    Using Serial Data Source as MBUS device
    29 Posts 5 Posters 34.1k Views 5 Watching
      MattFox @Turbo
      @Turbo no I used to for radio transmitters over serial. I still do for small electronics projects.
      But it is something that needs to be looked at.
      TurboT 2 Replies Last reply Reply Quote 0
      • TurboT Offline
        Turbo @MattFox
        @MattFox Okay:
        For folks that come through here, this appears to work for socat:
        b45e4d18-fd36-4a9c-9467-02d5769e6511-image.png socat -d -d -d -d tcp-listen:4141,reuseaddr,fork file:/dev/ttyUSB0,nonblock,cs8,b2400,cstopb=0,raw,echo=0
        (that's got debugging turned on)
        But these devices are "originate only" (M-Bus just sends, no listen, just talk), so now I'm trying to figure out to to get that data into mango..
        Same thing as before: Just see "data source started" in the TCP data souirce log file, but my little socat command status is streamalating data.. I'm now working this angle.
        If I can't get this figured out, I'll roll back to Mango V3 and see if that M-Bus in there still works for us.
        • TurboT Offline
          Turbo @Turbo
          @Turbo Also: This definitely works, btw, since if you telnet to that port I set up, you can see the data streaming in from the device. It's hex, though, not ascii, so it's not remotely human readable..
          When I try and select "configuration in HEX" in the TCP data source setup, it won't let the box stay checked: Each time I check it, when I refresh the page, it comes back as unchecked again.
          The adventure continues..
          • TurboT Offline
            Turbo @Turbo
            @Turbo Also: When you save the TCP Data source (usually) the Select Data Source list updates automatically when you create a new datasource: In this case, the new datasource is not automatically created. New clues coming in rapid-fire here.
            • TurboT Offline
              Turbo @Turbo
              @Turbo Well hot damn. The thing works.
              So now I can socat data in as a TCP point.. That's cool.
              For folks following along:
              First, do this to forward the port:
              This is a 2400 baud device.
              I set the timeout for 250, no delimeter, and then port 4141 (as above) and host of Localhost.
              Then, in the data point, I created a general placeholder with a read command of "00" and a value regex of (.*), value index 0
              This appears to update properly.
              Now to write a parser- This sure would be easier with the original M-Bus device.
              Thanks for your help, @MattFox .
              There also appears to be a bug (still) in the serial data source, at least when running on Linux- This test install is a raspberry pi, but we'll be deploying this on our IMX8's as usual, I hpoe.
              TurboT 1 Reply Last reply Reply Quote 1
              • TurboT Offline
                Turbo @Turbo
                @Turbo Ok. One more quick question on here: Since this device is (effectively) streaming data in - There isn't even a RX pin on the device we're talking to, is there a way to set up the tcpip connector to just store data as it comes in, rather than requiring the use of the "read" command before awaiting a response?
                Right now, I'm just sending "00" out as a read command, but the device has no read command; It just spews data out. The read command forces a sync where none exists. I'd rather just have the tcpip point record the point when data comes into the point, rather than after the read command is issued.
                If I disable "queryable" I get no data at all, but I enable queries, I end up missing every third packet, since there's no way to sync the "output only" nature of the M-Bus device with Mango's need to poll and record a response.
                It kinda works, but I wonder if there's some secret to have Mango just store whatever comes in over that port?
                • TurboT Offline
                  Turbo @MattFox
                  @MattFox So: Turns out the socat solution works, but it's not really as straightforward as using the Serial device natively:
                  Can you poke around and see if the Serial data source needs some hugs? Using a TCP forward for a USB converter serial port seems a bit silly to me, when Mango has a raw Serial device interface that (should) do the same thing.
                  I've now had no luck with the serial data source on my ARM based IMX8 machine over hardware serial or USB to 485 serial under V3 or V4, and now am seeing the same thing under V4 on a raspberry pi.
                  I'm happy to set up a screen share / demo video / something if you want to see what I'm seeing with this.
                  Thanks for your help, in any event, as we now have a (mostly) working MBus data source again, although in a somewhat ridiculously rube-goldbergesque way.
                    MattFox @Turbo
                    @Turbo sure I'll flick you a PM
                    • T Offline
                      tungthanh500 @Turbo
                      @Turbo can you share the reason why you didn't use a Mbus to Modbus TCP converter in your cases? The only time I have to reqd data from Mbus devices, I use Anybus gateway, quite easy to use.
                      • TurboT Offline
                        Turbo @tungthanh500
                        @tungthanh500 Budgets. The M-Bus to USB converter is $20, the M-Bus to modbus device is considerably more expensive. Our goal is also to keep the number of things "needing configuration" to an absolutely minimum:If we can do it in Mango, it saves us time and money (and spare parts inventory costs).
                        • cwangvC Offline
                          cwangv @Turbo
                          @Turbo
                          I didn't notice the MBUS driver has been dropped. That is bit disappointing. I have got a project with 50 MBUS meters. So I have to hook them into something else then spit them back out via BACnet IP then.
                          the workaround you have mentioned is a bit painful to implement and to get working reliably.
                          • TurboT Offline
                            Turbo @cwangv
                            @cwangv That's true- I'm happy to send you my code, if you want, when I get it working- It's just a scripted point that searches raw strings for the OBIS code and saves it in datapoints. This for energy meters, and so far, it works OK.
                            @CraigWeb any plans on bringing the M-Bus module in Mango V4? It's interesting, since it's still stated as "supported" on Mango's website: https://radixiot.com/supported-protocols
                            You only find out it's missing from V4 when you look at the documentation for Upgrade from V03 -> V04: https://docs-v4.radixiot.com/upgrade-to-v4 and scroll down to "unsupported modules"
                            • T Offline
                              tungthanh500 @Turbo
                              @Turbo you arr right, I bought a converter at $500 in my country just for 4 water meter
                                CraigWeb @Turbo
                                @Turbo I think you would be better off chatting with our team about adding the data source back to v4. We removed it because we had a total of 5 downloads over 3 years.
                                TurboT cwangvC 2 Replies Last reply Reply Quote 0
                                • TurboT Offline
                                  Turbo @CraigWeb
                                  @CraigWeb I appreciate that; We're going to be shipping a mountain of these things internationally use M-Bus (I hope), so for now I'm using my TCP silly workaround for this (since the Serial data source still appears to not work properly for whatever reason on our Arm-based machines).
                                  Some other folks have piped up here as well about M-Bus- This exists basically nowhere in the US (as I've found now that I'm testing things using M-Bus) but apparently is quite common in IOT purposes in Europe- Every meter in Norway (for example) has an M-Bus port for interfacing HAN devices directly to your buildings' meter.
                                  Surely someone must have had a reason that this got added in the first place; Although I do understand not updating things if nobody is using it. Since we're going to be using this A Lot (I think), we may be able to chat NRE to get it put back- I'm still chatting with Michael about Mango for our 2023 project pipeline, and this could be a good business discussion point to have.
                                    CraigWeb @Turbo
                                    @Turbo ye I know of one other client in Ireland who is using it successfully in v3 with about 30 MangoGTs so ill help motivates it with that point.
                                    • cwangvC Offline
                                      cwangv @CraigWeb
                                      @CraigWeb
                                      Hi, Craig
                                      Good to see you back on here.
                                      I will definitely submit this for my project since I have an existing Mango system running.
                                      Should I just get in contact with technical support?
