    How to read OID Tables
    7 Posts 2 Posters 5.3k Views 1 Watching
    • W Offline
      Wilf
         This is my first attempt and i have hit a problem, I need to read
      date form a oid table, I cant work out how to do this can anyone
      help ?
      wilf
        SNMP?
        • W Offline
          Wilf
          Hi Sorry i will try to explain a little better,
          I can read standard OID's no problem.
          some of the data i am trying to read is in a table as :
          UpsOutputEntry ::=
          SEQUENCE {
          upsOutputLineIndex INTEGER,
          upsOutputVoltage INTEGER,
          upsOutputCurrent INTEGER,
          upsOutputPercentLoad INTEGER
          I need to read voltage and current but cannot find a way to do this
          I think i need to send a SET command before the GET but don't
          know how.
          I hope this makes a little more sense.
          Best regards
          Neil
            Have you tried using a tool like MIBBrowser to convert the textual OID into numeric?
            • W Offline
              Wilf
              Hi yes i have converted the OID the following will read OK
              Name/OID: .1.3.6.1.4.1.4555.1.1.1.1.4.2.0
              The following ( from a table) wont
              Name/OID: .1.3.6.1.4.1.4555.1.1.1.1.4.4.1.2.1
              If i could use the GETNEXT Command i think it would work.
              or could i change the code to change the command ?
              if so where does Mango interface with SNMP4J ?
              any workaround appreciated, i just need to get these values the other 12
              i am picking up no problems the same for the modbus.
              Best regards
              • W Offline
                Wilf
                Ok i asume this is not possible, thanks anyway
