Navigation
    • Search
    Mango upgrade procedure to preserve existing data in the database
    Mango Automation general Discussion
    2
    5
    1935
    • R
      ray last edited by
      I want to upgrade the Mango from 1.2 to 2.03. What is the procedure so that I can keep the existing data in the database after the version upgrade.
      Thanks !
      • JoelHaggar
        JoelHaggar last edited by
        If you are using m2m2 1.2 it should upgrade just fine. Make a full backup just in case. You will need to purchase a upgrade license after the upgrade but you can run it in free mode to make sure the upgrade as worked.
        Joel.
        • R
          ray last edited by
          Thank you for your quick reply. I try to upgrade but with errors and the process terminated. The errors messages in the ma.log are listed as follows.
          INFO 2012-11-21 12:03:05,303 (com.serotonin.util.properties.ReloadingProperties.checkForReload:142) - (env) Found updated file(s) at [C:\m2m2-2.0.3\classes\env.properties]. Reloading properties
          INFO 2012-11-21 12:03:07,658 (com.serotonin.m2m2.Main.loadModules:222) - Loading module 'graphicalViews', v1.4.0 by Serotonin Software
          INFO 2012-11-21 12:03:07,721 (com.serotonin.m2m2.Main.loadModules:222) - Loading module 'meta', v1.4.0 by Serotonin Software
          INFO 2012-11-21 12:03:07,767 (com.serotonin.m2m2.Main.loadModules:222) - Loading module 'modbus', v1.4.1 by Serotonin Software
          INFO 2012-11-21 12:03:07,799 (com.serotonin.m2m2.Main.loadModules:222) - Loading module 'sstGraphics', v1.0.1 by Serotonin Software
          INFO 2012-11-21 12:03:07,861 (com.serotonin.m2m2.Main.loadModules:222) - Loading module 'virtualDS', v1.4.0 by Serotonin Software
          INFO 2012-11-21 12:03:07,908 (com.serotonin.m2m2.Main.loadModules:222) - Loading module 'watchlists', v1.4.0 by Serotonin Software
          INFO 2012-11-21 12:03:09,187 (com.serotonin.m2m2.db.BasePooledProxy.initializeImpl:36) - Initializing pooled connection manager
          WARN 2012-11-21 12:03:11,433 (com.serotonin.m2m2.db.upgrade.DBUpgrade.checkUpgrade:88) - Upgrading 'core' from 2 to 3
          INFO 2012-11-21 12:03:11,449 (com.serotonin.m2m2.db.upgrade.DBUpgrade.createUpdateLogOutputStream:145) - Writing upgrade log to C:\com.serotonin.m2m2.db.upgrade.Upgrade2.log
          WARN 2012-11-21 12:03:11,449 (com.serotonin.m2m2.db.upgrade.DBUpgrade.createUpdateLogOutputStream:155) - Failing over to console for printing database upgrade messages
          WARN 2012-11-21 12:19:35,318 (com.serotonin.m2m2.db.upgrade.DBUpgrade.checkUpgrade:88) - Upgrading 'core' from 3 to 4
          INFO 2012-11-21 12:19:35,337 (com.serotonin.m2m2.db.upgrade.DBUpgrade.createUpdateLogOutputStream:145) - Writing upgrade log to C:\com.serotonin.m2m2.db.upgrade.Upgrade3.log
          WARN 2012-11-21 12:19:35,338 (com.serotonin.m2m2.db.upgrade.DBUpgrade.createUpdateLogOutputStream:155) - Failing over to console for printing database upgrade messages
          WARN 2012-11-21 12:20:17,938 (com.serotonin.m2m2.db.upgrade.DBUpgrade.checkUpgrade:88) - Upgrading 'core' from 4 to 5
          INFO 2012-11-21 12:20:17,957 (com.serotonin.m2m2.db.upgrade.DBUpgrade.createUpdateLogOutputStream:145) - Writing upgrade log to C:\com.serotonin.m2m2.db.upgrade.Upgrade4.log
          WARN 2012-11-21 12:20:17,959 (com.serotonin.m2m2.db.upgrade.DBUpgrade.createUpdateLogOutputStream:155) - Failing over to console for printing database upgrade messages
          WARN 2012-11-21 12:20:20,634 (com.serotonin.m2m2.db.upgrade.DBUpgrade.checkUpgrade:88) - Upgrading 'core' from 5 to 6
          INFO 2012-11-21 12:20:20,645 (com.serotonin.m2m2.db.upgrade.DBUpgrade.createUpdateLogOutputStream:145) - Writing upgrade log to C:\com.serotonin.m2m2.db.upgrade.Upgrade5.log
          WARN 2012-11-21 12:20:20,646 (com.serotonin.m2m2.db.upgrade.DBUpgrade.createUpdateLogOutputStream:155) - Failing over to console for printing database upgrade messages
          ERROR 2012-11-21 12:20:22,624 (com.serotonin.m2m2.Main.main:88) - Error during initialization
          com.serotonin.ShouldNeverHappenException: org.springframework.jdbc.BadSqlGrammarException: StatementCallback; bad SQL grammar [ALTER TABLE dataPoints ADD COLUMN pointFolderId int; ]; nested exception is com.mysql.jdbc.exceptions.jdbc4.MySQLSyntaxErrorException: Duplicate column name 'pointFolderId'
          at com.serotonin.m2m2.db.upgrade.DBUpgrade.checkUpgrade(DBUpgrade.java:94)
          at com.serotonin.m2m2.db.upgrade.DBUpgrade.checkUpgrade(DBUpgrade.java:34)
          at com.serotonin.m2m2.db.DatabaseProxy.initialize(DatabaseProxy.java:136)
          at com.serotonin.m2m2.Lifecycle.databaseInitialize(Lifecycle.java:412)
          at com.serotonin.m2m2.Lifecycle.initialize(Lifecycle.java:143)
          at com.serotonin.m2m2.Main.main(Main.java:82)
          Caused by: org.springframework.jdbc.BadSqlGrammarException: StatementCallback; bad SQL grammar [ALTER TABLE dataPoints ADD COLUMN pointFolderId int; ]; nested exception is com.mysql.jdbc.exceptions.jdbc4.MySQLSyntaxErrorException: Duplicate column name 'pointFolderId'
          at org.springframework.jdbc.support.SQLExceptionSubclassTranslator.doTranslate(SQLExceptionSubclassTranslator.java:94)
          at org.springframework.jdbc.support.AbstractFallbackSQLExceptionTranslator.translate(AbstractFallbackSQLExceptionTranslator.java:72)
          at org.springframework.jdbc.support.AbstractFallbackSQLExceptionTranslator.translate(AbstractFallbackSQLExceptionTranslator.java:80)
          at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:406)
          at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:427)
          at com.serotonin.m2m2.db.BasePooledProxy.runScript(BasePooledProxy.java:71)
          at com.serotonin.m2m2.db.upgrade.DBUpgrade.runScript(DBUpgrade.java:122)
          at com.serotonin.m2m2.db.upgrade.DBUpgrade.runScript(DBUpgrade.java:136)
          at com.serotonin.m2m2.db.upgrade.DBUpgrade.runScript(DBUpgrade.java:127)
          at com.serotonin.m2m2.db.upgrade.Upgrade5.upgrade(Upgrade5.java:16)
          at com.serotonin.m2m2.db.upgrade.DBUpgrade.checkUpgrade(DBUpgrade.java:90)
          ... 5 more
          Caused by: com.mysql.jdbc.exceptions.jdbc4.MySQLSyntaxErrorException: Duplicate column name 'pointFolderId'
          at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
          at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
          at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
          at java.lang.reflect.Constructor.newInstance(Unknown Source)
          at com.mysql.jdbc.Util.handleNewInstance(Util.java:406)
          at com.mysql.jdbc.Util.getInstance(Util.java:381)
          at com.mysql.jdbc.SQLError.createSQLException(SQLError.java:1030)
          at com.mysql.jdbc.SQLError.createSQLException(SQLError.java:956)
          at com.mysql.jdbc.MysqlIO.checkErrorPacket(MysqlIO.java:3515)
          at com.mysql.jdbc.MysqlIO.checkErrorPacket(MysqlIO.java:3447)
          at com.mysql.jdbc.MysqlIO.sendCommand(MysqlIO.java:1951)
          at com.mysql.jdbc.MysqlIO.sqlQueryDirect(MysqlIO.java:2101)
          at com.mysql.jdbc.ConnectionImpl.execSQL(ConnectionImpl.java:2548)
          at com.mysql.jdbc.ConnectionImpl.execSQL(ConnectionImpl.java:2477)
          at com.mysql.jdbc.StatementImpl.execute(StatementImpl.java:741)
          at com.mysql.jdbc.StatementImpl.execute(StatementImpl.java:587)
          at org.apache.commons.dbcp.DelegatingStatement.execute(DelegatingStatement.java:266)
          at org.springframework.jdbc.core.JdbcTemplate$1ExecuteStatementCallback.doInStatement(JdbcTemplate.java:420)
          at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:395)
          ... 12 more
          INFO 2012-11-21 12:20:22,753 (com.serotonin.m2m2.db.BasePooledProxy.terminate:108) - Stopping database
          By the way, if I use graphicalViews modules in 1.2, do I need to copy some folders/files to the corresponding directory of the 2.0.3 ?
          • JoelHaggar
            Hi Ray,
            Note that in 2.0.3 the name of the database is madb
            You will probably need to change this in the classes\env.properties file to the name of the older database (probably m2m2db). Hopefully that will allow the upgrade to work right.
            Joel.
