<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Mango to MS Sql Server 2008]]></title><description><![CDATA[<p dir="auto">hi,<br />
i'm trying to connect mango to ms sql server 2008 R2, this is my build.propreties file:</p>
<pre><code>tomcat.home=C:/Program Files/Apache Software Foundation/Tomcat 6.0
tomcat.manager.url=http://localhost:8080/manager/html
tomcat.manager.username=manager
tomcat.manager.password=manager
tomcat.hostname=webapps
# App name and app path are separated to accomodate root deployments. (i.e. 'ROOT' vs. '/')
tomcat.appdir=mango
tomcat.apppath=/mango
log4j.xml.logThreshold=warn
db.type=mssql
db.url=jdbc:sqlserver://localhost:1433;databaseName=DbMango;integratedSecurity=true;
db.username=sa
db.password=
db.pool.maxActive=10
db.pool.maxIdle=10
convert.db.type=derby
convert.db.url=~/../../bin/DbMango
convert.db.username=
convert.db.password=
grove.url=http://mango.serotoninsoftware.com/servlet
# This property is only used for building a distribution.
version=1.0.0
<p dir="auto">the BUILD is Succussful but the convert doesn't happen, any suggestion ?</p>
]]></description><link>https://forum.mango-os.com/topic/931/mango-to-ms-sql-server-2008</link><generator>RSS for Node</generator><lastBuildDate>Sun, 07 Jun 2026 01:35:48 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/931.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 06 Jan 2012 15:14:21 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Mango to MS Sql Server 2008 on Mon, 09 Jan 2012 20:52:05 GMT]]></title><description><![CDATA[<p dir="auto">I can't really help you with that.</p>
]]></description><link>https://forum.mango-os.com/post/6083</link><guid isPermaLink="true">https://forum.mango-os.com/post/6083</guid><dc:creator><![CDATA[mlohbihler]]></dc:creator><pubDate>Mon, 09 Jan 2012 20:52:05 GMT</pubDate></item><item><title><![CDATA[Reply to Mango to MS Sql Server 2008 on Mon, 09 Jan 2012 20:46:26 GMT]]></title><description><![CDATA[<p dir="auto">here's the log file from tomcat directory:  "mango.log"</p>
<pre><code>FATAL 2012-01-09 15:44:01,613 (com.serotonin.mango.db.DatabaseAccess.initialize:153) - Unable to connect to database of type MSSQL
org.springframework.jdbc.CannotGetJdbcConnectionException: Could not get JDBC Connection; nested exception is org.apache.commons.dbcp.SQLNestedException: Cannot create PoolableConnectionFactory (This driver is not configured for integrated authentication.)
	at org.springframework.jdbc.datasource.DataSourceUtils.getConnection(DataSourceUtils.java:82)
	at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:381)
	at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:428)
	at com.serotonin.mango.db.MSSQLAccess.newDatabaseCheck(MSSQLAccess.java:47)
	at com.serotonin.mango.db.DatabaseAccess.initialize(DatabaseAccess.java:99)
	at com.serotonin.mango.MangoContextListener.databaseInitialize(MangoContextListener.java:255)
	at com.serotonin.mango.MangoContextListener.contextInitialized(MangoContextListener.java:94)
	at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4206)
	at org.apache.catalina.core.StandardContext.start(StandardContext.java:4705)
	at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:799)
	at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:779)
	at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:601)
	at org.apache.catalina.startup.HostConfig.deployDirectory(HostConfig.java:1079)
	at org.apache.catalina.startup.HostConfig.deployDirectories(HostConfig.java:1002)
	at org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:506)
	at org.apache.catalina.startup.HostConfig.start(HostConfig.java:1317)
	at org.apache.catalina.startup.HostConfig.lifecycleEvent(HostConfig.java:324)
	at org.apache.catalina.util.LifecycleSupport.fireLifecycleEvent(LifecycleSupport.java:142)
	at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1065)
	at org.apache.catalina.core.StandardHost.start(StandardHost.java:840)
	at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1057)
	at org.apache.catalina.core.StandardEngine.start(StandardEngine.java:463)
	at org.apache.catalina.core.StandardService.start(StandardService.java:525)
	at org.apache.catalina.core.StandardServer.start(StandardServer.java:754)
	at org.apache.catalina.startup.Catalina.start(Catalina.java:595)
	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
	at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
	at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
	at java.lang.reflect.Method.invoke(Unknown Source)
	at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:289)
	at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:414)
Caused by: org.apache.commons.dbcp.SQLNestedException: Cannot create PoolableConnectionFactory (This driver is not configured for integrated authentication.)
	at org.apache.commons.dbcp.BasicDataSource.createDataSource(BasicDataSource.java:1232)
	at org.apache.commons.dbcp.BasicDataSource.getConnection(BasicDataSource.java:881)
	at org.springframework.jdbc.datasource.DataSourceUtils.doGetConnection(DataSourceUtils.java:113)
	at org.springframework.jdbc.datasource.DataSourceUtils.getConnection(DataSourceUtils.java:79)
	... 30 more
Caused by: com.microsoft.sqlserver.jdbc.SQLServerException: This driver is not configured for integrated authentication.
	at com.microsoft.sqlserver.jdbc.SQLServerConnection.terminate(SQLServerConnection.java:1352)
	at com.microsoft.sqlserver.jdbc.SQLServerConnection.sendLogon(SQLServerConnection.java:2329)
	at com.microsoft.sqlserver.jdbc.SQLServerConnection.logon(SQLServerConnection.java:1905)
	at com.microsoft.sqlserver.jdbc.SQLServerConnection.access$000(SQLServerConnection.java:41)
	at com.microsoft.sqlserver.jdbc.SQLServerConnection$LogonCommand.doExecute(SQLServerConnection.java:1893)
	at com.microsoft.sqlserver.jdbc.TDSCommand.execute(IOBuffer.java:4575)
	at com.microsoft.sqlserver.jdbc.SQLServerConnection.executeCommand(SQLServerConnection.java:1400)
	at com.microsoft.sqlserver.jdbc.SQLServerConnection.connectHelper(SQLServerConnection.java:1045)
	at com.microsoft.sqlserver.jdbc.SQLServerConnection.login(SQLServerConnection.java:817)
	at com.microsoft.sqlserver.jdbc.SQLServerConnection.connect(SQLServerConnection.java:700)
	at com.microsoft.sqlserver.jdbc.SQLServerDriver.connect(SQLServerDriver.java:842)
	at org.apache.commons.dbcp.DriverConnectionFactory.createConnection(DriverConnectionFactory.java:38)
	at org.apache.commons.dbcp.PoolableConnectionFactory.makeObject(PoolableConnectionFactory.java:294)
	at org.apache.commons.dbcp.BasicDataSource.validateConnectionFactory(BasicDataSource.java:1254)
	at org.apache.commons.dbcp.BasicDataSource.createDataSource(BasicDataSource.java:1228)
	... 33 more
Caused by: java.lang.UnsatisfiedLinkError: no sqljdbc_auth in java.library.path
	at java.lang.ClassLoader.loadLibrary(Unknown Source)
	at java.lang.Runtime.loadLibrary0(Unknown Source)
	at java.lang.System.loadLibrary(Unknown Source)
	at com.microsoft.sqlserver.jdbc.AuthenticationJNI.&lt;clinit&gt;(AuthenticationJNI.java:32)
	at com.microsoft.sqlserver.jdbc.SQLServerConnection.logon(SQLServerConnection.java:1902)
	... 45 more
]]></description><link>https://forum.mango-os.com/post/6082</link><guid isPermaLink="true">https://forum.mango-os.com/post/6082</guid><dc:creator><![CDATA[r00t]]></dc:creator><pubDate>Mon, 09 Jan 2012 20:46:26 GMT</pubDate></item><item><title><![CDATA[Reply to Mango to MS Sql Server 2008 on Mon, 09 Jan 2012 20:34:43 GMT]]></title><description><![CDATA[<p dir="auto">Knowing the actual error message that you are getting would be very helpful.</p>
]]></description><link>https://forum.mango-os.com/post/6081</link><guid isPermaLink="true">https://forum.mango-os.com/post/6081</guid><dc:creator><![CDATA[mlohbihler]]></dc:creator><pubDate>Mon, 09 Jan 2012 20:34:43 GMT</pubDate></item><item><title><![CDATA[Reply to Mango to MS Sql Server 2008 on Mon, 09 Jan 2012 20:25:24 GMT]]></title><description><![CDATA[<p dir="auto">the app couldn't start; but, if i convert to mysql or derby, it works , so i think i've a mistake only in the connection string</p>
]]></description><link>https://forum.mango-os.com/post/6080</link><guid isPermaLink="true">https://forum.mango-os.com/post/6080</guid><dc:creator><![CDATA[r00t]]></dc:creator><pubDate>Mon, 09 Jan 2012 20:25:24 GMT</pubDate></item><item><title><![CDATA[Reply to Mango to MS Sql Server 2008 on Mon, 09 Jan 2012 20:20:02 GMT]]></title><description><![CDATA[<p dir="auto">Right, I meant mssql. Ok, are there any startup errors?</p>
]]></description><link>https://forum.mango-os.com/post/6079</link><guid isPermaLink="true">https://forum.mango-os.com/post/6079</guid><dc:creator><![CDATA[mlohbihler]]></dc:creator><pubDate>Mon, 09 Jan 2012 20:20:02 GMT</pubDate></item><item><title><![CDATA[Reply to Mango to MS Sql Server 2008 on Mon, 09 Jan 2012 20:11:45 GMT]]></title><description><![CDATA[<p dir="auto">the database is Ms Sql server not mysql, and i've only created the 'empty' schema ; i let mango creat the tables itself as u said in the mango&lt;-&gt;mysql thread somewhere...</p>
]]></description><link>https://forum.mango-os.com/post/6078</link><guid isPermaLink="true">https://forum.mango-os.com/post/6078</guid><dc:creator><![CDATA[r00t]]></dc:creator><pubDate>Mon, 09 Jan 2012 20:11:45 GMT</pubDate></item><item><title><![CDATA[Reply to Mango to MS Sql Server 2008 on Mon, 09 Jan 2012 19:49:22 GMT]]></title><description><![CDATA[<p dir="auto">Ensure that the tables in the mysql schema - but not the schema itself - have been dropped and try again. A conversion will only be run if Mango creates the tables anew.</p>
]]></description><link>https://forum.mango-os.com/post/6077</link><guid isPermaLink="true">https://forum.mango-os.com/post/6077</guid><dc:creator><![CDATA[mlohbihler]]></dc:creator><pubDate>Mon, 09 Jan 2012 19:49:22 GMT</pubDate></item><item><title><![CDATA[Reply to Mango to MS Sql Server 2008 on Mon, 09 Jan 2012 17:15:17 GMT]]></title><description><![CDATA[<p dir="auto">i've edited "WEB-INF/classes/env.properties" file but still doesn't work</p>
]]></description><link>https://forum.mango-os.com/post/6075</link><guid isPermaLink="true">https://forum.mango-os.com/post/6075</guid><dc:creator><![CDATA[r00t]]></dc:creator><pubDate>Mon, 09 Jan 2012 17:15:17 GMT</pubDate></item><item><title><![CDATA[Reply to Mango to MS Sql Server 2008 on Fri, 06 Jan 2012 20:24:37 GMT]]></title><description><![CDATA[<p dir="auto">Check your WEB-INF/classes/env.properties file. Make sure it looks ok.</p>
]]></description><link>https://forum.mango-os.com/post/6072</link><guid isPermaLink="true">https://forum.mango-os.com/post/6072</guid><dc:creator><![CDATA[mlohbihler]]></dc:creator><pubDate>Fri, 06 Jan 2012 20:24:37 GMT</pubDate></item></channel></rss>
