    New Update - Guest Access - Permission Issues?
    4 Posts 2 Posters 699 Views 2 Watching
      mihairosu
      It has been a long time since I've had to mess with guest access and permissions, so I'm a bit lost.
      We are running on Core 5.6.3
      Current Issue
      Our headless dashboards do not show all of the data points (some appear and some do not) and I cannot tell why. Some of the data points are meta data points and some are not.
      Configured Login
      These dashboards were set up to automatically log in using user guest and password guest through the URL as follows:
      https://internal.dns/ui/plumbing_dhw_overview?autoLoginUsername=guest&autoLoginPassword=guest1234&autoLoginStoreCredentials
      I checked one of the data points which was not visible and it has the following permissions:
      View point & Value:
      Superadmins (check)
      Users (check)
      Anonymous (unchecked)
      P.S. I tried to attach an image but there was an error "Imgur is temporarily over capacity. Please try again later."
      Resolution?
      I assume something has changed since the last update I performed.
      Previously we were running 5.6.2.
      I assume it's an issue with permissions
      • joeamiragliaJ Offline
        joeamiraglia
        Hello @mihairosu,
        It sounds like your diagnosis is on the right track. Here are the most likely causes based on what you’ve described:
        1. Check that the guest user actually has the Users role
          Since the point shows Users = checked and Anonymous = unchecked, the guest account must:
        • Be successfully logged in
        • Belong to the Users role
        If the guest account was created manually rather than through the usual user-creation workflow, it’s possible it never received that role.
        You can verify under Administration → Users → guest.
        1. Confirm whether auto‑login is actually succeeding
          If your auto‑login fails silently, Mango will treat the session as Anonymous, and any point that does not allow Anonymous access will simply disappear with no warning.
          To verify:
        • Open your dashboard URL in a private/incognito window
        • Check whether Mango shows you logged in as guest
        Also, your example URL uses:
        But you mentioned the password is guest. If those don’t match, the login will fail and the session becomes anonymous.
        1. For meta points specifically
        • Meta data points inherit visibility from their own permissions, but their values come from underlying source points.
        • If the guest user does not have permission to read one of the source points a meta point depends on, the meta point may appear on the dashboard but will fail to resolve a value.
        • So make sure the source points also include the Users role (or whatever group your guest belongs to).
        1. Version change (5.6.2 → 5.6.3)
        • Since this was working before the upgrade, it’s worth checking the 5.6.3 release notes. There have been a few changes recently around role evaluation and anonymous access. Even subtle permission tweaks could affect dashboards that rely on auto‑login.
          https://docs-v5.radixiot.com/v5-release-notes-overview
          mihairosu @joeamiraglia
          Hey @joeamiraglia ,
          Okay I confirmed all of that and it seems like the guest user is working okay.
          Let's begin with this data point which no longer updates:
          member2BoilerStatusCode
          The data flows as follows:
          device -> via ModbusRTU to MangoES -> via Publisher to Enterprise Mango.
          • ModbusRTU to MangoES: data is successfully retrieved
          • Publisher to Enteprise Mango: data has not updated since 2/7/2016
          I really wish I could attach images on here but you guys have some problems with IMGUR apparently, anyway.
          • MangoES: Data updates correctly visible on the watch list, it is not disabled.
          • MangoES Publisher: member2BoilerStatusCode shows up on the "Published data points"
          I tried removing it and re-adding it to the publisher and that did not help.
          I even tried changing the data point template to update when timestamp changes and that did not resolve it.
          I don't see any problems with the history synchronization otherwise in the publisher status or events.
          I'm not sure how to diagnose this.
          joeamiragliaJ 1 Reply Last reply Reply Quote 0
            joeamiraglia @mihairosu
            @mihairosu FYI - Image issue with the forum has been fixed.
