    TCP/IP Data Source examples?
    11 Posts 3 Posters 4.9k Views 3 Watching
    • danD Offline
      dan
      Re: [TCP/IP Data Source](Talking to MOXA Serial RS232?)
      Hey guys, I've been struggling to get anything usable out of my TCP/IP Data Source. It's connecting via a Moxa type media converter IP to Serial adapter.
      I can't get the device on the other end to respond to the commands that the manual says to use.
      Does anyone have any examples of what to put where in the data source for it?
      Cheers
      Dan
      • C Offline
        craig
        Hi Dan,
        I think you need to start with the most basic scenario and work up from there.
        Does the device respond to commands on RS232?
        Does the device respond to commands through the Moxa RS232 to TCP/IP converter? There must be some software out there that talks to this device that you can point at the Moxa. Might need to use the moxa virtual serial port which creates a COM port that redirects to the moxa device over RS232. I've done this on windows and linux before.
        If the existing software for the device can communicate with it through TCP/IP converted to RS232, you can use wireshark to capture the TCP/ip conversation. Then you will have an idea of what you need to send from mango and what response you should get.
        • danD Offline
          dan
          Thanks for the info, I'll give that a go and see how we get on.
          Cheers
          Dan
            Hi Dan,
            If you're working on a Linux system, using "nc" can be very useful when you're playing with the TCP/IP Data Source. Point the data source as linuxhost:9000, run "sudo nc -l 9000" (-k to keep alive) and let the experiments begin!
            • danD Offline
              dan
              ah yes, nc is a great idea. I'll try some tests with that.
              Thanks heaps.
              Cheers
              Dan
              • danD Offline
                dan
                the results are interesting...
                when I enable the data source, I get an echo of the read command I put in the data point, which is good, however if I drill down on the data point and press the refresh button it doesn't re-send the packet to the TCP port.
                  There are a number of data sources who haven't had their forcePointRead method implemented, so that little refresh arrow doesn't do anything. But, I've implemented it in the TCP/IP module, just for you! You can download it through the modules page.
                  Don't forget to:
                  sudo nc -l 9000 <<< 'Mango is awesome!'
                  • danD Offline
                    dan
                    oh! hahaha! you have no idea how many times I pressed the little refresh button then looked at the other monitor to see if something was happening.. that's hilarious!
                    Thanks for enabling that, I'll download it now.
                    Cheers
                    Dan
                    • danD Offline
                      dan
                      I'm supposed to send this to the controller for it to just report back a bunch of stuff..
                      AA 55 AA 55 AA 55 EB 90 EB 90 EB 90 16 A0 00 B1 A7 7F
                      Is there a data source log I can tail to see the transaction happening? And maybe somewhere to see the data that comes back so I can strip back what I need?
                      Cheers
                      Dan
                        Logging can be enabled by adding the line
                        <category name="com.infiniteautomation.tcpip.rt"><level value="debug"/></category>
                        below similar lines in your Mango/classes/log4j.xml file, near the bottom, then either restarting Mango or, if you have log4j-reset installed, by going to your System Settings page in the log4j reset section and reloading the logging configuration. This will output into the normal Mango log file.
                        I'm going to put in a RollingIO log, like Modbus and Serial have, as well as a testing utility and hopefully release it this week. It would make it easier to use, for sure.
                        • danD Offline
                          dan
                          thanks for that I'll give it a go.
