dc:creator><pubDate>Tue, 22 Aug 2017 11:03:34 GMT</pubDate></item><item><title><![CDATA[Reply to Mango Installation Stuck at Starting Mango (Windows) on Mon, 21 Aug 2017 15:59:31 GMT]]></title><description><![CDATA[<p dir="auto">Hi mmmmmt,</p>
<p dir="auto">What are your computer's timezone and language settings?</p>
<p dir="auto">If you can, can you post the results of the hard kill on a startup without modules?</p>
]]></description><link>https://forum.mango-os.com/post/15255</link><guid isPermaLink="true">https://forum.mango-os.com/post/15255</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Mon, 21 Aug 2017 15:59:31 GMT</pubDate></item><item><title><![CDATA[Reply to Mango Installation Stuck at Starting Mango (Windows) on Mon, 21 Aug 2017 13:02:22 GMT]]></title><description><![CDATA[<p dir="auto">Is it possible you only have the jre installed and not the jdk? What is the result of "echo $JAVA_HOME"</p>
]]></description><link>https://forum.mango-os.com/post/15254</link><guid isPermaLink="true">https://forum.mango-os.com/post/15254</guid><dc:creator><![CDATA[JoelHaggar]]></dc:creator><pubDate>Mon, 21 Aug 2017 13:02:22 GMT</pubDate></item><item><title><![CDATA[Reply to Mango Installation Stuck at Starting Mango (Windows) on Mon, 21 Aug 2017 01:44:46 GMT]]></title><description><![CDATA[<p dir="auto">I can't quit running by pressing ctrl+c. It seems like nothing works but ctrl+break. When I press ctrl+break, it shows these:</p>
<p dir="auto">Full thread dump Java HotSpot(TM) 64-Bit Server VM (25.144-b01 mixed mode):</p>
<p dir="auto">"SIGINT handler" #15 daemon prio=9 os_prio=2 tid=0x000000005c01f000 nid=0x1ea8 w<br />
aiting for monitor entry [0x00000000579ff000]<br />
java.lang.Thread.State: BLOCKED (on object monitor)<br />
at java.lang.Shutdown.exit(Unknown Source)<br />
- waiting to lock &lt;0x00000000a3ee4f08&gt; (a java.lang.Class for java.lang.<br />
Shutdown)<br />
at java.lang.Terminator$1.handle(Unknown Source)<br />
at sun.misc.Signal$1.run(Unknown Source)<br />
at java.lang.Thread.run(Unknown Source)</p>
<p dir="auto">"pool-1-thread-1" #10 prio=5 os_prio=0 tid=0x000000005c020000 nid=0x2118 in Obje<br />
ct.wait() [0x000000005fb4e000]<br />
java.lang.Thread.State: WAITING (on object monitor)<br />
at java.lang.Object.wait(Native Method)<br />
- waiting on &lt;0x00000000ee3efd80&gt; (a org.apache.logging.log4j.core.appen<br />
der.AsyncAppender$AsyncThread)<br />
at java.lang.Thread.join(Unknown Source)<br />
- locked &lt;0x00000000ee3efd80&gt; (a org.apache.logging.log4j.core.appender.<br />
at org.apache.logging.log4j.core.appender.AsyncAppender.stop(AsyncAppend<br />
er.java:135)<br />
at org.apache.logging.log4j.core.config.AbstractConfiguration.stop(Abstr<br />
actConfiguration.java:336)<br />
at org.apache.logging.log4j.core.LoggerContext.stop(LoggerContext.java:3<br />
51)<br />
at org.apache.logging.log4j.core.LoggerContext$1.run(LoggerContext.java:<br />
279)<br />
at org.apache.logging.log4j.core.util.DefaultShutdownCallbackRegistry$Re<br />
gisteredCancellable.run(DefaultShutdownCallbackRegistry.java:109)<br />
at <a href="http://org.apache.logging.log4j.core.util.DefaultShutdownCallbackRegistry.ru" rel="nofollow ugc">org.apache.logging.log4j.core.util.DefaultShutdownCallbackRegistry.ru</a><br />
n(DefaultShutdownCallbackRegistry.java:74)<br />
<p dir="auto">"SIGINT handler" #14 daemon prio=9 os_prio=2 tid=0x000000005c01e800 nid=0x1fa8 i<br />
n Object.wait() [0x000000005f8ef000]<br />
- waiting on &lt;0x00000000a2920338&gt; (a java.lang.Thread)<br />
- locked &lt;0x00000000a2920338&gt; (a java.lang.Thread)<br />
at java.lang.ApplicationShutdownHooks.runHooks(Unknown Source)<br />
at java.lang.ApplicationShutdownHooks$1.run(Unknown Source)<br />
at java.lang.Shutdown.runHooks(Unknown Source)<br />
at java.lang.Shutdown.sequence(Unknown Source)<br />
- locked &lt;0x00000000a3ee4f08&gt; (a java.lang.Class for java.lang.Shutdown)</p>
<pre><code>    at java.lang.Terminator$1.handle(Unknown Source)
<p dir="auto">"AsyncAppender-async" #11 daemon prio=5 os_prio=0 tid=0x00000000589d7000 nid=0x2<br />
1fc runnable [0x0000000057e6e000]<br />
java.lang.Thread.State: RUNNABLE<br />
at java.util.concurrent.ConcurrentHashMap.computeIfAbsent(Unknown Source<br />
)<br />
- locked &lt;0x00000000ee47c720&gt; (a java.util.concurrent.ConcurrentHashMap$<br />
ReservationNode)<br />
at com.serotonin.m2m2.i18n.Translations.getTranslations(Translations.jav<br />
a:35)<br />
at com.serotonin.m2m2.i18n.Translations.&lt;init&gt;(Translations.java:104)<br />
at com.serotonin.m2m2.i18n.Translations.lambda$getTranslations$0(Transla<br />
tions.java:37)<br />
at com.serotonin.m2m2.i18n.Translations$$Lambda$1/630489928.apply(Unknow<br />
n Source)<br />
)<br />
- locked &lt;0x00000000ee47c6b0&gt; (a java.util.concurrent.ConcurrentHashMap$<br />
a:35)<br />
n Source)<br />
)<br />
a:35)<br />
a:31)<br />
at com.serotonin.m2m2.rt.console.LoggingConsoleRT.&lt;init&gt;(LoggingConsoleR<br />
T.java:34)<br />
at com.serotonin.m2m2.rt.console.LoggingConsoleRT.&lt;clinit&gt;(LoggingConsol<br />
eRT.java:26)<br />
at com.serotonin.m2m2.rt.console.MangoFrontendAppender.append(MangoFront<br />
endAppender.java:70)<br />
at org.apache.logging.log4j.core.config.AppenderControl.tryCallAppender(<br />
AppenderControl.java:156)<br />
at org.apache.logging.log4j.core.config.AppenderControl.callAppender0(Ap<br />
penderControl.java:129)<br />
at org.apache.logging.log4j.core.config.AppenderControl.callAppenderPrev<br />
entRecursion(AppenderControl.java:120)<br />
at org.apache.logging.log4j.core.config.AppenderControl.callAppender(App<br />
enderControl.java:84)<br />
at org.apache.logging.log4j.core.appender.AsyncAppender$AsyncThread.call<br />
Appenders(AsyncAppender.java:459)<br />
at org.apache.logging.log4j.core.appender.AsyncAppender$AsyncThread.run(<br />
AsyncAppender.java:412)</p>
<p dir="auto">"Service Thread" #9 daemon prio=9 os_prio=0 tid=0x00000000571ba800 nid=0x19ac ru<br />
nnable [0x0000000000000000]<br />
java.lang.Thread.State: RUNNABLE</p>
<p dir="auto">"C1 CompilerThread2" #8 daemon prio=9 os_prio=2 tid=0x0000000057132000 nid=0xf74<br />
waiting on condition [0x0000000000000000]<br />
<p dir="auto">"C2 CompilerThread1" #7 daemon prio=9 os_prio=2 tid=0x0000000057131800 nid=0x22e<br />
c waiting on condition [0x0000000000000000]<br />
<p dir="auto">"C2 CompilerThread0" #6 daemon prio=9 os_prio=2 tid=0x000000005712c000 nid=0x229<br />
4 waiting on condition [0x0000000000000000]<br />
<p dir="auto">"Attach Listener" #5 daemon prio=5 os_prio=2 tid=0x0000000057124000 nid=0x21d4 r<br />
unnable [0x0000000000000000]<br />
<p dir="auto">"Signal Dispatcher" #4 daemon prio=9 os_prio=2 tid=0x0000000057123000 nid=0x120c<br />
<p dir="auto">"Finalizer" #3 daemon prio=8 os_prio=1 tid=0x0000000055d1f000 nid=0x22cc in Obje<br />
ct.wait() [0x000000005710e000]<br />
- waiting on &lt;0x00000000ee350db0&gt; (a java.lang.ref.ReferenceQueue$Lock)<br />
at java.lang.ref.ReferenceQueue.remove(Unknown Source)<br />
- locked &lt;0x00000000ee350db0&gt; (a java.lang.ref.ReferenceQueue$Lock)<br />
at java.lang.ref.Finalizer$FinalizerThread.run(Unknown Source)</p>
<p dir="auto">"Reference Handler" #2 daemon prio=10 os_prio=2 tid=0x0000000055cd7800 nid=0x1c8<br />
8 in Object.wait() [0x0000000056e3e000]<br />
- waiting on &lt;0x00000000ee5416d8&gt; (a java.lang.ref.Reference$Lock)<br />
at java.lang.Object.wait(Unknown Source)<br />
at java.lang.ref.Reference.tryHandlePending(Unknown Source)<br />
- locked &lt;0x00000000ee5416d8&gt; (a java.lang.ref.Reference$Lock)<br />
at java.lang.ref.Reference$ReferenceHandler.run(Unknown Source)</p>
<p dir="auto">"main" #1 prio=5 os_prio=0 tid=0x000000000203b800 nid=0x20f4 waiting for monitor<br />
entry [0x000000000238f000]<br />
at java.util.concurrent.ConcurrentHashMap.clear(Unknown Source)<br />
- waiting to lock &lt;0x00000000ee47c720&gt; (a java.util.concurrent.Concurren<br />
tHashMap$ReservationNode)<br />
at com.serotonin.m2m2.i18n.Translations.clearCache(Translations.java:46)</p>
<pre><code>    at com.serotonin.m2m2.Main.main(Main.java:110)
<p dir="auto">"VM Thread" os_prio=2 tid=0x0000000055cd0000 nid=0xca8 runnable</p>
<p dir="auto">"GC task thread#0 (ParallelGC)" os_prio=0 tid=0x0000000002052000 nid=0x218c runn<br />
able</p>
<p dir="auto">"GC task thread#1 (ParallelGC)" os_prio=0 tid=0x0000000002053800 nid=0x142c runn<br />
able</p>
<p dir="auto">"GC task thread#2 (ParallelGC)" os_prio=0 tid=0x0000000002055000 nid=0x23c4 runn<br />
able</p>
<p dir="auto">"GC task thread#3 (ParallelGC)" os_prio=0 tid=0x0000000002058800 nid=0x23e4 runn<br />
able</p>
<p dir="auto">"VM Periodic Task Thread" os_prio=2 tid=0x0000000057223800 nid=0x145c waiting on<br />
condition</p>
<p dir="auto">JNI global references: 230</p>
<p dir="auto">Heap<br />
PSYoungGen      total 218624K, used 67668K [0x00000000e0b80000, 0x00000000ef880<br />
000, 0x0000000100000000)<br />
eden space 196608K, 31% used [0x00000000e0b80000,0x00000000e4858fd0,0x00000000<br />
ecb80000)<br />
from space 22016K, 24% used [0x00000000ee300000,0x00000000ee83c1c0,0x00000000e<br />
f880000)<br />
to   space 23040K, 0% used [0x00000000ecb80000,0x00000000ecb80000,0x00000000ee<br />
200000)<br />
ParOldGen       total 64512K, used 32265K [0x00000000a2200000, 0x00000000a61000<br />
00, 0x00000000e0b80000)<br />
object space 64512K, 50% used [0x00000000a2200000,0x00000000a41825a8,0x0000000<br />
0a6100000)<br />
Metaspace       used 18047K, capacity 18322K, committed 18688K, reserved 106496<br />
0K<br />
class space    used 2408K, capacity 2489K, committed 2560K, reserved 1048576K</p>
]]></description><link>https://forum.mango-os.com/post/15253</link><guid isPermaLink="true">https://forum.mango-os.com/post/15253</guid><dc:creator><![CDATA[mmmmmt]]></dc:creator><pubDate>Mon, 21 Aug 2017 01:44:46 GMT</pubDate></item><item><title><![CDATA[Reply to Mango Installation Stuck at Starting Mango (Windows) on Mon, 21 Aug 2017 01:39:12 GMT]]></title><description><![CDATA[<p dir="auto">java version "1.8.0_144"<br />
Java(TM) SE Runtime Environment (build 1.8.0_144-b01)<br />
Java HotSpot(TM) 64-Bit Server VM (build 25.144-b01, mixed mode)</p>
<p dir="auto">I don't have any antivirus software running on my system.</p>
<p dir="auto">I tried to install version 2.8.8, it worked.</p>
]]></description><link>https://forum.mango-os.com/post/15252</link><guid isPermaLink="true">https://forum.mango-os.com/post/15252</guid><dc:creator><![CDATA[mmmmmt]]></dc:creator><pubDate>Mon, 21 Aug 2017 01:39:12 GMT</pubDate></item><item><title><![CDATA[Reply to Mango Installation Stuck at Starting Mango (Windows) on Fri, 18 Aug 2017 15:27:19 GMT]]></title><description><![CDATA[<p dir="auto">Bizarre. I almost think you should redownload everything. But, that seems like it would error somehow if the files were wrong. I tested the free core download after your post, it worked for me.</p>
<p dir="auto">I wonder,</p>
<li>What's your <code>java -version</code> on the command line?</li>
<li>Could it be some self righteous antivirus software you've installed?</li>
]]></description><link>https://forum.mango-os.com/post/15251</link><guid isPermaLink="true">https://forum.mango-os.com/post/15251</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Fri, 18 Aug 2017 15:27:19 GMT</pubDate></item><item><title><![CDATA[Reply to Mango Installation Stuck at Starting Mango (Windows) on Fri, 18 Aug 2017 00:47:41 GMT]]></title><description><![CDATA[<p dir="auto">The directory doesn't have any zip file. I tried to run with an empty modules folder, still nothing.</p>
]]></description><link>https://forum.mango-os.com/post/15246</link><guid isPermaLink="true">https://forum.mango-os.com/post/15246</guid><dc:creator><![CDATA[mmmmmt]]></dc:creator><pubDate>Fri, 18 Aug 2017 00:47:41 GMT</pubDate></item><item><title><![CDATA[Reply to Mango Installation Stuck at Starting Mango (Windows) on Thu, 17 Aug 2017 15:24:18 GMT]]></title><description><![CDATA[<p dir="auto">For some reason I thought it was later in the boot process. It's at installing/loading modules. Does your Mango/web/modules/ directory still have zip files in it? You mean need to redownload one or more modules. See if things go better with an empty Mango/web/modules/ directory.</p>
]]></description><link>https://forum.mango-os.com/post/15239</link><guid isPermaLink="true">https://forum.mango-os.com/post/15239</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Thu, 17 Aug 2017 15:24:18 GMT</pubDate></item><item><title><![CDATA[Reply to Mango Installation Stuck at Starting Mango (Windows) on Thu, 17 Aug 2017 06:11:08 GMT]]></title><description><![CDATA[<p dir="auto">Yes, and I did not have quick edit mode enabled.</p>
]]></description><link>https://forum.mango-os.com/post/15232</link><guid isPermaLink="true">https://forum.mango-os.com/post/15232</guid><dc:creator><![CDATA[mmmmmt]]></dc:creator><pubDate>Thu, 17 Aug 2017 06:11:08 GMT</pubDate></item><item><title><![CDATA[Reply to Mango Installation Stuck at Starting Mango (Windows) on Thu, 17 Aug 2017 15:15:47 GMT]]></title><description><![CDATA[<p dir="auto">Huh. Are you launching it at the command line?</p>
<pre><code>cd E:\TestProject\free-m2m2-core-3.2.0\bin
ma-start.bat
<p dir="auto">The only other thing that comes to mind in this moment is that you can freeze command prompt's output with clicking and dragging (you may need quick editing enabled for that to happen, and maybe other things). You can usually click in the command prompt and hit enter to continue.</p>
]]></description><link>https://forum.mango-os.com/post/15231</link><guid isPermaLink="true">https://forum.mango-os.com/post/15231</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Thu, 17 Aug 2017 15:15:47 GMT</pubDate></item><item><title><![CDATA[Reply to Mango Installation Stuck at Starting Mango (Windows) on Thu, 17 Aug 2017 05:56:28 GMT]]></title><description><![CDATA[<p dir="auto">The databases folder is empty. I left it there like half an hour.</p>
]]></description><link>https://forum.mango-os.com/post/15230</link><guid isPermaLink="true">https://forum.mango-os.com/post/15230</guid><dc:creator><![CDATA[mmmmmt]]></dc:creator><pubDate>Thu, 17 Aug 2017 05:56:28 GMT</pubDate></item><item><title><![CDATA[Reply to Mango Installation Stuck at Starting Mango (Windows) on Thu, 17 Aug 2017 05:35:17 GMT]]></title><description><![CDATA[<p dir="auto">Hi mmmmmt,</p>
<p dir="auto">I wonder, what is the size of your H2 database? E:\TestProject\free-m2m2-core-3.2.0\databases\mah2.h2.db (unless you're usl MySQL?) How long have you given it?</p>
<p dir="auto">Almost certainly if you rename your E:\TestProject\free-m2m2-core-3.2.0\databases directory it will start on a fresh instance. You can restore either database or configuration backups (which likely would exist if you left it on over night) on the system settings page.</p>
<p dir="auto">Another option is using the h2-web-console.bat script in Mango\bin\ to access the database.</p>
<p dir="auto">The free download bundle comes without the NoSQL module, which can lead to a much larger H2 database. Perhaps allocating more memory by putting a script like one of those in bin\ext-available into ext-enabled\ will help.</p>
]]></description><link>https://forum.mango-os.com/post/15228</link><guid isPermaLink="true">https://forum.mango-os.com/post/15228</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Thu, 17 Aug 2017 05:35:17 GMT</pubDate></item></channel></rss>
