    Mango cannot run after installation
    16 Posts 5 Posters 8.2k Views 4 Watching
    • danD Offline
      dan
      What happens if you do...
      java -version
      ramhuzainiR 1 Reply Last reply Reply Quote 0
      • ramhuzainiR Offline
        ramhuzaini @dan
        @dan Hi dan
        pi@raspberrypi:~ $ java -version
        openjdk version "11.0.9.1" 2020-11-04
        OpenJDK Runtime Environment (build 11.0.9.1+1-post-Raspbian-1deb10u2)
        OpenJDK Server VM (build 11.0.9.1+1-post-Raspbian-1deb10u2, mixed mode)
        pi@raspberrypi:~ $ javac -version
        javac 11.0.9.1
        • cwangvC Offline
          cwangv @ramhuzaini
          @ramhuzaini
          can you try using a different GUI?
            ramhuzaini @cwangv
            @cwangv Hi
            What do you mean by different GUI?
            • cwangvC Offline
              cwangv @ramhuzaini
              @ramhuzaini
              I can see you are using X11 as your GUI environment (windows like). Can you try Gnome or something else?
              • danD Offline
                dan
                It should be all running in command line.
                Maybe Java is looking for a default browser, try installing Links or Lynx
                Or if you have XWindows installed, check it has a default web browser?
                  If it is looking for a default browser, the setting for opening a browser on boot complete can be disabled via the env.properties file. If dan has found this to be an issue, try disabling the setting (Set to false) and see how mango behaves.
                  Also try ensuring all mango directories are run and owned by mango.
                    ramhuzaini
                    Hi everyone,
                    I have solved the problem. The problem is that I cannot run Mango through remote desktop connection. It has to be run directly from the pi. Anyway that everyone for your advice
                    best regards
                    Ramhuzaini
                      Would have helped if you had mentioned the remote desktop part a bit sooner...
                      If you want remote access, use a VPN. It is secure and easy to set up.
                        ramhuzaini @MattFox
                        @mattfox
                        Ok thanks for that information. Will do that.
                        best regards
                        Ramhuzaini
