    the datapoint synchronize datasource in mysql datasource.rather than time.
    7 Posts 3 Posters 3.5k Views 2 Watching
    • E Offline
      edmond
      if mysql as datasoruce.how can synchronize the data source. (for example,when insert into a row data ,the datapoint will add a row.Rather than the time to change. That is, the data about the changes in the source data, the corresponding data points are also changed, rather than minutes, seconds, to collect data.
      • BGB Offline
        BG
        Hello Edmund,
        The data points created from a MySQL data source has a setting for the time over ride. Enter the column name of cell that you want to use as the timestamp. Then in the Logging properties section choose "When point timestamp changes" from the Logging Type drop down list.
        I hope this helps.
        Cheers
        Brian
        • E Offline
          edmond
          but when I use your way for test .and I find have no data was displayed.as attachment.
          https://www.dropbox.com/s/2hmbl8y2hdk0etu/1.jpg?dl=0
          I donot know whether my understanding is error.
          when I want to get to 'w'data for mysql.and it is normal from mysql.but when I input 'datetime' in Time override column,datetime is column in mysql. or I try to input 'id' in Time override column.the result is same .no result be display.
          • BGB Offline
            BG
            Hello Edmond,
            How is the timestamp formatted in the datetime column of your MySQL table? Our system is set to use: 'yyyy-mm-dd hh:mm:ss' It may not work if your datetime column is formatted differently from the Mango system.
            Cheers
            Brian
            • E Offline
              edmond
              As attachment https://www.dropbox.com/s/g3h5mtywr3jljyq/2.jpg?dl=0
              the format is same as mango.
              • BGB Offline
                BG
                Hello Edmond,
                I am sorry, I am not sure why it is not working for you as it is for me. I hope someone else can help you with this.
                  Hi edmond, can you post your select statement from your SQL data source? What datatype of sql column is your datetime?
