    SeroUtils.jar management
    41 Posts 6 Posters 91.0k Views 1 Watching
      andrex
      So, I suppose you won't release the modUtils.jar sources in the future.
      It's possible to buy the sources?
      Regards
      Andrea
        apl
        having a project which violates the license it uses, may render the license void - Im no legal expert, but this could happen IMHO.
        So Matthew, you can switch to a different license | open source the serotonin-utils.jar.
        Or somebody may decompile your jar for debugging reasons. I don't know if this is a violation against the license ....
        I am also not entirely satisfied with the current situation. Open source (GPL|LGPL) means you have all sources and not head into a trap, where you only have the binaries.
        Arne
          I'm not a lawyer either, but what is the difference between producing an open source Java project that requires a JVM - which is not open source - to run and one that requires another library - also not open source - to run? I believe you are mistaken.
            apl
            My problem is, in which way do you want to get your bread and butter from this?
            I haven't seen a price tag so far. Do you want to get your revenue with commercial support, ...?
            So not to open source serutils.jar may have for some potential commercial customers the smell of a trap.
            A solution would be decompile serutils (there is no expicit license, so it is LGPL too?, but the sources are missing ;-).
            In this case decompilation should be no problem for you.
            If you plan to extensively cash money for mango, a fork of mango and bugfixing without Serotonin Inc. would be possible - this may be a solution for potential customers.
            Don't get me wrong: You need money too, but before I use this software commercially I have to be confident there is no hidden trap in the future. So a pricelist and/or a license for serutils.jar would be fine ;-)
            Arne
              andrex
              The Java api are open.
              search in JAVA_HOME/src.zip
              Only the com.sun api are not open.
              If you make a program that use com.sun api you can't say it is "open" and sun alert you against this warning.
              If you write good open source code,
              as you have effectively done,
              but you link it aginst not open source code,
              without java interfaces which permit the use of the open code without the closed library,
              you destroy the advantage of the open code you wrote.
              For example I have the problem in using your code because I'm not sure I will cacth the bugs in my products if I will use your GOOD library.
              maybe, if you release the seroUtils opensource, we can help you to fix bugs or make it more documented or less sperimental.
              On the other side, if you prefer mantain the seroUtils closed, you may code the modbus4J less bound to the utils, via some padckage-interface.
              Regards
              Andrea
              • F Offline
                Fred
                Removed post.
                  racj
                  Dear Matthew,
                  I am currently using JAMOD on a CDC platform and would be interested in using Modbus4J, since this gives RTU slave capability.
                  However, The seroUtils.jar is not JAVA 1.4 compatible, which is what I need for my CDC platform (which consequently fails when trying to link).
                  Are you able to provide a version of the JAR file built using the JAVA compiler switches -source 1.4 and -target 1.4 ?
                  If you are able to do this then I would look to generate a CDC compatible version of Modbus4J.
                  Many thanks
                  Richard
                    Hi Richard,
                    It is very likely possible to create a CDC-compatible version of seroUtils. Is this a personal project, or do you have a development budget?
                      racj
                      Dear Matthew,
                      This is a research project - so only a very limited budget.
                      How long do you think it would take you ?
                      Would it be possible for me to look at what is needed for a CDC compatible compile ? I do realise from the previous discussions in this thread that you have concerns about open sourcing SeroUtils - can this be handled some other way than global open source ?
                      Regards
                      Richard
                        Hi Richard,
                        Did you already convert Modbus4J to 1.4? I recall that for the "-source 1.4" switch to work you'd need to refactor all the generics, annotations, and auto-boxing, and possibly other stuff too.
                          racj
                          Dear Matthew,
                          I have only identified the sections that will need to be modified (as you correctly identified this is mostly generics etc), However I have not proceeded with implementing any changes, because having a usable system is dependant on having a CDC compatible version of SeroUtils.
                          Do you have a feel for how much work it would be to generate the CDC compatible version of SeroUtils ?
                          Regards
                          Richard
                            I could provide you with the subset of seroUtils required by Modbus4J fairly easily. Do note though that Modbus4J is GPL software. Any changes you make need to become open source, which is a consideration if your project ever becomes commercial in the future. But Serotonin can provide a more LGPL-like license in this occurrence.
                              racj
                              Dear Matthew,
                              Open source is not a problem.
                              Would you provide the sub-set of SeroUtils as source for me to do the conversion or would you look to do it yourself ?
                              Regards
                              Richard
                                If you're converting the Modbus4J stuff, you might as well do this too. Attached.
                                  racj
                                  Dear Matthew,
                                  Thank you for that. I will let you know how I get on.
                                  Regards
                                  Richard
                                  • G Offline
                                    gpulido
                                    Dear Matthew,
                                    I'm collaborating in a Open Source project to develop a personal home-automation framework, and we would like to use your Modbus4J library.
                                    Unfortunatelly it depends of the seroUtils.jar and as our project is under the GPL license we would like to know if you can proportionate us the source code for the library.
                                    Thank you in advance
                                    Best regards
                                    Gabriel
                                      Hi Gabriel,
                                      The source in the above should be all you need. Feel free to use it.
                                      Regards,
                                      • G Offline
                                        gpulido
                                        Hello Mathew,
                                        Unfortunately the link is broken can you publish it again?
                                        Thank you
                                        Regards,
                                        Gabriel
                                          Ah, right. Lost in the move. Re-attached.
                                            apl
                                            @mlohbihler said:
                                            Can I take this, that I can reengineer the needed sorces for mango M2M (1.12.4) for further development?
                                            Or under which license is seroUtils.jar?
