    M2M2 Help File Errors
    6 Posts 3 Posters 4.9k Views 1 Watching
      jjd124
      I am receiving the following error with M2M2 Core version 1, I also get similar errors with other Help files. Thanks.
      Document file not found: web/modules/watchlists/web/dox/watchList.htm
        Thanks for the report. We found a few cases of this. Fixes will be in the next releases.
          PCM
          I am receiving the same error:
          "Error Document file not found: web/WEB-INF/dox/scriptingDS.htm"
          "Error Document file not found: web/WEB-INF/dox/metaDS.htm"
          NONE of the help files are working. This is particularly a problem because I can't read the documentation to solve script errors due to unknown metadata script syntax changes in migrating from M2M 1.12.x to MA2.0.
          Mango Automation is installed in /opt/mango
          Linux 3.2.0-35-generic x86_64
          No LSB modules are available.
          Distributor ID: Ubuntu
          Description: Ubuntu 12.04 LTS
          Release: 12.04
          Codename: precise
            Can you try this with 2.0.3?
              PCM
              I just checked, and apparently I am using 2.0.3.
              Joel Haggar suggested I add 'cd ${PRGDIR}' below line 13 in the ma-start.sh file. Now it works. He said 'this will be included in all new releases of Mango'
              $ **cat /opt/mango/ma-start.sh
              #!/bin/sh
              Copyright (C) 2006-2011 Serotonin Software Technologies Inc. All rights reserved.
              @author Matthew Lohbihler
              Runs Mango Automation.
              Get standard environment variables
              PRGDIR=dirname "$0"
              #log output
              exec >${PRGDIR}/logs/ma.out 2>${PRGDIR}/logs/ma.err
              cd ${PRGDIR}
              Only set MA_HOME if not already set
              [ -z "$MA_HOME" ] && MA_HOME=cd "$PRGDIR" >/dev/null; pwd
              if [ ! -r "$MA_HOME"/ma-start.sh ]; then
              echo The MA_HOME environment variable is not defined correctly
              echo This environment variable is needed to run this program
              exit 1
              fi
              Uncomment the following line to start with the debugger
              JPDA=-agentlib:jdwp=transport=dt_socket,address=8090,server=y,suspend=y
              MA_CP=$MA_HOME/overrides/classes
              MA_CP=$MA_CP:$MA_HOME/classes
              MA_CP=$MA_CP:$MA_HOME/overrides/properties
              for f in $MA_HOME/lib/*.jar
              do
              MA_CP=$MA_CP:$f
              done
              if [ -z "$JAVA_HOME" ]; then
              EXECJAVA=java
              else
              EXECJAVA=$JAVA_HOME/bin/java
              fi
              LOOP_EXIT=false
              while [ $LOOP_EXIT = false ]; do
              $EXECJAVA $JPDA -server -cp $MA_CP
              -Dma.home=$MA_HOME
              -Djava.library.path=$MA/lib:$PATH
              com.serotonin.m2m2.Main
              if [ ! -r "$MA_HOME"/RESTART ]; then
                  LOOP_EXIT=true
              fi
              done
