    Building Mango in Eclipse
    42 Posts 13 Posters 79.5k Views 1 Watching
      Andras
      I would like to add a "driver" for a data source, so I'm trying to build Mango. Since you're using Eclipse, I figured I'll use Eclipse also.
      I've downloaded Galileo and tried to import the 1.8.0 Mango source with File->Import as "General existing project". I got errors because a src_gen and src_test directory is expected, so I added these dirs. Also, I had to alter the path to RXTXcomm in .classpath to the war dir and the tomcat.home in build.properties (as mentioned elsewhere on the forum).
      This got me further, but I still get a "buildpath incomplete" error:
      The type com.serotonin.io.messaging.RequestHandler cannot be resolved. It is indirectly referenced from required .class files SpinwaveSensorListener.java /Mango/src/com/serotonin/mango/web/dwr/beans
      I'm now doubting if I'm on th right track here...
        craig
        I do the following:
        1. make sure you have eclipse release which includes the web tools project.
        2. unpack mango source in a directory called "myMangoBranch" inside the eclipse workspace directory
        3. Do File->New->Other, choose "Dynamic Web project" from under "Web"
        4. Make Project name "myMangoBranch" (must match existing directory name)
        5. I don't have to change any other options on the new dynamic web project dialog, target runtime is apache tomcat 6.0 (you may have to add a target runtime), so I hit next.
        6. Source folders on the build path i leave as "src" and default output folder I leave as build/classes, so i hit next
        7. Content Directory I change from "WebContent" to war. Hit finish!
          Andras
          Hi Craig,
          I followed your steps. I got the webtools Eclipse. However, it seems the current Eclipse version doesn't like that the myMangoBranch directory already exists (and suggests to use import existing project).
          Nevertheless, I did create a new dynamic web project according to your steps and copied the Mango source into the newly created directory afterwards. Then I did a refresh in the project explorer. The new source files are then recognized, but I get exactly the same problems as before.
            Andras
            Update: building Mango now succeeded :)
            I had to run the createconfigfiles task first. Still, I had to solve the problem that axis tools (wsdl2java) couldn't be found. axis-ant.jar is needed for this. I downloaded it from somewhere and put it in the WEB-INF/lib where it is now next to axis.jar. I understand that this isn't the correct place, but until someone points out what the right place is, this works for now :wink:
            Summarizing the steps I had to take to build Mango:
            -follow the general Mango installation instructions (including Tomcat install) from the Mango download page
            -get Eclipse IDE for Java EE Developers
            -get Mango source code, unpack it
            -add empty subdirectories lib, src_gen and src_test to Mango source
            -in file build.properties, edit tomcat.home to point at the tomcat location on your system. For windows, make sure forward slashes "/" are used in the tomcat.home path
            -get axis-ant.jar and put it into the WEB-INF/lib directory
            -In Eclipse choose import->general and browse to the mango source
            -right-click build.xml in the project explorer and choose run as->2.ant-build...
            choose the createconfigfiles target
            -right-click build.xml again and again choose run as->2.ant-build...
            choose the default deploy
            The newly built Mango is now copied to the tomcat webapps/test directory
            Probably this isn't the most optimal recipe, but it does the job :)
              You should be able to just remove the axis jar from your build path.
                Andras
                Thanks, I removed it from the build path and now the axix-ant.jar isn't needed anymore.
                  apl
                  if you want to build it with maven and/or Netbeans i can provide a setup-script (bash with symlinks) and a pom.xml.
                  Arne
                    mmn666
                    i want to install the mango source, but i have this error when i try run the build.xml.
                    BUILD FAILED
                    /home/.../workspace/myMangoBranch/build.xml:233: taskdef class org.apache.axis.tools.ant.wsdl.Wsdl2javaAntTask cannot be found
                    i know the lib axis-ant fix a problem linked to wsdl2, but in my case this doesn't work... the lib's version is axis-ant-1.2.1.jar
                    please i need help...
                    regards
                    Mario
                    thanks
                      Andras
                      Hi Mario,
                      For building Mango you don't need the axis stuff. Besides removing the axis jars from the build path, you can remove the last WDSL related part of the build.xml as well. It's not needed for the "deploy" build target. Building the way I described above should then work.
                      Although building now works, when using the IDE, you will still get quite some unresolved red markings. You can solve that by adding some jars to the build path under the menu "project->properties->java build path->libraries". I used "add jar" to add these jars in war/WEB-INF/lib :
                      modbus4J
                      seroUtils
                      common-httputils
                      quartz
                      bacnet4J
                      commons-codec
                      joda
                      You might also need use "add external jar" to point to the servlet and jsp api. For Tomcat 5 these jars are in ${tomcat.home}/lib and are named:
                      servlet-api
                      jsp-api
                      Regards,
                      Andras
                        mmn666
                        Hi Andras,
                        i use: linux(ubuntu-10.4)
                        tomcat-6.0.20
                        eclipse 3.5(galileo)
                        mysql-server-5.0
                        and i build the mango source without error or red markers the way you said(i added more others jars)
                        but when i try to access http://localhost:8080/test with my browser(firefox 3.5) i can't see nothing only a HTTP STATUS 404
                        regards,
                        Mario
                          Did you installed Mango in webapps/test? Also, are there any startup errors in the Tomcat console?
                            mmn666
                            this is the default folder in build.properties
                            tomcat.appdir=test
                            tomcat.apppath=/test
                            no errors
                            26/03/2010 18:30:38 org.apache.catalina.core.AprLifecycleListener init
                            INFO: The APR based Apache Tomcat Native library which allows optimal performance in production environments was not found on the java.library.path: /usr/lib/jvm/java-6-sun-1.6.0.15/jre/lib/i386/server:/usr/lib/jvm/java-6-sun-1.6.0.15/jre/lib/i386:/usr/lib/jvm/java-6-sun-1.6.0.15/jre/../lib/i386:/usr/lib/jvm/java-6-sun-1.6.0.15/jre/lib/i386/client:/usr/lib/jvm/java-6-sun-1.6.0.15/jre/lib/i386:/usr/lib/xulrunner-addons:/usr/lib/xulrunner-addons:/usr/java/packages/lib/i386:/lib:/usr/lib
                            26/03/2010 18:30:38 org.apache.coyote.http11.Http11Protocol init
                            INFO: Initializing Coyote HTTP/1.1 on http-8080
                            26/03/2010 18:30:38 org.apache.catalina.startup.Catalina load
                            INFO: Initialization processed in 1018 ms
                            26/03/2010 18:30:38 org.apache.catalina.core.StandardService start
                            INFO: Starting service Catalina
                            26/03/2010 18:30:38 org.apache.catalina.core.StandardEngine start
                            INFO: Starting Servlet Engine: Apache Tomcat/6.0.20
                            26/03/2010 18:30:38 org.apache.coyote.http11.Http11Protocol start
                            INFO: Starting Coyote HTTP/1.1 on http-8080
                            26/03/2010 18:30:38 org.apache.jk.common.ChannelSocket init
                            INFO: JK: ajp13 listening on /0.0.0.0:8009
                            26/03/2010 18:30:39 org.apache.jk.server.JkMain start
                            INFO: Jk running ID=0 time=0/61 config=null
                            26/03/2010 18:30:39 org.apache.catalina.startup.Catalina start
                            INFO: Server startup in 710 ms
                            sorry my ignorance...
                            and thanks for your patience
                            regards,
                            Mario
                              Obvious sounding, i know, but can you check that there is a <tomcat>/webapps/test directory?
                              Also (assuming you're using ANT), what does "ant list" tell you?
                                mmn666
                                Hi mlohbihler,
                                yes this folder exist and have into:
                                /audio
                                /exception
                                /graphics
                                /images
                                /resources
                                /uploads
                                /WEB-INF
                                customViewExample.jsp
                                index.jsp
                                soundmanager2.swf
                                soundmanager2_flash9.swf
                                i guess the ant is used to build and get what i need to build the project and deploy.
                                but i don't use the ant because Andras said this is not necessary
                                regards,
                                Mario
                                  What do you see when you hit http://localhost:8080/manager/list (changing host info as necessary)? This assumes that you left the manager application in the deployment. You should be able to find your u/p in the conf/tomcat-users.xml file.
                                    mmn666
                                    I try do everything from beginning again...because i could't access http://localhost:8080/manager/list
                                    so i install the tomcat6 again
                                    and when i try build i have another error
                                     [copy] Copying 2797 files to /home/mario/Programas/apache-tomcat-6.0.20/webapps/mango
                                    BUILD FAILED
                                    /home/mario/workspace7/SuperMango/build.xml:117: Failed to copy /home/mario/workspace7/SuperMango/build/WEB-INF/classes/com/serotonin/mango/rt/maint/work/WorkItem.class to /home/mario/Programas/apache-tomcat-6.0.20/webapps/mango/WEB-INF/classes/com/serotonin/mango/rt/maint/work/WorkItem.class due to java.io.FileNotFoundException /home/mario/Programas/apache-tomcat-6.0.20/webapps/mango/WEB-INF/classes/com/serotonin/mango/rt/maint/work/WorkItem.class (No such file or directory)
                                    Total time: 3 seconds
                                    regards,
                                    Mario
                                      Andras
                                      Regarding your problem to access the manager: did you check that the manager role was assigned to the user with which you tried to access the manager ?
                                      In conf/tomcat-users.xml you should have something like
                                      <tomcat-users>
                                      <role rolename="manager"/>
                                      <user username="manager" password="manager" roles="manager"/>
                                      </tomcat-users>
                                      to be able to access http://localhost:8080/manager/html with user manager
                                        mmn666
                                        Hi Andras,
                                        in my tomcat-users.xml i have this
                                        <tomcat-users>
                                        <role rolename="tomcat"/>
                                        <role rolename="role1"/>
                                        <user username="tomcat" password="tomcat" roles="tomcat"/>
                                        <user username="manager" password="manager" roles="tomcat,manager"/>
                                        <user username="both" password="tomcat" roles="tomcat,role1"/>
                                        <user username="role1" password="tomcat" roles="role1"/>
                                        </tomcat-users>
                                        and in my build.properties i have
                                        tomcat.home=/home/mario/Programas/apache-tomcat-6.0.20
                                        tomcat.manager.url=http://localhost:8080/manager
                                        tomcat.manager.username=manager
                                        tomcat.manager.password=manager
                                        tomcat.hostname=webapps/ROOT
                                        App name and app path are separated to accomodate root deployments. (i.e. 'ROOT' vs. '/')
                                        tomcat.appdir=mango
                                        tomcat.apppath=/mango
                                        and when i run the build.xml to createConfigFiles
                                        Buildfile: /home/mario/workspace7/SuperMango/build.xml
                                        createConfigFiles:
                                        [copy] Copying 1 file to /home/mario/workspace7/SuperMango/build/WEB-INF/classes
                                        BUILD SUCCESSFUL
                                        Total time: 466 milliseconds
                                        but when i run to deploy[default]
                                        compile:
                                        static:
                                        build:
                                        copy:
                                        [copy] Copying 2797 files to /home/mario/Programas/apache-tomcat-6.0.20/webapps/ROOT/mango
                                        BUILD FAILED
                                        /home/mario/workspace7/SuperMango/build.xml:117: Failed to copy /home/mario/workspace7/SuperMango/build/WEB-INF/classes/com/serotonin/mango/rt/maint/work/WorkItem.class to /home/mario/Programas/apache-tomcat-6.0.20/webapps/ROOT/mango/WEB-INF/classes/com/serotonin/mango/rt/maint/work/WorkItem.class due to java.io.FileNotFoundException /home/mario/Programas/apache-tomcat-6.0.20/webapps/ROOT/mango/WEB-INF/classes/com/serotonin/mango/rt/maint/work/WorkItem.class (No such file or directory)
                                        Total time: 2 seconds
                                        other thing i observe is the fact when i started tomcat by the eclipse, i can't access the "http://localhost:8080/" , returning a HTTP Status 404
                                        but when i started the tomcat by console like root, i can access the homepage of tomcat("http://localhost:8080/") and "http://localhost:8080/manager/html" normally
                                        regards,
                                        Mario
                                          Hi Mario,
                                          If you're going to have a context path of "mango", then your hostname should not include "ROOT". Try changing the following build.properties value:
                                            mmn666
                                            Hi mlohbihler,
                                            i changed to
                                            but don't have any effect...
                                            compile:
                                            static:
                                            build:
                                            copy:
                                            BUILD FAILED
                                            regards,
                                            Mario
