    V.1.11.0 installed but OPC DA datasource is not there :(
    19 Posts 6 Posters 17.1k Views 1 Watching
      aniimsaj
      I saw that v.1.11.0 has OPC DA datasource. What I might done wrong because I did not see it in a list of datasources? Any idea? I upgraded mango from the earlier version and everything seemed to go OK. Mango is now 1.11.0.
        The OPC DA data source was contributed by the kind folks at certi.org.br. We are waiting for them to confirm its production usability, and in the meantime have marked it to not display by default. If you want to try it out, use the SQL page to run this update:
        insert into systemSettings (settingName, settingValue) values ('OPC.display', 'Y')
          aniimsaj
          Alright, thank you!
          Any advise how to configure it? No help text yet founded...
            Patriator
            Succeded in some tests with this configuration:
            Name and Export Id : like in all other datsources
            Host : the hostname or IP adress of the OPC server
            Domain user and password : Authentification information so the client can acess the server. (I made a replication server on a Windows machine and put there a window user information )
            Server : If all above information is OK when you click Refresh, You will get a list of available OPC servers, then choose one.
            Update periode ... I guess it is explicit.
            You can now save and then press 'browse tags'
            You'll then get a list of available tags.
            select some of then and press 'Add Tags'
            You will get Data Point for all selected tags.
              Patriator
              But I still have some trouble :
              • the browse tag don't give me any String datatype Tag
              • the browse tag don't give me any settable Tag
              And I've got an OPC server functionning like that :
              If I want to get the parameter X on machine Y
              groupReqX settable I put value Y
              groupAnsX I get the value overwise I get 0
              Is there any way to do that ? how ? scripting?
                aniimsaj
                Thank you for the clear answer, above makes sense but I did not managed :( Or should OPC Servers always be in a different machine and "localhost" is not accepted or otherwise it is something to do a machine without domain as is a case in my PC, all servers are in a mango machine.
                For other question from you I don't have an answer but I also waiting an answer for settable value issue...
                  Patriator
                  Mango is on a virtual Linux box so I can't answer for the localhost.
                  Maybe You could try with the box IP or 127.0.0.1 instead of localhost.
                  I tried to let domain blank and it worked fine.
                    I used localhost and it worked fine.
                      Patriator
                      Tried to add manually (with the import feature) a data point type string like that :
                         "dataPoints":[
                               "xid":"DP_999323",
                               "loggingType":"ON_CHANGE",
                               "purgeType":"YEARS",
                               "pointLocator":{
                                  "dataType":"ALPHANUMERIC",
                                  "settable":false,
                                  "tag":"PCC1.AR01.A0_ssys_ddmmyy00"
                               "eventDetectors":[
                               "engineeringUnits":"",
                               "chartRenderer":null,
                               "dataSourceXid":"DS_691328",
                               "defaultCacheSize":1,
                               "discardExtremeValues":false,
                               "discardHighLimit":0.0,
                               "discardLowLimit":0.0,
                               "enabled":true,
                               "intervalLoggingPeriod":15,
                               "name":"PCC1.AR01.A0_ssys_ddmmyy00",
                               "purgePeriod":1,
                               "textRenderer":{
                                  "type":"PLAIN",
                                  "suffix":""
                               "tolerance":0.0
                      I get 'Unknown value type' so it find the Tag (would get a 'Unknow Tag' overwise) but can't do anything with the answer.
                        I was able to import this point, but of course, it says that it was unable to add the point because i don't have it. If you know you have that point on your server, i think someone from ScadaBR will need to comment. They're the experts on it.
                          rbautomacao
                          Any doubt about OPC Configuration please take a look:
                          http://sourceforge.net/projects/scadabr/files/Software/Docs/OPC Configuration ScadaBR.pdf
                          The configurations about OPC DataSource refers only to the server, in other words, all the settings must be about where OPC Server is located.
                          A important note: The computer where is the Server must contain a domain.
                            aniimsaj
                            Yes, I got mine working with a computer which is part of a domain. But same notice as "Patriator" has: Settable values shows "false" even if I know that OPC Server tag is writable one.
                            Maybe have to just wait some improvements from ScadaBR, "mlohbihler"?
                              rbautomacao
                              Hi again,
                              ScadaBR team made some improvements about OPC Client and i believe that
                              within a maximum a week they are passed for Mango.
                              • V Offline
                                victor-br
                                Hello
                                rbautomacao has updated the opc-driver.jar
                                it can be found here:
                                https://scadabr.svn.sourceforge.net/svnroot/scadabr/ScadaBR/WebContent/WEB-INF/lib/opc-driver.jar
                                please try this new version and let us know if the fixes are ok.
                                thanks! :)
                                Victor
                                ScadaBR
                                  Patriator
                                  Just tried this new jar.
                                  write allowed points are now listed as settable.
                                  I still get some points missing ( string) but not with all the opc servers.
                                    aniimsaj
                                    Yes, now it's works!
                                    I did not made any further checking but anyway direction is right!
                                    Hopefully development does not end and soon we will see also settable polling periods for individual points etc. OPC Client things...
                                      skiv71
                                      how can i use this opc da datasource to connect to a beijersopc server?
                                      there are no provisions to set username or password..
                                      also, i'll be installing everything on xp home (so no domain) :-/
                                      be great to see this working
                                        skiv71
                                        ... just an update... been playing around and can now connect to the opc server.... but its only showing tags in the default container 'SystemVariables' and not my tags present in my group containers...??
