    New Developer Documentation
    5 Posts 3 Posters 6.8k Views 3 Watching
      Hi All,
      Just wanted to let you know we have updated our developers documentation. We have separated it into 2 parts, Angular for the UI and Java for the backend. As of Mango 3.7 there is a new 'development' mode that can save time developing. Check them out here:
      UI Development Process
      Eclipse for Java
      H 1 Reply Last reply Reply Quote 3
        Hi Terry, just letting you know I clicked in and nothing appeared on mobile when I clicked on the Ui Development process menu item.
        Sorry, disregard, it wasn't until I went into my pc I realised the page is actually a file download...
        • H Offline
          hazel
          Hi Terry,
          We will install development environment for Mango v4.0.0.beta5 to our test servers.
          We are following the steps on this link http://docs-v4.mango-os.com/mango-java-developer-ide-setup-and-usage .
          We completed the steps until the “Copy Overrides” part. But on that part we cannot find classes folder and classes debug-log4j2.xml file on the directory.
          Also, on the Run Configuration part while we are configuring VM Arguments, we could not set debug-log4j2.xml file.
          We saw that properties file is on the resources file. On the run configuration dependencies tab, what should we connect to Classpath Entries?
          Is there a different documentation for beta.5 development environment?
          Thanks in advance,
          • H Offline
            hazel @terrypacker
            Hi @terrypacker
            Hi Terry,
            When will you update your developer documentation? I encountered a different configuration than the current version in Create Java Modules for Mango > Custom Module Configuration. How do I build the module in version 4.3.5.
            Thanks in advance,
              terrypacker @hazel
              @hazel there are no plans to update that documentation, your best bet is to review the code for our modules here:
              https://github.com/MangoAutomation/ma-modules-public
              If you can be specific about what you are trying to accomplish I might be able to point you in the direction of some code that will help your specific use-case.
