    Mango to MS Sql Server 2008
    11 Posts 2 Posters 5.2k Views 1 Watching
      r00t
      hi,
      i'm trying to connect mango to ms sql server 2008 R2, this is my build.propreties file:
      tomcat.home=C:/Program Files/Apache Software Foundation/Tomcat 6.0
      tomcat.manager.url=http://localhost:8080/manager/html
      tomcat.manager.username=manager
      tomcat.manager.password=manager
      tomcat.hostname=webapps
      # App name and app path are separated to accomodate root deployments. (i.e. 'ROOT' vs. '/')
      tomcat.appdir=mango
      tomcat.apppath=/mango
      log4j.xml.logThreshold=warn
      db.type=mssql
      db.url=jdbc:sqlserver://localhost:1433;databaseName=DbMango;integratedSecurity=true;
      db.username=sa
      db.password=
      db.pool.maxActive=10
      db.pool.maxIdle=10
      convert.db.type=derby
      convert.db.url=~/../../bin/DbMango
      convert.db.username=
      convert.db.password=
      grove.url=http://mango.serotoninsoftware.com/servlet
      # This property is only used for building a distribution.
      version=1.0.0
      the BUILD is Succussful but the convert doesn't happen, any suggestion ?
        Check your WEB-INF/classes/env.properties file. Make sure it looks ok.
          r00t
          i've edited "WEB-INF/classes/env.properties" file but still doesn't work
            Ensure that the tables in the mysql schema - but not the schema itself - have been dropped and try again. A conversion will only be run if Mango creates the tables anew.
              r00t
              the database is Ms Sql server not mysql, and i've only created the 'empty' schema ; i let mango creat the tables itself as u said in the mango<->mysql thread somewhere...
                Right, I meant mssql. Ok, are there any startup errors?
                  r00t
                  the app couldn't start; but, if i convert to mysql or derby, it works , so i think i've a mistake only in the connection string
                    Knowing the actual error message that you are getting would be very helpful.
                      r00t
                      here's the log file from tomcat directory: "mango.log"
                      FATAL 2012-01-09 15:44:01,613 (com.serotonin.mango.db.DatabaseAccess.initialize:153) - Unable to connect to database of type MSSQL
                      org.springframework.jdbc.CannotGetJdbcConnectionException: Could not get JDBC Connection; nested exception is org.apache.commons.dbcp.SQLNestedException: Cannot create PoolableConnectionFactory (This driver is not configured for integrated authentication.)
                      	at org.springframework.jdbc.datasource.DataSourceUtils.getConnection(DataSourceUtils.java:82)
                      	at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:381)
                      	at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:428)
                      	at com.serotonin.mango.db.MSSQLAccess.newDatabaseCheck(MSSQLAccess.java:47)
                      	at com.serotonin.mango.db.DatabaseAccess.initialize(DatabaseAccess.java:99)
                      	at com.serotonin.mango.MangoContextListener.databaseInitialize(MangoContextListener.java:255)
                      	at com.serotonin.mango.MangoContextListener.contextInitialized(MangoContextListener.java:94)
                      	at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4206)
                      	at org.apache.catalina.core.StandardContext.start(StandardContext.java:4705)
                      	at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:799)
                      	at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:779)
                      	at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:601)
                      	at org.apache.catalina.startup.HostConfig.deployDirectory(HostConfig.java:1079)
                      	at org.apache.catalina.startup.HostConfig.deployDirectories(HostConfig.java:1002)
                      	at org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:506)
                      	at org.apache.catalina.startup.HostConfig.start(HostConfig.java:1317)
                      	at org.apache.catalina.startup.HostConfig.lifecycleEvent(HostConfig.java:324)
                      	at org.apache.catalina.util.LifecycleSupport.fireLifecycleEvent(LifecycleSupport.java:142)
                      	at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1065)
                      	at org.apache.catalina.core.StandardHost.start(StandardHost.java:840)
                      	at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1057)
                      	at org.apache.catalina.core.StandardEngine.start(StandardEngine.java:463)
                      	at org.apache.catalina.core.StandardService.start(StandardService.java:525)
                      	at org.apache.catalina.core.StandardServer.start(StandardServer.java:754)
                      	at org.apache.catalina.startup.Catalina.start(Catalina.java:595)
                      	at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
                      	at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
                      	at java.lang.reflect.Method.invoke(Unknown Source)
                      	at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:289)
                      	at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:414)
                      Caused by: org.apache.commons.dbcp.SQLNestedException: Cannot create PoolableConnectionFactory (This driver is not configured for integrated authentication.)
                      	at org.apache.commons.dbcp.BasicDataSource.createDataSource(BasicDataSource.java:1232)
                      	at org.apache.commons.dbcp.BasicDataSource.getConnection(BasicDataSource.java:881)
                      	at org.springframework.jdbc.datasource.DataSourceUtils.doGetConnection(DataSourceUtils.java:113)
                      	at org.springframework.jdbc.datasource.DataSourceUtils.getConnection(DataSourceUtils.java:79)
                      	... 30 more
                      Caused by: com.microsoft.sqlserver.jdbc.SQLServerException: This driver is not configured for integrated authentication.
                      	at com.microsoft.sqlserver.jdbc.SQLServerConnection.terminate(SQLServerConnection.java:1352)
                      	at com.microsoft.sqlserver.jdbc.SQLServerConnection.sendLogon(SQLServerConnection.java:2329)
                      	at com.microsoft.sqlserver.jdbc.SQLServerConnection.logon(SQLServerConnection.java:1905)
                      	at com.microsoft.sqlserver.jdbc.SQLServerConnection.access$000(SQLServerConnection.java:41)
                      	at com.microsoft.sqlserver.jdbc.SQLServerConnection$LogonCommand.doExecute(SQLServerConnection.java:1893)
                      	at com.microsoft.sqlserver.jdbc.TDSCommand.execute(IOBuffer.java:4575)
                      	at com.microsoft.sqlserver.jdbc.SQLServerConnection.executeCommand(SQLServerConnection.java:1400)
                      	at com.microsoft.sqlserver.jdbc.SQLServerConnection.connectHelper(SQLServerConnection.java:1045)
                      	at com.microsoft.sqlserver.jdbc.SQLServerConnection.login(SQLServerConnection.java:817)
                      	at com.microsoft.sqlserver.jdbc.SQLServerConnection.connect(SQLServerConnection.java:700)
                      	at com.microsoft.sqlserver.jdbc.SQLServerDriver.connect(SQLServerDriver.java:842)
                      	at org.apache.commons.dbcp.DriverConnectionFactory.createConnection(DriverConnectionFactory.java:38)
                      	at org.apache.commons.dbcp.PoolableConnectionFactory.makeObject(PoolableConnectionFactory.java:294)
                      	at org.apache.commons.dbcp.BasicDataSource.validateConnectionFactory(BasicDataSource.java:1254)
                      	at org.apache.commons.dbcp.BasicDataSource.createDataSource(BasicDataSource.java:1228)
                      	... 33 more
                      Caused by: java.lang.UnsatisfiedLinkError: no sqljdbc_auth in java.library.path
                      	at java.lang.ClassLoader.loadLibrary(Unknown Source)
                      	at java.lang.Runtime.loadLibrary0(Unknown Source)
                      	at java.lang.System.loadLibrary(Unknown Source)
                      	at com.microsoft.sqlserver.jdbc.AuthenticationJNI.<clinit>(AuthenticationJNI.java:32)
                      	at com.microsoft.sqlserver.jdbc.SQLServerConnection.logon(SQLServerConnection.java:1902)
                      	... 45 more
                        I can't really help you with that.
