    Building Mango in Eclipse
    42 Posts 13 Posters 89.6k Views 1 Watching
      Andras
      Thanks, I removed it from the build path and now the axix-ant.jar isn't needed anymore.
        apl
        if you want to build it with maven and/or Netbeans i can provide a setup-script (bash with symlinks) and a pom.xml.
        Arne
          mmn666
          i want to install the mango source, but i have this error when i try run the build.xml.
          BUILD FAILED
          /home/.../workspace/myMangoBranch/build.xml:233: taskdef class org.apache.axis.tools.ant.wsdl.Wsdl2javaAntTask cannot be found
          i know the lib axis-ant fix a problem linked to wsdl2, but in my case this doesn't work... the lib's version is axis-ant-1.2.1.jar
          please i need help...
          regards
          Mario
          thanks
            Andras
            Hi Mario,
            For building Mango you don't need the axis stuff. Besides removing the axis jars from the build path, you can remove the last WDSL related part of the build.xml as well. It's not needed for the "deploy" build target. Building the way I described above should then work.
            Although building now works, when using the IDE, you will still get quite some unresolved red markings. You can solve that by adding some jars to the build path under the menu "project->properties->java build path->libraries". I used "add jar" to add these jars in war/WEB-INF/lib :
            modbus4J
            seroUtils
            common-httputils
            quartz
            bacnet4J
            commons-codec
            joda
            You might also need use "add external jar" to point to the servlet and jsp api. For Tomcat 5 these jars are in ${tomcat.home}/lib and are named:
            servlet-api
            jsp-api
            Regards,
            Andras
              mmn666
              Hi Andras,
              i use: linux(ubuntu-10.4)
              tomcat-6.0.20
              eclipse 3.5(galileo)
              mysql-server-5.0
              and i build the mango source without error or red markers the way you said(i added more others jars)
              but when i try to access http://localhost:8080/test with my browser(firefox 3.5) i can't see nothing only a HTTP STATUS 404
              regards,
              Mario
                Did you installed Mango in webapps/test? Also, are there any startup errors in the Tomcat console?
                  mmn666
                  this is the default folder in build.properties
                  tomcat.appdir=test
                  tomcat.apppath=/test
                  no errors
                  26/03/2010 18:30:38 org.apache.catalina.core.AprLifecycleListener init
                  INFO: The APR based Apache Tomcat Native library which allows optimal performance in production environments was not found on the java.library.path: /usr/lib/jvm/java-6-sun-1.6.0.15/jre/lib/i386/server:/usr/lib/jvm/java-6-sun-1.6.0.15/jre/lib/i386:/usr/lib/jvm/java-6-sun-1.6.0.15/jre/../lib/i386:/usr/lib/jvm/java-6-sun-1.6.0.15/jre/lib/i386/client:/usr/lib/jvm/java-6-sun-1.6.0.15/jre/lib/i386:/usr/lib/xulrunner-addons:/usr/lib/xulrunner-addons:/usr/java/packages/lib/i386:/lib:/usr/lib
                  26/03/2010 18:30:38 org.apache.coyote.http11.Http11Protocol init
                  INFO: Initializing Coyote HTTP/1.1 on http-8080
                  26/03/2010 18:30:38 org.apache.catalina.startup.Catalina load
                  INFO: Initialization processed in 1018 ms
                  26/03/2010 18:30:38 org.apache.catalina.core.StandardService start
                  INFO: Starting service Catalina
                  26/03/2010 18:30:38 org.apache.catalina.core.StandardEngine start
                  INFO: Starting Servlet Engine: Apache Tomcat/6.0.20
                  26/03/2010 18:30:38 org.apache.coyote.http11.Http11Protocol start
                  INFO: Starting Coyote HTTP/1.1 on http-8080
                  26/03/2010 18:30:38 org.apache.jk.common.ChannelSocket init
                  INFO: JK: ajp13 listening on /0.0.0.0:8009
                  26/03/2010 18:30:39 org.apache.jk.server.JkMain start
                  INFO: Jk running ID=0 time=0/61 config=null
                  26/03/2010 18:30:39 org.apache.catalina.startup.Catalina start
                  INFO: Server startup in 710 ms
                  sorry my ignorance...
                  and thanks for your patience
                  regards,
                  Mario
                    Obvious sounding, i know, but can you check that there is a <tomcat>/webapps/test directory?
                    Also (assuming you're using ANT), what does "ant list" tell you?
                      mmn666
                      Hi mlohbihler,
                      yes this folder exist and have into:
                      /audio
                      /exception
                      /graphics
                      /images
                      /resources
                      /uploads
                      /WEB-INF
                      customViewExample.jsp
                      index.jsp
                      soundmanager2.swf
                      soundmanager2_flash9.swf
                      i guess the ant is used to build and get what i need to build the project and deploy.
                      but i don't use the ant because Andras said this is not necessary
                      regards,
                      Mario
                        What do you see when you hit http://localhost:8080/manager/list (changing host info as necessary)? This assumes that you left the manager application in the deployment. You should be able to find your u/p in the conf/tomcat-users.xml file.
                          mmn666
                          I try do everything from beginning again...because i could't access http://localhost:8080/manager/list
                          so i install the tomcat6 again
                          and when i try build i have another error
                           [copy] Copying 2797 files to /home/mario/Programas/apache-tomcat-6.0.20/webapps/mango
                          BUILD FAILED
                          /home/mario/workspace7/SuperMango/build.xml:117: Failed to copy /home/mario/workspace7/SuperMango/build/WEB-INF/classes/com/serotonin/mango/rt/maint/work/WorkItem.class to /home/mario/Programas/apache-tomcat-6.0.20/webapps/mango/WEB-INF/classes/com/serotonin/mango/rt/maint/work/WorkItem.class due to java.io.FileNotFoundException /home/mario/Programas/apache-tomcat-6.0.20/webapps/mango/WEB-INF/classes/com/serotonin/mango/rt/maint/work/WorkItem.class (No such file or directory)
                          Total time: 3 seconds
                          regards,
                          Mario
                            Andras
                            Regarding your problem to access the manager: did you check that the manager role was assigned to the user with which you tried to access the manager ?
                            In conf/tomcat-users.xml you should have something like
                            <tomcat-users>
                            <role rolename="manager"/>
                            <user username="manager" password="manager" roles="manager"/>
                            </tomcat-users>
                            to be able to access http://localhost:8080/manager/html with user manager
                              mmn666
                              Hi Andras,
                              in my tomcat-users.xml i have this
                              <tomcat-users>
                              <role rolename="tomcat"/>
                              <role rolename="role1"/>
                              <user username="tomcat" password="tomcat" roles="tomcat"/>
                              <user username="manager" password="manager" roles="tomcat,manager"/>
                              <user username="both" password="tomcat" roles="tomcat,role1"/>
                              <user username="role1" password="tomcat" roles="role1"/>
                              </tomcat-users>
                              and in my build.properties i have
                              tomcat.home=/home/mario/Programas/apache-tomcat-6.0.20
                              tomcat.manager.url=http://localhost:8080/manager
                              tomcat.manager.username=manager
                              tomcat.manager.password=manager
                              tomcat.hostname=webapps/ROOT
                              App name and app path are separated to accomodate root deployments. (i.e. 'ROOT' vs. '/')
                              tomcat.appdir=mango
                              tomcat.apppath=/mango
                              and when i run the build.xml to createConfigFiles
                              Buildfile: /home/mario/workspace7/SuperMango/build.xml
                              createConfigFiles:
                              [copy] Copying 1 file to /home/mario/workspace7/SuperMango/build/WEB-INF/classes
                              BUILD SUCCESSFUL
                              Total time: 466 milliseconds
                              but when i run to deploy[default]
                              compile:
                              static:
                              build:
                              copy:
                              [copy] Copying 2797 files to /home/mario/Programas/apache-tomcat-6.0.20/webapps/ROOT/mango
                              BUILD FAILED
                              /home/mario/workspace7/SuperMango/build.xml:117: Failed to copy /home/mario/workspace7/SuperMango/build/WEB-INF/classes/com/serotonin/mango/rt/maint/work/WorkItem.class to /home/mario/Programas/apache-tomcat-6.0.20/webapps/ROOT/mango/WEB-INF/classes/com/serotonin/mango/rt/maint/work/WorkItem.class due to java.io.FileNotFoundException /home/mario/Programas/apache-tomcat-6.0.20/webapps/ROOT/mango/WEB-INF/classes/com/serotonin/mango/rt/maint/work/WorkItem.class (No such file or directory)
                              Total time: 2 seconds
                              other thing i observe is the fact when i started tomcat by the eclipse, i can't access the "http://localhost:8080/" , returning a HTTP Status 404
                              but when i started the tomcat by console like root, i can access the homepage of tomcat("http://localhost:8080/") and "http://localhost:8080/manager/html" normally
                              regards,
                              Mario
                                Hi Mario,
                                If you're going to have a context path of "mango", then your hostname should not include "ROOT". Try changing the following build.properties value:
                                  mmn666
                                  Hi mlohbihler,
                                  i changed to
                                  but don't have any effect...
                                  compile:
                                  static:
                                  build:
                                  copy:
                                  BUILD FAILED
                                  regards,
                                  Mario
                                    Maybe a silly question, but can you say how much of this path actually exists:
                                      mmn666
                                      maybe is not a silly question hehehehe
                                      only this is real
                                      regards,
                                      Mario
                                        Incidentally, i strongly recommend changing the password in your tomcat-users file. There is a known crawler that looks for unprotected Tomcat instances and uses the manager to upload and start applications.
                                          That comment above was for all forum users, not just Mario.
                                          So, Mario, are you sure the user under which the build is running has permissions to write to the "webapps" directory?
                                            mmn666
                                            Hi mlohbihler,
                                            i change the permission and works now i have the folder
                                            and the build is ok
                                            compile:
                                            static:
                                            build:
                                            copy:
                                            deploy:
                                            BUILD SUCCESSFUL
                                            Total time: 26 seconds
                                            now i will try access http://localhost:8080/mango
                                            right?
                                            regards,
                                            Mario
