    Bacnet data problem
    8 Posts 3 Posters 2.6k Views 3 Watching
    • U Offline
      ua
      In Mango ver 4 scada ( Win 8.1, firewall off) I have 5 Bacnet IP devices )192.168.1.10 - 192.168.1.14 and Instance number 10-14) with 30 data point in total.
      When I list bacnet object in device browser present value of each gives the correct value, but in data points It has all zeros.
      All data point added from Mango automated proceduere after listed in device browser and they have correct value of device-instance-number and object-instance-number and all enabled.
      IP addresing of Bacnet/IP devices is confusing :
      Administration_Data Source_Bacnet/IP local devices
      When i put IP address of Bacnet device in LAN e.g. 192.168.1.10:47808 or 0.0.0.0:47808 result in device browser is nothing. But when I put address of server pc ( pc where installed Mango scada) e.g. 192.168.1.30:47808 device browser list all five BACnet devices on LAN. But in list of Administration:Bacnet local devices all five devices have own IPaddresses, 192.168.1.10:47808 until 192.168.1.14:47808
      How to connect properly present value of bacnet objects with point value of data points ( and such values get on the point-value) ?
      Thanks!
      • cwangvC Offline
        cwangv
        can you supply some screenshots to illustrate your problems?
        Have you checked the below location and tie the network card to the system?
        • U Offline
          ua
          Thanks for quick response !
          I did not create a bacnet device with the address 0.0.0.0. I will create it today and try again. I thought that MY PC is baknet connection to devices on the network.
          The image "Bacnet local devices - dev 1" is an example as the others are set - the last octet of the IP address is the baknet address. It is identical in the "Data Sources" menu - they all have the address MY PĆ where the Mango app is located.
          Thanks!
          data sources - my pc.png data sources - device 3.png data sources - device 1.png Bacnet local devices.png Bacnet local devices - dev 1.png
          • U Offline
            ua
            Whether the license is a problem? ... I activated the license for free, up to 300 data points with unrestricted Bacnet .
            • U Offline
              ua
              today i installed mango 3.77 and everything works properly
              The same settings in mango 4.00 do not work as in the first post.
              • cwangvC Offline
                cwangv @ua
                @ua
                maybe something has changed in V4.
                • cwangvC Offline
                  cwangv @ua
                  @ua
                  you shouldn't have to define your target BACnet/IP devices as your local BACnet/IP devices.
                    @ua something else to note is that it appears you have a local device for each of your data sources. I'm not sure of your use case but it might work better if you share one local device across all of your data sources.
