<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Bacnet data problem]]></title><description><![CDATA[<p dir="auto">In Mango ver 4 scada ( Win 8.1, firewall off) I have 5 Bacnet IP devices )192.168.1.10 - 192.168.1.14 and Instance number 10-14) with 30 data point  in total.</p>
<p dir="auto">When I list bacnet object  in device browser present value of each  gives the correct value, but in data points It has all zeros.</p>
<p dir="auto">All data point added from Mango automated proceduere after listed in device browser and they have correct value of  device-instance-number and object-instance-number and all enabled.</p>
<p dir="auto">IP addresing of Bacnet/IP devices is confusing :<br />
<em>Administration_Data Source_Bacnet/IP local devices</em><br />
When i put IP address of Bacnet device in LAN e.g. 192.168.1.10:47808 or 0.0.0.0:47808 result in device browser is nothing. But when I put address of server pc ( pc where installed Mango scada) e.g. 192.168.1.30:47808 device browser list all five BACnet devices on LAN.  But in list of <em>Administration:Bacnet local devices</em> all five devices have own IPaddresses, 192.168.1.10:47808 until 192.168.1.14:47808</p>
<p dir="auto">How to connect properly present value of bacnet objects with point value of data points ( and such values get on the point-value)  ?</p>
<p dir="auto">Thanks!</p>
]]></description><link>https://forum.mango-os.com/topic/5230/bacnet-data-problem</link><generator>RSS for Node</generator><lastBuildDate>Wed, 15 Jul 2026 05:04:25 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/5230.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 05 Jul 2021 17:05:59 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Bacnet data problem on Fri, 09 Jul 2021 00:14:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ua" aria-label="Profile: ua">@<bdi>ua</bdi></a> something else to note is that it appears you have a local device for each of your data sources.  I'm not sure of your use case but it might work better if you share one local device across all of your data sources.</p>
]]></description><link>https://forum.mango-os.com/post/26791</link><guid isPermaLink="true">https://forum.mango-os.com/post/26791</guid><dc:creator><![CDATA[terrypacker]]></dc:creator><pubDate>Fri, 09 Jul 2021 00:14:49 GMT</pubDate></item><item><title><![CDATA[Reply to Bacnet data problem on Wed, 07 Jul 2021 11:08:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ua" aria-label="Profile: ua">@<bdi>ua</bdi></a><br />
you shouldn't have to define your target BACnet/IP devices as your local BACnet/IP devices.</p>
]]></description><link>https://forum.mango-os.com/post/26777</link><guid isPermaLink="true">https://forum.mango-os.com/post/26777</guid><dc:creator><![CDATA[cwangv]]></dc:creator><pubDate>Wed, 07 Jul 2021 11:08:33 GMT</pubDate></item><item><title><![CDATA[Reply to Bacnet data problem on Wed, 07 Jul 2021 11:04:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ua" aria-label="Profile: ua">@<bdi>ua</bdi></a><br />
maybe something has changed in V4.</p>
]]></description><link>https://forum.mango-os.com/post/26776</link><guid isPermaLink="true">https://forum.mango-os.com/post/26776</guid><dc:creator><![CDATA[cwangv]]></dc:creator><pubDate>Wed, 07 Jul 2021 11:04:26 GMT</pubDate></item><item><title><![CDATA[Reply to Bacnet data problem on Tue, 06 Jul 2021 19:29:33 GMT]]></title><description><![CDATA[<p dir="auto">today i installed mango 3.77 and everything works properly<br />
The same settings in mango 4.00 do not work as in the first post.</p>
<p dir="auto"><img src="https://camo.nodebb.org/0bb750cdd2ccaee07b08be6d57ed8ab03800bbd1?url=https%3A%2F%2Fi.imgur.com%2FCEvl8Rx.png" alt="2.png" class=" img-fluid img-markdown" /> <img src="https://camo.nodebb.org/c6cfa7db8563c8331bb5a08f0112aa40c02a74d8?url=https%3A%2F%2Fi.imgur.com%2Fw35MpsY.png" alt="1.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.mango-os.com/post/26774</link><guid isPermaLink="true">https://forum.mango-os.com/post/26774</guid><dc:creator><![CDATA[ua]]></dc:creator><pubDate>Tue, 06 Jul 2021 19:29:33 GMT</pubDate></item><item><title><![CDATA[Reply to Bacnet data problem on Tue, 06 Jul 2021 19:05:17 GMT]]></title><description><![CDATA[<p dir="auto">Whether the license is a problem? ... I activated the license for free, up to 300 data points with unrestricted Bacnet .</p>
<p dir="auto"><img src="https://camo.nodebb.org/170addf35973623457632470f6e5fcd863e34aa4?url=https%3A%2F%2Fi.imgur.com%2FSfmCFQ8.png" alt="lic.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.mango-os.com/post/26772</link><guid isPermaLink="true">https://forum.mango-os.com/post/26772</guid><dc:creator><![CDATA[ua]]></dc:creator><pubDate>Tue, 06 Jul 2021 19:05:17 GMT</pubDate></item><item><title><![CDATA[Reply to Bacnet data problem on Tue, 06 Jul 2021 05:54:27 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for quick response !<br />
I did not create a bacnet device with the address 0.0.0.0. I will create it today and try again. I thought that MY PC is baknet connection to devices on the network.</p>
<p dir="auto">The image "Bacnet local devices - dev 1" is an example as the others are set - the last octet of the IP address is the baknet address. It is identical in the "Data Sources" menu - they all have the address MY PĆ where the Mango app is located.<br />
Thanks!</p>
<p dir="auto"><img src="https://camo.nodebb.org/f843eced7f73d6e418ea2146f843321a3e4f215f?url=https%3A%2F%2Fi.imgur.com%2F9WFD6lJ.png" alt="data sources - my pc.png" class=" img-fluid img-markdown" /> <img src="https://camo.nodebb.org/5a830c8039345cf03e53ef6a85ce41dca0002689?url=https%3A%2F%2Fi.imgur.com%2FsjNL0Ym.png" alt="data sources - device 3.png" class=" img-fluid img-markdown" /> <img src="https://camo.nodebb.org/a106fbc6d973a3f00c2903c3a5616720e94458e3?url=https%3A%2F%2Fi.imgur.com%2F1QVsaXq.png" alt="data sources - device 1.png" class=" img-fluid img-markdown" /> <img src="https://camo.nodebb.org/d4f423712f8d314f74481f83dbcf1f3647e52c3a?url=https%3A%2F%2Fi.imgur.com%2FEHu8Lqi.png" alt="Bacnet local devices.png" class=" img-fluid img-markdown" /> <img src="https://camo.nodebb.org/80cf008b6ba50c3084b61c35d15071e374e18c22?url=https%3A%2F%2Fi.imgur.com%2FjI6UPLG.png" alt="Bacnet local devices - dev 1.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.mango-os.com/post/26769</link><guid isPermaLink="true">https://forum.mango-os.com/post/26769</guid><dc:creator><![CDATA[ua]]></dc:creator><pubDate>Tue, 06 Jul 2021 05:54:27 GMT</pubDate></item><item><title><![CDATA[Reply to Bacnet data problem on Mon, 05 Jul 2021 23:44:12 GMT]]></title><description><![CDATA[<p dir="auto">can you supply some screenshots to illustrate your problems?<br />
Have you checked the below location and tie the network card to the system?</p>
<p dir="auto"><img src="https://camo.nodebb.org/bc045e883bc02951c55fe84c10dcd297411153b4?url=https%3A%2F%2Fi.imgur.com%2FtzWSweK.jpg" alt="bacnet ip.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.mango-os.com/post/26765</link><guid isPermaLink="true">https://forum.mango-os.com/post/26765</guid><dc:creator><![CDATA[cwangv]]></dc:creator><pubDate>Mon, 05 Jul 2021 23:44:12 GMT</pubDate></item></channel></rss>
