<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How to read OID Tables]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<pre><code>   This is my first attempt and i have hit a problem, I need to read
<p dir="auto">date form a oid table, I cant work out how to do this can anyone<br />
help ?</p>
<p dir="auto">Thanks<br />
wilf</p>
]]></description><link>https://forum.mango-os.com/topic/309/how-to-read-oid-tables</link><generator>RSS for Node</generator><lastBuildDate>Fri, 13 Nov 2026 01:36:00 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/309.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 26 Feb 2010 00:38:48 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to How to read OID Tables on Sun, 07 Mar 2010 22:02:13 GMT]]></title><description><![CDATA[<p dir="auto">Ok i asume this is not possible, thanks anyway</p>
]]></description><link>https://forum.mango-os.com/post/3328</link><guid isPermaLink="true">https://forum.mango-os.com/post/3328</guid><dc:creator><![CDATA[Wilf]]></dc:creator><pubDate>Sun, 07 Mar 2010 22:02:13 GMT</pubDate></item><item><title><![CDATA[Reply to How to read OID Tables on Mon, 01 Mar 2010 16:15:01 GMT]]></title><description><![CDATA[<p dir="auto">Hi yes i have converted the OID the following will read OK</p>
<p dir="auto">Name/OID: .1.3.6.1.4.1.4555.1.1.1.1.4.2.0</p>
<p dir="auto">The following ( from a table) wont</p>
<p dir="auto">Name/OID: .1.3.6.1.4.1.4555.1.1.1.1.4.4.1.2.1</p>
<p dir="auto">If i could use the GETNEXT Command i think it would work.<br />
or could i change the code to change the command ?<br />
if so where does Mango interface with SNMP4J ?</p>
<p dir="auto">any workaround appreciated, i just need to get these values the other 12<br />
i am picking up no problems the same for the modbus.</p>
<p dir="auto">Best regards</p>
]]></description><link>https://forum.mango-os.com/post/3293</link><guid isPermaLink="true">https://forum.mango-os.com/post/3293</guid><dc:creator><![CDATA[Wilf]]></dc:creator><pubDate>Mon, 01 Mar 2010 16:15:01 GMT</pubDate></item><item><title><![CDATA[Reply to How to read OID Tables on Mon, 01 Mar 2010 15:12:42 GMT]]></title><description><![CDATA[<p dir="auto">Have you tried using a tool like MIBBrowser to convert the textual OID into numeric?</p>
]]></description><link>https://forum.mango-os.com/post/3292</link><guid isPermaLink="true">https://forum.mango-os.com/post/3292</guid><dc:creator><![CDATA[mlohbihler]]></dc:creator><pubDate>Mon, 01 Mar 2010 15:12:42 GMT</pubDate></item><item><title><![CDATA[Reply to How to read OID Tables on Fri, 26 Feb 2010 19:37:54 GMT]]></title><description><![CDATA[<p dir="auto">Hi Sorry i will try to explain a little better,</p>
<p dir="auto">I can read standard OID's no problem.<br />
some of the data i am trying to read is in a table as :</p>
<p dir="auto">UpsOutputEntry ::=<br />
SEQUENCE {<br />
upsOutputLineIndex          INTEGER,<br />
upsOutputVoltage            INTEGER,<br />
upsOutputCurrent            INTEGER,<br />
upsOutputPercentLoad        INTEGER<br />
}</p>
<p dir="auto">I need to read voltage and current but cannot find a way to do this<br />
I think i need to send a SET command before the GET but don't<br />
know how.<br />
I hope this makes a little more sense.</p>
<p dir="auto">Neil</p>
]]></description><link>https://forum.mango-os.com/post/3287</link><guid isPermaLink="true">https://forum.mango-os.com/post/3287</guid><dc:creator><![CDATA[Wilf]]></dc:creator><pubDate>Fri, 26 Feb 2010 19:37:54 GMT</pubDate></item><item><title><![CDATA[Reply to How to read OID Tables on Fri, 26 Feb 2010 01:35:54 GMT]]></title><description><![CDATA[<p dir="auto">SNMP?</p>
]]></description><link>https://forum.mango-os.com/post/3286</link><guid isPermaLink="true">https://forum.mango-os.com/post/3286</guid><dc:creator><![CDATA[mlohbihler]]></dc:creator><pubDate>Fri, 26 Feb 2010 01:35:54 GMT</pubDate></item></channel></rss>
