<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M2M2 Help File Errors]]></title><description><![CDATA[<p dir="auto">I am receiving the following error with M2M2 Core version 1, I also get similar errors with other Help files. Thanks.</p>
<p dir="auto">Document file not found: web/modules/watchlists/web/dox/watchList.htm</p>
]]></description><link>https://forum.mango-os.com/topic/805/m2m2-help-file-errors</link><generator>RSS for Node</generator><lastBuildDate>Sat, 11 Apr 2026 14:54:24 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/805.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 05 Apr 2011 19:20:47 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M2M2 Help File Errors on Sat, 05 Jan 2013 03:19:47 GMT]]></title><description><![CDATA[<p dir="auto">I just checked, and apparently I am using 2.0.3.</p>
<p dir="auto">Joel Haggar suggested I add 'cd ${PRGDIR}' below line 13 in the <a href="http://ma-start.sh" rel="nofollow ugc">ma-start.sh</a> file. Now it works. He said 'this will be included in all new releases of Mango'</p>
<p dir="auto">$ **cat /opt/mango/ma-start.sh<br />
**```<br />
#!/bin/sh</p>
<h1></h1>
<h1>Copyright (C) 2006-2011 Serotonin Software Technologies Inc. All rights reserved.</h1>
<h1>@author Matthew Lohbihler</h1>
<h1></h1>
<h1>Runs Mango Automation.</h1>
<h1>Get standard environment variables</h1>
<p dir="auto">PRGDIR=<code>dirname &amp;quot;$0&amp;quot;</code></p>
<p dir="auto">#log output<br />
exec &gt;${PRGDIR}/logs/ma.out 2&gt;${PRGDIR}/logs/ma.err<br />
cd ${PRGDIR}</p>
<h1>Only set MA_HOME if not already set</h1>
<p dir="auto">[ -z "$MA_HOME" ] &amp;&amp; MA_HOME=<code>cd &amp;quot;$PRGDIR&amp;quot; &amp;gt;/dev/null; pwd</code></p>
<p dir="auto">if [ ! -r "$MA_HOME"/ma-start.sh ]; then<br />
echo The MA_HOME environment variable is not defined correctly<br />
echo This environment variable is needed to run this program<br />
exit 1<br />
fi</p>
<h1>Uncomment the following line to start with the debugger</h1>
<h1>JPDA=-agentlib:jdwp=transport=dt_socket,address=8090,server=y,suspend=y</h1>
<p dir="auto">MA_CP=$MA_HOME/overrides/classes<br />
MA_CP=$MA_CP:$MA_HOME/classes<br />
MA_CP=$MA_CP:$MA_HOME/overrides/properties<br />
for f in $MA_HOME/lib/*.jar<br />
do<br />
MA_CP=$MA_CP:$f<br />
done</p>
<p dir="auto">if [ -z "$JAVA_HOME" ]; then<br />
EXECJAVA=java<br />
else<br />
EXECJAVA=$JAVA_HOME/bin/java<br />
fi</p>
<p dir="auto">LOOP_EXIT=false<br />
while [ $LOOP_EXIT = false ]; do<br />
$EXECJAVA $JPDA -server -cp $MA_CP <br />
-Dma.home=$MA_HOME <br />
-Djava.library.path=$MA/lib:$PATH <br />
com.serotonin.m2m2.Main</p>
<pre><code>if [ ! -r &amp;quot;$MA_HOME&amp;quot;/RESTART ]; then
    LOOP_EXIT=true
fi
<p dir="auto">done</p>
<pre><code></code></pre>
]]></description><link>https://forum.mango-os.com/post/7349</link><guid isPermaLink="true">https://forum.mango-os.com/post/7349</guid><dc:creator><![CDATA[PCM]]></dc:creator><pubDate>Sat, 05 Jan 2013 03:19:47 GMT</pubDate></item><item><title><![CDATA[Reply to M2M2 Help File Errors on Fri, 04 Jan 2013 20:30:09 GMT]]></title><description><![CDATA[<p dir="auto">Can you try this with 2.0.3?</p>
]]></description><link>https://forum.mango-os.com/post/7342</link><guid isPermaLink="true">https://forum.mango-os.com/post/7342</guid><dc:creator><![CDATA[mlohbihler]]></dc:creator><pubDate>Fri, 04 Jan 2013 20:30:09 GMT</pubDate></item><item><title><![CDATA[Reply to M2M2 Help File Errors on Wed, 02 Jan 2013 23:47:29 GMT]]></title><description><![CDATA[<p dir="auto">I am receiving the same error:</p>
<p dir="auto">"Error Document file not found: web/WEB-INF/dox/scriptingDS.htm"<br />
"Error Document file not found: web/WEB-INF/dox/metaDS.htm"<br />
NONE of the help files are working. This is particularly a problem because I can't read the documentation to solve script errors due to unknown metadata script syntax changes in migrating from M2M 1.12.x to MA2.0.</p>
<p dir="auto">Mango Automation is installed in /opt/mango</p>
<p dir="auto">Linux 3.2.0-35-generic x86_64<br />
No LSB modules are available.<br />
Distributor ID:	Ubuntu<br />
Description:	Ubuntu 12.04 LTS<br />
Release:	12.04<br />
Codename:	precise</p>
]]></description><link>https://forum.mango-os.com/post/7335</link><guid isPermaLink="true">https://forum.mango-os.com/post/7335</guid><dc:creator><![CDATA[PCM]]></dc:creator><pubDate>Wed, 02 Jan 2013 23:47:29 GMT</pubDate></item><item><title><![CDATA[Reply to M2M2 Help File Errors on Sat, 09 Apr 2011 02:11:42 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for the report. We found a few cases of this. Fixes will be in the next releases.</p>
]]></description><link>https://forum.mango-os.com/post/5665</link><guid isPermaLink="true">https://forum.mango-os.com/post/5665</guid><dc:creator><![CDATA[mlohbihler]]></dc:creator><pubDate>Sat, 09 Apr 2011 02:11:42 GMT</pubDate></item></channel></rss>
