M2M2 Help File Errors
I am receiving the following error with M2M2 Core version 1, I also get similar errors with other Help files. Thanks.
Document file not found: web/modules/watchlists/web/dox/watchList.htm
Thanks for the report. We found a few cases of this. Fixes will be in the next releases.
I am receiving the same error:
"Error Document file not found: web/WEB-INF/dox/scriptingDS.htm"
"Error Document file not found: web/WEB-INF/dox/metaDS.htm"
NONE of the help files are working. This is particularly a problem because I can't read the documentation to solve script errors due to unknown metadata script syntax changes in migrating from M2M 1.12.x to MA2.0.Mango Automation is installed in /opt/mango
Linux 3.2.0-35-generic x86_64
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 12.04 LTS
Release: 12.04
Codename: precise -
Can you try this with 2.0.3?
I just checked, and apparently I am using 2.0.3.
Joel Haggar suggested I add 'cd ${PRGDIR}' below line 13 in the ma-start.sh file. Now it works. He said 'this will be included in all new releases of Mango'
$ **cat /opt/mango/ma-start.sh
#!/bin/shCopyright (C) 2006-2011 Serotonin Software Technologies Inc. All rights reserved.
@author Matthew Lohbihler
Runs Mango Automation.
Get standard environment variables
PRGDIR=
dirname "$0"
#log output
exec >${PRGDIR}/logs/ma.out 2>${PRGDIR}/logs/ma.err
cd ${PRGDIR}Only set MA_HOME if not already set
[ -z "$MA_HOME" ] && MA_HOME=
cd "$PRGDIR" >/dev/null; pwd
if [ ! -r "$MA_HOME"/ma-start.sh ]; then
echo The MA_HOME environment variable is not defined correctly
echo This environment variable is needed to run this program
exit 1
fiUncomment the following line to start with the debugger
JPDA=-agentlib:jdwp=transport=dt_socket,address=8090,server=y,suspend=y
MA_CP=$MA_HOME/overrides/classes
MA_CP=$MA_CP:$MA_HOME/classes
MA_CP=$MA_CP:$MA_HOME/overrides/properties
for f in $MA_HOME/lib/*.jar
do
MA_CP=$MA_CP:$f
doneif [ -z "$JAVA_HOME" ]; then
EXECJAVA=java
else
EXECJAVA=$JAVA_HOME/bin/java
fiLOOP_EXIT=false
while [ $LOOP_EXIT = false ]; do
$EXECJAVA $JPDA -server -cp $MA_CP
-Dma.home=$MA_HOME
-Djava.library.path=$MA/lib:$PATH
com.serotonin.m2m2.Mainif [ ! -r "$MA_HOME"/RESTART ]; then LOOP_EXIT=true fi
done
